Question about Jura Capresso Jura Ena 3 Espresso Machine Coffee Maker
How do i open an ENA 3 case - Jura Capresso Jura Ena 3 Espresso Machine Coffee Maker
System is not filling in my Ena 3. Pump stalled despite several attempts to prime it. Any suggestion?
I do not know what efforts you made to prime the pump.
1- Make sure that the water faucet is open.
Use a hand pump to push water into the pump. You can use a syringe or a hand pump. See instructions attached. Services Unlimited Inc Parts Guru Since 1988
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edward_bbd2c7ff4ee1828a
Dec 16, 2016 | Jura ENA 3 Automatic Coffee Center - Black
Jura ena 3 rotary dial issue
Have you tried completely powering it down, as far as unplugging it from the wall? Sorry if that's stating the obvious, but I'm a computer guy and 9 times out of 10, a 'reboot' fixes the problem.
Aug 04, 2014 | Jura Capresso Jura Ena 3 Espresso Machine ...
Jura ena don't grind coffee
new grinder teeth
Dec 27, 2013 | Jura ENA 3
How do i unlock my zte tablet exceeded 3 times
Hey Ena i guess u need to contact ZTE and check if they can help u out with this issue. Either sign on to this website: http://zte.sbeglobalservice.com/ or call them on +44(0) 1233652005
Apr 10, 2013 | ZTE V9a 7" 4gb 3g Wifi Capacitive Tablet...
Disassemble ena 4
As far as I know the Jura machines have a special oval shape screw head on their panels...and Jura charge something outrageous like 150euro if you want to buy the tool for opening these! Mite be worth trying to open it some other way like by gluing a tool or something into the head and let it dry, then open it.... then maybe replace the oval head screw with a different screw type when reassembling. Not an easy method of getting past the problem but id sooner do it than pay for the tool!!
Hope this helps
Dec 04, 2012 | Jura Capresso ENA 4 (13421)
Ena 3 troubleshooting: Right now it appears that the right coffee spout has a weaker flow than the left. Is it clogged? How can I fix it if it is even broken. Thanks!
Got it! It took me two months and the parts diagram to figure it out.
http://www.jura-parts.com/v/vspfiles/diagrams/Jura%20Impressa%20ENA%203,%20ENA%205%20Diagram.pdf
Use a water-flosser... I used like 8 full water tanks and DONE.
The simpler way would be to try to point up the water-flosser through each of the four holes of each spout... It will be a mess but it should work.
The other way:
1.- Take the grey plastic panel out from the front dispenser. Use a small flat screw-driver, start from the top, there are 2 clips, and then 2 other clips on the bottom.
ena-3-troubleshooting-right-now-appears-nddfxdzj3csnr0xni24gr4jm-4-0.jpg ena-3-troubleshooting-right-now-appears-nddfxdzj3csnr0xni24gr4jm-4-2.jpg 2.- You will see the dispenser "inside", a two black tubes with the spouts at the end and an air intake (I guess) on top. Take out the air intake, that will let you have access into the tubes with the water-flosser.
ena-3-troubleshooting-right-now-appears-nddfxdzj3csnr0xni24gr4jm-4-9.jpg 3.- Take your time "flossing" your dispenser, as I said it took me like 8 water tanks... a lot of coffee residual got accumulated (to my surprise).
ena-3-troubleshooting-right-now-appears-nddfxdzj3csnr0xni24gr4jm-4-14.jpg 4.- Voila!
Jan 29, 2011 | Jura Capresso Jura Ena 3 Espresso Machine ...
Giannis
I cant understand the language sorry i cant help you!
Nov 01, 2008 | 1990 Honda CRX
Jura Capresso Jura Ena 3 Espresso Machine  Coffee Maker Logo
163 people viewed this question
Top Jura Capresso Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Ken Macumber
Ken Macumber
Level 1 Expert
Are you a Jura Capresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
