Question about Guillemot Thrustmaster Ferrari Force Feedback GT Racing Wheel (2969062) Wheel And Pedals Set
Is there any way of getting this wheel to work with an xbox 360?
I've had the wheel for years and it's got a USB connection. My sin has just got a new xbox 360 and wants to play Hot Wheels Racing with it.
How do i connect my ev8 racing wheel to xbox 360
If it has a usb you just plug it in, if it's a ps2 game controller you can not use it on a 360. But not all usb controllers will work on a 360
Jul 11, 2014 | Microsoft Xbox 360 Console
Can't get the super sports 3x steering wheel to light up
Ensure wheel is compatible with xbox360 - search compatible wheels online - the list is short.
Dec 25, 2013 | Microsoft Xbox 360 Console
When I plug in my wired xbox 360 controller it will blink for a split second, and then stop responding. I can power on the machine with it but I can't do anything else with it. It started doing th
Dear kakaixero,
The USB port on your XBOX may have experienced short circuit when your dogs ran over it. Just to make sure,try connecting some other device (such as the racing wheel) and see if it works. If it doesn't,take your XBOX to the nearest service point and ask them to replace it. Act like it's not your fault and you might actually get a new xbox!
Oct 19, 2012 | Microsoft Xbox 360 Controller
My xbox doesnt want to pickup the ethernet connection
There are two ways in which you can address this issue:
1) Attempt to connect wirelessly. You can access this feature via "Settings" on your XBox home page. After setting up your XBox to automatically connect to your internet router (by entering the password and name), you should be able to log into and play on XBox Live.
2) Connect via ethernet cable.
Although you've already tried this, it's possible there is an issue with your modem and not your XBox. Routers and modems usually have a shelf life of about 2-3 years-- if you have had yours for longer than that, it might be time to invest in a new one. Another issue could be a faulty ethernet cable-- they're usually pretty cheap (around ten bucks), so if the above fixes don't work go into a local electronics store, purchase one, try it out, and if it doesn't work return it immediately and you should get your money back.
Jan 31, 2012 | Microsoft Xbox 360 Console
Why won't my universal mc2 wheel work with my xbox 360, are these not compatible. None of the output leads would fit into the xbox 360, so I actually got an adapter lead that fits into one of the 3...
There should be a USB cable that came with the wheel that connects directly to the Xbox 360. Are referring to the Madcatz MC2? If so then you might be missing the USB cable connector? You can't modify the other inputs to feed into the Xbox 360. You need to use the cable that comes with the wheel.
Also, some games are not compatible with the wheel.
Jul 19, 2011 | Video Game Consoles & Games
I have a tevion steering wheel (5 years old not used yet) can I connect it to my xbox 360 elite. the connection leads have 4 plugs one for GC, one for Play station 1/2 , one for pc(usb) and one for Xbox....
Sorry to be the one to break this to you mate, but the Tevion steering wheel is only compatible with the following;
  • Game Cube
  • Playstation 1
  • Playstation 2
  • PC
  • Original Xbox
Now I can not guarantee this will work, but before you give up completely, Try Using the USB plug for the PC in one of the USB ports for the xbox 360 elite. They are located to the right of the front if you have your xbox 360 elite lying down flat, under a small flap. I use a Keyboard intented for a computer with my xbox 360 S in the same manner, so hopefully that will work.
Jun 26, 2011 | Video Game Consoles & Games
My turbo controller wont connect to the cuztomizer
my new wirless turbo fire 2 controller with rumble will not connect to my xbox 360 console... i' ve tried syncing it several times as instructed but no go...
what am i doing wrong, it will not work with my xbox 360!
Feb 17, 2011 | Datel Xbox 360 Turbo Fire 2 Wireless...
I have just received a Madcatz MC2 wheel for the XBOX360 that I purchaced on ebay. However I cannot find out how to connect it as the lead from the wheel has a round plug and I can only assume that I need...
you have to go to amazon and type in "XBOX Controller to PC / MAC USB Cable Adapter" it only cost $4 plus shipping i had to do it to get my Mad Catz wheel to work with xbox 360. I paid $10 for mine rather then a hundered and works fine with all games.
Aug 20, 2010 | Mad Catz MC2 Universal (6320) Wheel And...
La direccion de la consola esta deshabilitado mac xbox360
Conectar xbox 360 a internet; si tienes xbox 360 y quieres jugar en internet, ve este tutorial.
Como conectarse al Live.
Bueno tienes tu nueva 360 smile.gif y ahora quieres entrar a la experiencia Xbox Live y no sabes cómo. Acá una guía que te enseñara como hacer desde las conexiones de redes (VTR por ahora) hasta la creación de tu cuenta Xbox Live/gamertag.
Las Conexiones:
Hay 4 opciones para conectar tu consola:
A: Directamente desde el MODEM de VTR.
Conecta el cable de red que sale del MODEM a la 360.
MODEM ------------ 360
1. Llama a VTR (600 600 9000 opcion 3, 3), pideles que te cambien el numero de MAC al que tiene la 360.
2. Para saber como obtener tu numero de MAC debes buscarlo en las opciones del menu de 360
3. Una vez hecho esto estás listo para entrar a Xbox Live.
B: Desde el MODEM de VTR 2 conexiones (USB y RED).
MODEM red ------------- 360
usb ------------- PC
1. Conecta el otro dispositivo que tengas (Ej. PC) y conectalo via USB.
2. Conecta la 360 por el Cable de Red.
3. Llama a VTR (600 600 9000 opcion 3,3), pide que te registren 2 MACs, la del PC y la 360. Así ambos quedarán con Internet.
4. Una vez hecho esto estás listo para entrar a Xbox Live.
C: Router
Modem ------- Router ------ 360
1. Conecta la 360 al router con un cable de red.
2. Ahora hay que configurar el Router. (Ruteo de puertos)
1. Tienes que entrar al menú de administración del router. Generalmente la dirección es 192.168.0.1, después te pedirá nombre y contraseña. Generalmente es User: admin, sin password. Si no funciona, vas a tener que conseguirtelos.
2. Una vez dentro del menú.
3. En la página eliges Forwarding.
4. Elige la marca de tu router.
5. Elige Xbox Live 360
6. Sigue las instrucciones de cómo “rutear” los puertos para la 360 (88 y 3074)
7. Una vez ruteados los puertos, estás listo. Empieza la creación de tu Gamertag.
D: Router via Wifi
Router )))))))) 360
1. Necesitas el Adaptador Wifi para la 360
2. Necesitas un router con soporte Wifi b/g
3. Prendes la 360 vas a la parte de Sistema – Config de Red – Windows Connect Now.
4. Eliges el Spot Wifi
5. Desde un PC, Ahora hay que configurar el Router (Ruteo de puertos).
5. Elige Xbox Live 360, Sigue las instrucciones
6. Una vez hecho lo anterior, estas listo para crear tu Gamertag.
XBOX LIVE
Entendiendo Xbox Live:
Primero hay 2 tipos de cuentas para Xbox Live. Gold y Silver.
SILVER
• Permite a otros jugadores saber quién eres y cómo juegas gracias al perfil de jugador único.
• Entra en el Bazar Xbox Live para conseguir fantásticas descargas (incluidos los juegos clásicos de consola de Xbox Live Arcade), demostraciones y tráilers de los juegos que van a salir próximamente.
• Prueba la acción multijugador con acceso a partidas multijugador masivas. Lo único que tienes que hacer es crearte un gamertag.
• Disfruta de la acción multijugador sin límites con las oportunidades suscripción de prueba al nivel Gold.
• Crea y mantén una lista de amigos para conectarte y comunicarte instantáneamente con familiares y amigos mediante mensajes de texto y voz.
En otras Palabras... Puedes Bajar Trailers, demos, etc. Pero NO puedes jugar Online
May 20, 2010 | Microsoft Video Game Consoles & Games
Mtu error in xbox 360. is router compatible dell 2350
tienes un problema emn el router pero intenta directamenti sin el router
Aug 25, 2009 | Microsoft Xbox 360 Console
Guillemot Thrustmaster Ferrari Force Feedback GT Racing Wheel (2969062) Wheel And Pedals Set Logo
Top Guillemot Video Game Consoles & Games Experts
shaun taylor
Jeffrey
Jeffrey
Chris Larocque
Are you a Guillemot Video Game Console and Game Expert? Answer questions, earn points and help others
