My dvd drive is not reading a dvd
Reason 1. It could be a problem from the DVD drive.
Reason 2. The cause can be associated with DVD discs.
Reason 3. The DVD drive driver is not working.
Reason 4. The computer system should be correcting some parameters.
For more info and solutions, you can check on here:
Why is My DVD Drive Not Reading DVDs
Try using multiple DVDs and Also check the DVD region code if that may be causing the problem....Ensure that the media player you are using has the required codecs...VLC Player supports many codecs so check if that might be the problem VLC Player can be downloaded from www.videolan.org
