Question about Canon Pixma MX420 All-In-One Printer
Error code u053 on canon printer - Canon Pixma MX420 All-In-One Printer
2 Suggested Answers
  • 541 Answers
SOURCE: U053 error code,tried removing and replacing
Printing with an empty ink cartridge may cause printer malfunction. U051 / U052
U053 / U059 The ink cartridge may not be set properly, or an ink cartridge not supported by the printer is installed.
Install the proper ink cartridge.
Make sure to install both the ink cartridges even when you set the printer to use only one ink cartridge (Color or Photo) in printing.
If one of the ink cartridges is missing, this error will occur. U075 / U076 The ink cartridges are not installed in the proper position.
Install each ink cartridge in the proper position. U140 An ink cartridge not supported by the printer is installed.
Install the proper ink cartridge. U161 / U162 A used ink cartridge may be installed, or the ink cartridge may be empty.
Replace the ink cartridge.
By pressing the OK button, printing can be done without replacing the ink cartridge. However, the remaining ink amount cannot be detected properly, so the function to detect the remaining ink amount does not operate. READ/WRITE MODE Since the memory card is currently write-enabled, printing is not possible.
Set READ-ONLY MODE ON. NO PHOTOS ON CARD Some images in the memory card may not be in a supported format. images listed below cannot be printed directly from a memory card. Print them from a computer.
- images edited on the computer
- images in a format other than JPEG or TIFF
- images with double-byte characters used in the file name
- images saved in a folder nested 4 or more layers deep INCOMPATIBLE CAMERA The printer cannot communicate with the connected camera.
Disconnect the cable between the printer and the camera to clear the error.
Confirm the following items and print again.
1. Confirm that the camera you are using supports PictBridge or Canon Bubble Jet Direct.
If the camera does not support either one, the printer cannot print directly from the camera.
2. Set the camera in PictBridge print mode before it is connected to the machine. This is required before printing for some cameras that support PictBridge.
Please refer to the camera instructions for more information about procedures required before and after connection to the printer.
3. There may have been no response from the camera for the prescribed time.
Re-connect the cable between the camera and the printer. WASTE INK NEAR FULL The waste ink absorber is getting full.
Press the OK button to clear the error.
Printing can be done until the waste ink absorber becomes full. If the waste ink absorber becomes full, please contact your local Service Center for replacement of the absorber and printer maintenance.
The waste ink absorber is a part inside the printer, which absorbs ink used in the cleaning operations, etc. CHECK PRINTER Turn the printer off, and remove the power plug from the outlet.
About ten minutes later, plug it in again, and turn the printer on.
If the problem is not resolved, the printer may require servicing. Please contact your local Service Center. HEAD ALIGNMENT ERROR Automatic print head alignment failed.
Press the OK button to release the error.
Check the followings and do automatic print head alignment again.
- Check if A4/Letter-sized paper is loaded in the auto sheet feeder.
- Check if the paper output slot is not exposed to a strong light source
- Print the nozzle check pattern to check the status of the print head.
If the problem continues, do manual print head alignment. LOAD PAPER If paper is not set, set paper and press the OK button. When paper is set, check each item and do printing again.
1. Confirm that unusable paper is not set.
2. Confirm that paper is set properly.
3. Confirm that recommended paper is used, and the number of sheets set in the auto sheet feeder is within the limit.
4. Cleaning the paper feed roller may resolve the error.
If the problem persists, the printer may require servicing. Please contact your local Service Center. PAPER JAMMED Remove the jammed paper.
If paper jam frequently occurs, check the following:
1. Confirm that no foreign material is inside the printer.
2. Confirm that unusable paper is not set.
3. Confirm that paper is set properly.
4. Confirm that recommended paper is used, and the number of sheets set in the auto sheet feeder is within the limit.
Posted on Dec 27, 2009
Error U053
Download the latest drivers from Cannon and install them.Hear is link:-
Canon Printer Support
Apr 22, 2014 | Canon Office Equipment & Supplies
When installing new ink cartridges, I'm getting an error - U053 "The ink Cartridge cannot be recognized".. What should I do?
The easiest way to get rid from this problem is to clean the cartridge connector.This is the first steps.Good luck
Oct 08, 2011 | Canon MP490 InkJet Printer
Error u053
this error signals that something is wrong with ink cartridge.
You can try re-install ink cartidge, if this doesn't helps ink cartridge is defective and you need to replace with new one.
Hope that helps!
Aug 23, 2011 | Canon PIXMA MX320 Color USB InkJet Printer
Check ink u053 problem on my canon mx053
U053 is cartridge problem. Try to insert the cartridge properly. Or you may need to replace new cartridge.
Jun 10, 2010 | Canon MX300 Office All-In-One Printer
Why do i get uo53 error message
U053 is a printhead error, you might need a new printhead if all inks are installed properly and not empty. The printhead part number is stamped on the side of the printhead.
Nov 05, 2009 | Canon PIXMA MX310 All-In-One Printer
U053 Error
Use the correct ink cartridge referring to the model number indicated on the printer box or the instruction manuals. Please refer to below website: http://support-sg.canon-asia.com/contents/SG/EN/8000660401.html
May 29, 2009 | Canon PIXMA MX310 All-In-One Printer
Printer problem
My Canon MX310 doesn't like recycled ink cartridges, but doesn't do this.
Rjams
Jun 18, 2008 | Canon PIXMA MX310 All-In-One Printer
INSTALLING NEW PRINTER CARTRIDGES
Cyan or blue prints in stripes. Tried allignment but still cant solve the problem.
Oct 30, 2007 | Canon Pixma MP450 All-In-One InkJet...
Canon Pixma MX420 All-In-One Printer Logo
78 people viewed this question
old marine
old marine
