Question about Scantron ScanMark ES2010 2010 Optical Mark Reader Test Score OCR Scanner
ES2010 not being detected by Win7
Scanner not being detected by Win7 laptop
I need to boot Win7 by USB flash Drive created by a 2.5"FF SATA drive.
If you can tell your BIOS to use USB as the first boot device and the USB is from an ISO of Win7, it should work but your laptop won't be happy as the drivers may be wrong.
Dec 07, 2014 | Computers & Internet
My laptop can't see the device and did not accept the set up .my operating sys is win7 -64 bit
Hi - I believe that the LIDE 25 is not supported in WIndows 7. I've run into the same problem and found this out. The Canoscans that are supported are the LIDE100 and up...
Oct 13, 2012 | Canon CanoScan LiDE 25 Flatbed Scanner
DR-6080 not recognised after reloading Windows 7 (32-bit) on laptop. Re-installed latest driver (says Win7 supported) successfully but still won't work, Anything?
Disconnect the scanner from the computer. Uninstall driver software, shut down and restart the Comp. Reinstall the driver. (http://software.canon-europe.com/software/0036991.asp?model= ). connect the scanner and the system will report USB device plugged in. This should work.
S. Mohan. Chennai, India
Dec 02, 2011 | Canon DR-6080 Path-Through Scanner
I have a Samsung 500 GB portable drive which containes WD 5000BEVT Scorpio Blue drive inside. It is not recognised on my two laptops (1 running XP & other Win7). At times, it is recognised when I...
does the drive make any noise? does it whine or click? do you have both data AND power cables connected?
also, can you hear or feel the drive spin up when you provide power? i have a scorpio black in my laptop, and although it is very quiet, i can definately tell just by the feel and slight noise when it is running (without the hard drive indicator light being taken into consideration)
feel free to contact me directly i would like to help
Jul 06, 2011 | Computers & Internet
I lost my network adapters in my computer
I kind of need a little more info ie: operating system and what you have tried and what happened before you noticed they were lost. I am assuming you did not physically lose them. I can say though that windows xp, Vista and certainly win7 should detect them on startup and alert you or in Vista and win7 auti install.
Jun 03, 2011 | Computers & Internet
I have installed a windows 7 ultimate after uninstalling windows xp but now my blue tooth device is not working with my laptop it was working earllier with windows xp
no driver detected by Win7 for BT.....all drivers are not provided by Win7...u may not find a driver for your BT to work on Win7, but can try using the XP driver....
suggest have a dual boot....like i use....
WinXP on C
Win7 on D
and choose OS on boot...
so have the advantage of both OS....
Oct 30, 2010 | Computers & Internet
OVT Scanner won't run with Windows 7. Vupoint
We suffered this initially on a new laptop with Windows 7. I can't tell if the driver on the Vupoint website has been updated, or is the old XP/Vista driver, but we installed this (1/2011). In Picasa or the Photoimpressions software which comes with the scanner, we were then only able to acquire solid black images. However, when we tried all of the USB ports on the computer, we found that one of them (a USB2 rather than USB1 port) was able to function like normal. We suspect there is a funny issue with the amount of power going to the scanner from different USB ports, and maybe this interacts with the driver in some way.
Jul 07, 2010 | Office Equipment & Supplies
How can i make my scanner work for windows 7
Win7 will load most hp printer diver once connected to the PC. If the printer is detected and the driver loaded, you can use the windows fax and scan to scan your document.
Click start ------ All Programs ------ Windows Fax and Scan
Dec 29, 2009 | Office Equipment & Supplies
Scantron ScanMark ES2010 2010 Optical Mark Reader Test Score OCR Scanner Logo
Top Scantron Office Equipment & Supplies Experts
k24674
Are you a Scantron Office Equipment and Supply Expert? Answer questions, earn points and help others
