Question about GE JES1142SJ Microwave Oven
I ran the microwave with nothing in the oven (obviously by mistake). Now it won't heat the food. Timer, clock, etc works. Is there a simple part that I can replace to solve this problem or have I killed this appliance?
  • 6,784 Answers
You can replace the magnetron tube and , the heating will be restored. this is repairable.
Most magnetron tubes will run in the 120 to 140 dollar range.
Posted on Jun 19, 2009
Microwave Model (1992) J KP6460P1B6 Doesn't heat food. Timer, clock, etc. work fine.
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101 ;'
Aug 25, 2011 | Microwave Ovens
My GE Profile over range microwave spacemaker xl 1800 model jvm1870bf02 was working just perfect until my daughter decided to use the microwave as a timer and actual ran the microwave with nothing inside...
Magnetron is blown.
This high-energy microwave-transmitting device hides behind a small plate on side of oven.
The waveguide sticky-out part looks like a small tube.
Normally, water molecules absorb the energy, heating the food.
Without an absorbing 'load' inside the oven cavity, the high-frequency, high power energy bounces back into the magnetron and it destroys itself. (Magnetron Hari-Kiri).
In a nutshell, tech must renew magnetron.
Then iInstruct family members to never run it empty.
Oct 11, 2017 | GE JVM1850 1000 Watts Microwave Oven
Ge microwave digial dispaly works but nothing heats-
in 99% of casses its a burned out magnatron they can be expensive to replace but it depends on how much the microwave is worth
Jun 19, 2010 | General Electric Microwave Oven
My delonghi 800w microwave oven works but does not heat up food
If your handy with getting the cover off and looking inside... check the obvious.
I suspect :
fuse
thermister
relay
If both microwave and Heating elements dont work, then I will assume the magnetron is ok, ans we are dealing with a high voltage issue... and you will need at best... a volt meter and or neon troublelight...
moust appliances have a simple schematic inside... I would start with the heating element first... trace wiring back to circuit board... usually one side of the heating element is connected to the white wire (neutral) and live (Hot) side is controlled thru the circuit board... so finding the neutral should be easy... then trace with neon light or voltmeter...
I know easy for me to say... but with everything else working... it doesnt seem to be the microprocessor that controlls the unit...
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/lisa_52daba487e5b4d53
May 06, 2010 | DeLonghi MW 605 Convection/Microwave Oven
MY MICROWAVE WILL NOT HEAT FOOD. EVERYTHIN ELSE WORKS (FAN WORKS, BUTTONS WORK, CLOCK, KITCHEN TIMER, ETC) CAN I FIX THIS?
you can take it into a local repair shop but it might cost more to repair it. Looks like you can replace the unit for 150 to 250 sears carries this brand.
Nov 06, 2009 | Goldstar MV-1526 Microwave Oven
Our microwave (GE) not longer heats food items.
heatman101
r
Sep 27, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
The microwave stopped heating the food. Power
The light inside the micro wave needs to be replaced most have a door on the back side that yo can remove the screw and unscrew the bulb and take to a applince shop and purchance a new one to replace.
Jul 16, 2009 | Whirlpool GH4155XP Microwave Oven
Food not heated in mocrowave
I'd say the actual microwave generator has gone bad.
Jun 05, 2009 | GE XL1800 1100 Watts Microwave Oven
Microwave doesn't heat anything
This more than likely is the magnatron,< heats food >, making noise and not working. it isn,t really easy fix and can be done if you get part and experienced person to walk you through it. Most GE magnatrons have at least 5 yr warranty and if it isn't that old call them first.
Apr 23, 2009 | GE JVM1320 Microwave Oven
Hood range microwave not heating up
We had one that did the same thing. my brother got so mad at it he put a wrench in it and turned it on. It didn't do anything to it. No power surge nothing. It acted as if I put a plate of food. Lighted up turned and even beeped when done. The wrench wasn't even hot. Now I do recommend this myself. But we went and got antoher one.
There is something in there that magnifys the power inside the mircowave and it sounds like its out.
Dec 12, 2008 | Emerson MW8778 Microwave Oven
GE JES1142SJ Microwave Oven Logo
207 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
