Question about Snap-On 1750 PSI Electric Pressure Washer
My snap-on 1750 psi pressure washer not operate when turned on
When turned on with power to the on/off switch the unit will not operate
Karcher k3.86 on/off switch does not work
If you are certain it is the switch, try looking on Ebay for a replacement switch.
Apr 16, 2014 | Karcher 1750 Psi Elec Pressure Washer
When turn on power fuse/breaker trips on power up
try to free the motor by turning it somehoe if its free replace running capacitor
Aug 16, 2013 | Karcher 1750 psi Electric Pressure Washer
When i operate the switch on my karcher pressure washer the power wash does not operate.
But water comes out the end right? just under hose pressure only I bet. I have one of these units and every time I think it has gone bad I manage to find the problem. This unit not only has the switch on the front that needs to be on but it also has a safety switch on the plug where it plugs into a wall or extension cord. The last time I thought mine had gone bad it had actually blown the fuse. the unit was plugged into an outside outlet via extension cord. It just so happens that that is an GFCI outlet. I think the wife got water on the extension cord and that caused it to blow. So check:
The power switch on the front The safety switch on the cord, The outlet it is plugged into
Usually, for us, it is the button on the cord when it is plugged into an extension cord it always gets the test button bumped which shuts it down.
Aug 22, 2010 | Karcher 1750 psi Electric Pressure Washer
1750 psi Electric Pressure Washer: My pressure washer is losing pressure and is pulsa...
I have d'same problem before. replace the head component with the 3 little cylinders,springs etc.. its a 1 piece part.
May 06, 2010 | Karcher 1750 psi Electric Pressure Washer
Pressuer washer not turning on
Inside machine are safety switches, you probably have a stuck on. Take apart, plug in and test with a tester to see where power is not getting to. I am guessing a safety switch is stuck.
May 02, 2010 | Karcher 1750 psi Electric Pressure Washer
Pressure Washer quit running
I have owned four of those units. Every one of them did what you are experiencing or just wouldn't give me any pressure after only a few uses. The company was certainly no help. I gave up after four and bought a heavier gas model from Lowes. Hope this info helps.
Jul 06, 2009 | Karcher 1750 psi Electric Pressure Washer
Need to lower 1750 psi to 300 psi on my portable power washer.
Don't starve the inlet to the pump. It will detroy it.
Buy a pressure regulating valve and plumb it in line per the instructions. Do not use a relief valve because you will have to have a return line or you will heat the water up on the inlet side of the pump depending on how the pressure washer is set up. It should already have a safety relief valve. You might look and also find a pressure regulator that is adjustable and all you problems will be solved.
Apr 24, 2009 | Garden
try running the machine without the hose attached if the machine runs ok then it is probable the there is a blockage in the nozzle if the the machine still cuts out then the pressure switch will probably be stuck or faulty this switch will be inline with the on/off switch and the motor it can be checked using a multi meter after dissconecting the power.
Oct 14, 2007 | Karcher 2500 PSI Pressure Washer
Snap-On 1750 PSI Electric Pressure Washer Logo
Top Snap-On Garden Experts
Dennis Key
Dennis Key
john h
Are you a Snap-On Garden Expert? Answer questions, earn points and help others
