Question about Fisher and Paykel IWL12 Top Load Washer
Fisher paykel ecosmart washer smells burnt
There is a smell like burning rubber or cat ***** coming from my washer
4 Suggested Answers
SOURCE: Fisher and Paykel Smart Drive burning mells
Try: http://usa.fisherpaykel.com/global/customer-care/trouble-shooting/washing-machines.cfm?CFID=5795181&CFTOKEN=46306735
Posted on Jan 15, 2007
TheMobilian
  • 8220 Answers
SOURCE: fisher pakel ecosmart washer rinse cycle into spin
Check for objects between tub and basket.
Posted on Mar 17, 2010
  • 389 Answers
SOURCE: Fisher Paykel ecosmart starts to drain for a few seconds then stops.
it could be you have somthing caught in your pump and your belt is sliping that will cause the burning smell take of your pump and check this is the first thing to try please let me know
Posted on Nov 11, 2011
Fisher and Paykel Ecosmart GW612 rinse cycles not working all other cycles working fine
Could be that your water pump is blocked. If you have a burning smell then you need a new water pump
Apr 04, 2014 | Fisher and Paykel Washing Machines
Fisher Paykel Intuitive Eco Washer IWL12 fault code 37
Pump Ohms to low will smell like burning enamal
The pump will need replacing,
Apr 06, 2013 | Fisher and Paykel Washing Machines
Fisher and paykel gwl15 wont completely drain
Also check the clear pressure tube for blockages,
Blow air down the pressure tube to remove any blockages
that would prevent water level from changing.
Jan 02, 2012 | Fisher Paykel EcoSmart GWL15
Nov 10, 2011 | Fisher and Paykel GWL11 Top Load Washer
My mw512nz started making a burning smell and wouldnt finish the cycle. i think it has stopped at the rinse. it definitly wont spin. i thought maybe its the water pump where the smell is coming from but...
That will be your waterpump, try popping the plastic cover off the coil on it and sniff the coil itself, you will most probably smell abit of the burnt smell you could smell earier. Also try measuring the ohms with a multimeter, should read somewhere around 33ohms give or take 5ohms depending on temperature.
Sep 18, 2011 | Fisher and Paykel Fisher & Paykel Washer
Burning Smell on Fisher and Paykel GW11 on spin and is not getting up to speed on spin cycle. Motor Bad?
Hi just read your posting.In my experience the only part on a Fisher and Paykel top loader machine that creates a burning smell is the pump.Try looking under the machine and you will see a black fan.This is your pump.Check to see if it has corrosion on it with a torch and try smelling it.I am sure you will find it is the pump that is smelling.Please reply for additional help and tell me how you got on with checking the pump.Looking forward to your reply.
May 14, 2011 | Fisher and Paykel GWL11 Top Load Washer
I have a fisher paykel GWL10 washing machine. It shuts off while
At this stage i can suggest that the inlet valve may be faulty & giving off this burning smell.open the control box & see if one of the 2 inlet valves look distorted or brown or burnt looking.I'm wondering if it's not filling very fast also,this could also be an indication of the valve.
Jun 03, 2010 | Fisher and Paykel Fisher & Paykel Washer
My washing machine stops mid cycle
issue where washer stops and water won't drain might mean something is in drain area.
look at my issue "eco smart won't drain, smells hot" and see about the sock. I found one of my husband's socks so far down in the tub bottom that I couldn't see it when I looked between plastic outer liner and wash tub. Had to remove black motor/white housing on bottom of machine--which i had to replace cause it burned out. That is when I saw the sock and pulled it out through a quarter-sized hole.
Jun 26, 2008 | Fisher Paykel EcoSmart GWL15
Oct 25, 2006 | Fisher and Paykel GWL11 Top Load Washer
Fisher and Paykel IWL12 Top Load Washer Logo
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
