Question about Fisher and Paykel 23 in. DD-603 Built-in Dishwasher
Dishdrawer lid actuator is not working
I ran the diagnostics on my Fisher and Paykel DD603 and determined that the left side lid actuator motor is not working on the bottom drawer. I've ordered a replacement. Is there any trick to replacing this piece? It appears to just snap onto the frame.
  • 552 Answers
SOURCE: I have a fisher & paykel dd603 double dish
Fisher Paykel dishwasher repair video, this video will walk you through repairing your dishwasher.
http://www.appliancerepairlesson.com
Posted on Feb 26, 2011
  • 125 Answers
SOURCE: Fisher& Paykel
Its under the bottom drawer dry out and re-assemble
Posted on Jan 12, 2008
  • 3 Answers
SOURCE: Fisher-Paykel DD603 DishDrawer shows F1
See also http://www.fixya.com/support/t346941-f1_error_1_draw_dishwasher
Posted on Nov 03, 2008
RescueTech
  • 145 Answers
SOURCE: blocked drainage hose in Fisher and Paykel top dishdrawer DD603
Hello there..
How do you know the hose is blocked at all? It's rare for that to happen, I work on these machines daily as I am a Factory Authorized tech. You need to be careful in your approach to this, that is an expensive machine and it can be damaged by improper service procedures.
For starters, there is a flap valve on the end of the drain hose that would prevent you from introducing any sort of pressure backwards into the machine via the drain hose. For example, if you took and tried to blow air thru the drain hose outlet end, you would force that flap closed and create pressure in the hose. Also putting caustic drain cleaning substances is very, very bad for your machine and can cause some serious damage.
I will be happy to try to assist you, but let's start at the begining, shall we? What prompted you to conclude that the drain hose is 90% blocked? The first thing you should do is take out the rack, wash arm and tha large stainless steel filter plate. Next, pull the rotor up and out of the pump base (none of these procedures require tools) and make sure the grey impeller is not "freewheeling" or has become detached from the rotor shaft. The blue wash impeller on the top and the grey drain impeller on the bottom must be "one to one" meaning they are firmly connected to the shaft of the motor and turn together.
Next, check the tube or passageway in the drawer between the sump (where that small removeable filter screen is) and the pump's sump area (where you pulled up the rotor)
If you have any blockage, it will be in that tube.
There is some glitch here where I do not get notified of response to questions, so I will check back to this post.
Posted on Dec 14, 2008
SOURCE: possible pump blocked
dishes have white film glasses are foggy
Posted on Feb 11, 2009
How do I move the actuators by hand on a Fisher and Paykel DD603 two drawer dishwasher
Lid motors should rectify themselves when power is restored. Once they have moved up then push the drawer back. If they don't rectify, you can disconnect the actuator from the side frame and rotate the actuator to wind it up.
Apr 28, 2016 | Fisher and Paykel Dishwashers
Fisher paykel dd24scx6 lid fault
This error is linked to the mechanisms that operate the lid seal of the drawer.
If the drawer feels hard when moving in and out, then the lid seal could be stuck in close position and the movement actuator motors may have lost power.
If there is no change in the situation after turning off the mains power and turning it back on, then there is a component failure linked to the lid seal.
Will need a technician to fix it if you are not very familiar with fixing electrical stuff. The lid seal actuator assembly is very complex. The easiest to fix is a failed power board under the drawer and the hardest is to replace the actuator motor if it has gone faulty.
Mar 27, 2013 | Fisher Paykel Fisher & Paykel DishDrawer...
Fisher Paykel DD603 Problem. Top drawer shows F1 and pump runs continuously. Lower drawer does nothing, no display. I think the Electronic Controller in lower drawer is fried and maybe the Mains Filter...
Yup, definately the bottom drawer controller, for some reason you can run a DD603 with no board in the top, so long as you have a board in the bottom, but not the other way around. This is the fault you get, constant F1 from the top drawer. If you are stuck try removing the display cable from the bottom controller, this may help, so long as you leave the chassis harness in.
Sep 26, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher & Paykel dishwasher:
Turn off dishwasher's circt braker at distribution panel (usaly located in garage or in basement)
1. Open lower drawer
2. Push in two plastic buttons at front lower corners.
3. Remove drawer from railing
4. Remove water from bottom of dishwasher
5. Use hair drier to dry off bottom copartment, specialy in left corner at floding switch location.
6. Install drawer on the rail in position when plastic buttons pup up
Mar 27, 2009 | Fisher and Paykel 23 in. DD-603 Built-in...
Lid is stuck in "down" position on the right only.
k the only thing you can do is try starting then stopping each drawer to see if the lid will go back up if not it will even be a hard one for the serviceman. you can't swap the wires like you've done it will cause large problems like a jammed lid sorry.
Mar 21, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Possible pump blocked
Jan 31, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher and Paykel DD603 service manual
Check to see if the Child lock is on...Check your email
Aug 28, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher and paykel leak
most likely the actuators are bad. with the unit off push and hold the lock and start buttons, lock first then start, after about 6 seconds the display will flash 188. press the power button, ho will be displayed. push the start button until Ld is displayed. open the drawer in question and push the lock button and watch the lid both sides should go down evenly, push the lock key to move it up and down as needed. push the power button to exit diagnostics. if you notice that the lid doesn't go down evenly or if one side stays up replace the actuators, they come as a pair. call a dealer/servicer to order actuators. make sure to specify top or bottom as there is a difference. hope this helps
Oct 03, 2007 | Fisher and Paykel 23 in. DD603H SS...
Fisher and Paykel 23 in. DD-603 Built-in Dishwasher Logo
500 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
