Question about Kohler Home
All buttons stuck in
My bath tub button is stuck inside and I can only shower, it wont release for the bath faucet. How to fix?
  • 171 Answers
SOURCE: Moen Bath Tub Faucet
Hi varn4620,
I'm Harvey the Master Plumber.
Your question is: You had to replace the faucet in the tub due to a broken plastic piece in valve stem. Bought a Moen ripped the wall out and put new faucet in. Went good untill we turned the water on and the shower rained on us. Tightened everything you could find to tighten .Every time the water is turned on the shower rains. Can this be fixed or is the faucet broken?
Is this new faudet a single handle? If so I"ve had this experience also. Most of the time it's because the guts were not lined up properly at the factory. You may have to play with it a bit.
Turn off the water and take the handle off and remove the sleave, remove and rotate the guts. Try 90' at a time. Turn water on to try it. Useually one of the other 3 positions will be right. The correct position is there, but it may take time to find it.
Feel free contact me again!
Please give me a rating here at fixya before you sign off
Thank you,
Harvey your Master Plumber
Posted on Sep 21, 2008
SOURCE: no water coming out of shower in master bath
I had a similar problem. Turned out to be simple to fix. Unscrew the shower head to see if water flows. Mine had a piece of solder stuck in it.
Posted on Jan 18, 2009
jj505
  • 195 Answers
SOURCE: kohler bath/shower diverter stem stuck on shower
Probably has water deposit minerals build up on it. Push and or pull with pliers until freely moves,soak in Lime away solvent ,toothbrush on.
Posted on Mar 16, 2009
  • 349 Answers
SOURCE: adjust the hot & cold water for delia monitor 1700
Remove handle and check to see if there is a dial to take out to repostion back in to adjust cold and hot water flow. take it out and move it a little put handle on and turn on see if it changes,
Posted on May 05, 2010
  • 37 Answers
SOURCE: water comes from both the shower head and bath tub
if it is standard shower where you pull the knob up when water is running. the pull knob lifts a flap to shut off water to bottom faucet it proably has some buildup on the flap clean well with some clr or other calcium cleaner like it so the flap gets a clean seal on downspout
Posted on May 10, 2010
Shower button came out
you can use piece of cloth over there
Nov 09, 2013 | Plumbing
I recently move into a condo that has a Delta single lever Series 1400 single lever bathtub fixture. The bathtub has a shower nozzle that looks like it has been used. I cannot find where there is a button,...
Is there a button on the tub filler? How about the spout on the tub, does it lift up? If there is not a tub spout then it should be shower only, if it has a tub spout it has to have a lifter of some sort, the foto I found showed the little button lifter. Hope this helps.
May 29, 2010 | Delta & Single Handle Shower Faucet
Water comes from both the shower head and bath tub faucet when bath is turnd on and wont turn off when shower is on
May 08, 2010 | Home
Shower/tub combo hot water problem
There is a restriction in the faucet or the piping to the faucet on the hot wtaer side...this will be very hard to find and fix... The shower uses less water so it will get hot.... the tub spout allows more water flow so you cannot get the water more then warm...
Take the faucet apart and blow out all the passage ways with air... also run some water from the piping while the guts are out of the faucet, to flush the piping...
Hopefully this will fix you up...
Heatman101
Mar 03, 2010 | Delta & Single Handle Shower Faucet
My bath tub faucet fills very slowly both hot and cold. All other faucets in the house have good water pressure. What could be the problem?
sounds like something stuck inside shower valve, piece of solder or something,...best to call a service guy to do this,....shouldn't be costly,....cracklin joe,......
Jan 05, 2010 | Moen & One Handle Tub & Shower Faucet
Kohler bath/shower diverter stem stuck on shower
Mar 14, 2009 | Kohler Plumbing
Leaky Faucet
You likely need to replace the Moen cartridge. There are clear instructions on how to proceed that come with the new cartridge.
Mar 14, 2009 | Moen & One Handle Tub & Shower Faucet
Moen Tub Faucet.. Water won't stop running.
change the washers first if that don't work change the inserts buy all at same time and return if not needed . Thank you for useing fixya please rate me
Feb 25, 2009 | Moen 2919 Chateau Two Handle Tub and...
Home Logo
Top Kohler Home Experts
Donni Steen
john h
Tim Whalen
Are you a Kohler Home Expert? Answer questions, earn points and help others
