Question about GE JVM1870 Microwave Oven
Not heating just will not heat
Everything working but no heat
Timer working but not heating - Microwave - iFixit
https://www.ifixit.com/Answers/.../Timer+working+but+not+heating
iFixitMy fridgadire microwave oven is not heating, it acts like it is heating by the timerworking and .... I have a GE Profile and everything worked but it would not heat.
Microwave Not Heating Troubleshooting Guide - YouTube
? 2:45
https://www.youtube.com/watch?v=_3SbJueEn1w
Aug 31, 2012 - Uploaded by Repair.com
If the water is not consistently warm, you've confirmed there's a problem. ..... Everything works except the microwave- it wontheat anything up. ... How to Fix a Microwave Oven - Simple Fuse Replacement - Duration: 18:04. by
Nov 28, 2015 | Electrolux E30SO75FPS 1000 Watts Microwave...
What material is usually used to transfer heat around central heating systems?
Water. Water is a good conductor of heat. The boiler heats the water, a pump circulates it around the system and through the radiators where it loses heat. Cooler water returns to the boiler for re-heating.
http://www.waermecenter.de/
Jun 16, 2015 | Microwave Ovens
The microwave is not heating the food.
When it did heat food before and you used the same settings now, the microwave must be defect.
But before you are sure, put a cup with water in the micro and try to heat that.
Dry food can't be heated in a microwave. There must be some moist in the food if you want to heat it in the microwave.
Mar 13, 2015 | Microwave Ovens
Oster microwave OM1101NOE wont heat carosel turns light is on time runs but not heat
There are three things to consider, the magnetron "heats food" high voltage diode "sometimes cracks" and the high voltage capacitor "sometimes shorts" one or more can cause the symptom of no heat. I recommend a professional to assess.
Mar 08, 2012 | Oster Microwave Ovens
Diswaher will not dry heating does not work
Check your heating element..
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The
Heating Element not Working
How to Replace the Dishwasher Heating Element
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Dec 05, 2010 | Microwave Ovens
I dont know how to use induction cooker.it has no numbers to reduce the heat.things will burn very fast
You can use to set the timing in order of the heat required. Also using the grade rating of the heating coupled with the time set, the food can be easily heated without burning.
To start with use low heat and long time, the try with medium heat and lesser time and then choose high heat and short time. You must be able to use the settings accordingg to your requirement.
Hope this advice helps
Aug 27, 2010 | Microwave Ovens
Dishwasher is running through cycles ok but water is not heating so only cold cycles.
Hi
The water is not heating as the heating element has gone bad or a fuse has blown which is preventing heating element to turn on. To check the heating element you'll need to turn off the dishwasher, unplug it. After unplugging it check the heating element formineral deposit on it, clean the deposits using a soft brush and a cleaning solution(Don't scrub the elemnt hard). If this doesn't resolves the issue then remove the panel and examine all the wirin connections to the heating element. Now, use a multimeter and check for the resistance reading(ohms, Rx1) for the heating element. The multimeter should display between 1200-1600 ohms or 1.2K ohms. If it is less than 1200 then you'll need to get the heating element replaced. Also, check for any blown fuse around the element. This should resolve your issue.
Thanks
Daniel
Aug 07, 2010 | Microwave Ovens
Doesnt heat up
in a microwave, there is no heating element. There are microwaves that heat up the water molecules, they make them spin fast and that's what heats things up. Running it with nothing in it, you really can tell if it's not working by that test either, again, nothing to heat up. I would put in a cup of water, set on high for 3 minutes and it should boil, if not, get a new one for the price, why mess around?
Mar 23, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
GH7145XFB-1 not heating properly
Generally, the most common causes of a failure to heat are:
- bad door switches or door switch mounts
- loose connection at the magnetron
- problem or loose conneciton on the control unit circuit board
- bad magnetron or other high voltage part
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
Nov 16, 2007 | Whirlpool GH7145XF Microwave Oven
GE JVM1870 Microwave Oven Logo
29 people viewed this question
Top GE Microwave Ovens Experts
D. E. Hev
 Larry
Larry
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
