Question about Broan-NuTone Kitchen Ranges
Leaking water water leaking down though the filter onto the stove below
    Problem Solver:
  • 17 Answers
Are you sure its water...does it have oil collector along filter...
or check for leakage from something from upper floor may be you have washroom or plumbing leakage
Posted on Aug 14, 2014
Leaking water onto counter
When my coffe maker does that I have found i needed to remove (if possible) and clean the coffee filter housing, mine has a spring loaded valve that lets you get a cup halfway though the perk and it had gotten plugged up with grounds, and was overflowing.
Just rinse it out top and bottom and you should be good.
If you cant remove it, be sure to unplug the electrical first :)
May 23, 2016 | Coffee Makers & Espresso Machines
Why is water leaking into cool (deli) drawer?
Hi,have you got a drain at the back of the fridge just above the veg draw,if yes is there eney food above that that is tuching the back wall of the fridge above the veg tray,if so then the water that runs down the back wall will be going onto the food that it tuches and into the veg draw,hope this was some help,all the best.
Sep 16, 2015 | Refrigerators
Where is the water filter on frs24wscb?
Good Afternoon Teresa,
I understand you want to know where the water filter is located on your Frigidaire refrigerator, model# FRS24WSCB. The water filter is located in the top back right-hand corner. To change filter follow the instructions below:
It is not necessary to turn the water supply off to change the filter.
1. Set ice maker lever (wire signal arm) to the OFF (up) position.
2. Hold filter cup firmly, and unscrew counter clockwise. (Some water could leak out as you remove cup. This is normal.) Filter cartridge should come down with cup. If cartridge remains in housing, pull down gently, while twisting filter back and forth.
3. Empty cup of any substance.
4. The large o-ring that seals the filter system sets in the o-ring groove down inside the cup. Should the o-ring fall out during filter cartridge replacement, simply place it back in the groove prior to screwing the cup back in place. If the o-ring becomes damaged, you will need to order a new one from the Consumer Assistance Center.
5. Discard old filter cartridge.
6. Remove new filter cartridge from packaging, and install.
7. Place filter cartridge in cup. The end with the small o-ring should be up, out of the cup.
8. Screw cup, with filter, back onto housing. Do Not Use Wrench To Reinstall Cup. Filter cartridge will self-align as cup is tightened. Be sure cup is completely tightened with PureSource Plus Logo facing outward. Do Not Tighten Past Stop.
9. Set ice maker level on the ON (down) position.
10. Check for leaks. Open refrigerator door. Wipe any water drops from the filter cup. Run a glass of water. If there is a leak, unscrew filter cup, and reinsert the filter cartridge. Check placement of large O-ring. Reinstall filter cup, making certain it is tightened completely.
11. To condition filter system and purge air from water line, run several glasses of water through water dispenser. This will also assure that the purest water possible is stored in water tank.
I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jul 01, 2014 | Frigidaire Refrigerators
Unit leaks after changing filter
I have one of these units, just replaced it last night. First off, determine where it's leaking. The filter cartridge is generally inside a cylindrical cup with a screw thread at the top. Leaks here would either be that the wall has a hole in it (replace the canister), the male threaded area has been damaged and is not round (replace the canister, the mating female thread is damaged or out of round (replace that part), or you're leaking through where the threads meet. (If the leak is not in this are, then the leak-fixing turns into generic plumbing - find out where the water if getting out. If it's hose, replace the segment, if it's a valve, replace the valve or valve seat.
Assuming it's the filter holder - check both thread faces for contaminants or grit. Some filters (like mine, fed with well water, come out covered in gack. If that gack- fine sand/silt from the water, gets in the threads, it can create a widening there on the thread that the screwing-in just spreads down the thread. In any case, clean both surfaces carefully with a clean, lint-free cloth.
After that, I've had great success wrapping a couple of circles of plumbers teflon tape onto the male thread of the filter holder. Get a roll of reasonably wide teflon plumbers tape and run it clockwise (looking down from above the cup) around the thread 2 or three times, keeping some tension on the tape, and then tension tearing the tape. Smooth it down, clockwise. Now mount the filter to the screw in point, and then carefully screw in the filter body. You wrap the tape this direction so that tightening the screw will tend to flow the outer end of the tape toward it's end, rather than back on itself. hand tighten, and then, when firm, tighten another quarter turn or so. The tape will do a great job of sealing the slightly larger gaps between the threads, and probably fixing the leak.
BTW, good pricing on the filters here: http://bit.ly/1Opkuh8 though back ordered at present, and here
http://bit.ly/1Rwg9q0
Good Luck!
Nov 24, 2013 | Franke Replacement Cartridge For Frxs2...
My Amana french door/bottom freezer is leaking water. Did the procedure with hot water the drain in back of the freezer, although it seemed clear of ice. That didn't help. The leaking stops when I...
Two possibilities:
1. A cracked plastic tube. These will leak whenever there's a call for water - either the chilled water dispenser, or re-filling the icemaker tray (two seperate tubes). Pay particular attention to anywhere the tubes are clamped to the chassis; anywhere they're routed near or under the refrigeration unit; and near the solenoid valve - especially if there's a tight loop in the tube there.
2. A bad (leaking) connection where one of the tubes exits the water valve. Again, these will leak whenever the valve is activated.
Those plastic tubes don't last forever. I've replaced many of them for the same symptoms. They're known to simply deteriorate with age.
Manuf's make good money selling replacement tubing kits.
Aug 15, 2011 | Amana AFB2534DE Bottom Freezer French Door...
Humidifier leaks water when turned on
Humidifier water pad comes w/ a mark in one end, that mark should be on top. Also check your feed tube they tend to crack some times. if if still leaks water change the water pad
Nov 14, 2008 | Aprilaire 550 Humidifier
Freezer leaking on Ge Profile
The drain is frozen over and water cannot escape when it defrosts. You will need to remove the back panel inside the freezer and run some hot water down the drain until it has thawed. Hope this helps
Sep 24, 2008 | Refrigerators
Cannot shut off the kitchen aid stove with the "Off" button, model # KESA907PSS01
i had the same problem with mine.. i overboiled some water and it leaked down the front onto my panel (inside).. i had to replace the whole thing.. (i did it so i added a silicone bead inside so water cannot get to that same panel area)..
3 years and it still works..
replacement panel is about 120.00 CAD
Jun 26, 2008 | KitchenAid KESC307 Electric Kitchen Range
Leaking on floor only after shuts down.
Griz, check the vent and see if you have bunch of gunk thats collecting water in it. Sometimes the spray arms are cracked and direct water into the vent. If this happens you will have leaking down the center of the door. Catriver...post back
Aug 14, 2006 | Kenmore 18 in. 14432 / 14439 Built-in...
Kitchen Ranges Logo
90 people viewed this question
Top Broan-NuTone Kitchen Ranges Experts
Dan Phillips
Level 1 Expert
Phil Lovisek
Phil Lovisek
Are you a Broan-NuTone Kitchen Range Expert? Answer questions, earn points and help others
