Question about Abbott Laboratories ABBOTT LABS ABBOTT Cell-Dyn 3200 CD 3200SL Hematology Analyzer W/ Monitor & Accessories Hematology Analyzer
MCV controls are out in all levels - Abbott Laboratories ABBOTT LABS ABBOTT Cell-Dyn 3200 CD 3200SL Hematology Analyzer W/ Monitor & Accessories Hematology Analyzer
My haemoglobin level is 54 how bad is that
I am not a physician, but am an amateur doctor. You should be talking to a real one. From what I have studied for you, your level is actually the percentage of red blood cells to the total volume of blood in your body. You are at the high end of the scale. I am not sure if that is good or bad which is why you need to ask your doctor.
The hematocrit measures the volume of red blood cells compared to the total blood volume (red blood cells and plasma). The normal hematocrit for men is 40 to 54%; for women it is 36 to 48%. This value can be determined directly by microhematocrit centrifugation or calculated indirectly. Automated cell counters calculate the hematocrit by multiplying the red cell number (in millions/mm3) by the mean cell volume (MCV, in femtoliters). When so assayed, it is subject to the vagaries inherent in obtaining an accurate measurement of the MCV
Male Hemoglobin and Hematocrit
Dec 01, 2016 | Miscellaneous
1982 Yamaha Virago 920ccj Looking for a diagram regarding vacuum line routing. Thank you
Hi, Rick what you really need is a service/owners manual sorry you can't find the first and best tool you ever bought for your Yamaha despair not for a mere $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
1982 Yamaha Virago 920 vacuum line routing Google Search
Yamaha XV920 1982 Virago MCV
1983 Yamaha XV500K Fuel Vacuum routing
http://www.startouringcroatia.net/manuali/VIRAGO/Yamaha_XV_V-Twins_81-94.pdf
May 08, 2016 | Yamaha Motorcycles
Thanks tim baker. A MCV is a mixture control valve on a 1999 hyundai accent but I cant find a maf sensor.
should be mounted on air filter housing or hose between a/f housing and throttle body
Sep 11, 2015 | Hyundai Cars & Trucks
Is a MAF sensor and a MCV the same thing
Im not sure what an MCV is did you mean a PCV? If so the answer is no the pcv valve is the Positive crankcase ventilation valve and is usually located in the valve cover and the MAF sensor is the Mass air flow which is located in the air intake tube they do 2 totally different functions.
I hope this helps
Sep 11, 2015 | Cars & Trucks
Wire a dakota digital model mcv-7000 to a 2005 kawasaki vn1600b
Is the mcv water tight? Do you have both wire schematics? If 'YES' go ahead, good luck.
Jul 25, 2015 | Cars & Trucks
856 farmall replaced mcv valve and pump. Everything works. But once up to operating temperature hydraulic warning light comes on. While driving if I press firmly on brakes the light goes out. What is...
not worked on a tractor before but principle must be the same as car,are the brake components in good condition as a worn brake lining/faulty brake servo could cause the hydralic fluid resevoir to suffer a back pressure that would make sensor light go off so i'd check the brake system and go from there
May 07, 2014 | Cars & Trucks
Sony Mavica MCV-CD 1000 Will not recognize a new disc.
some of the non-Sony mini-cd's will just not work. Get the real thing and this problem should go away.
Mar 03, 2008 | Sony Mavica MVC-CD1000 Digital Camera
Abbott Laboratories ABBOTT LABS ABBOTT Cell-Dyn 3200 CD 3200SL Hematology Analyzer W/ Monitor & Accessories Hematology Analyzer Logo
29 people viewed this question
Top Abbott Laboratories Science & Laboratory Experts
Gareth Cockram
Gareth Cockram
William McMath
ray gallant
Are you an Abbott Laboratories Science and Laboratory Expert? Answer questions, earn points and help others
