Question about Kenmore Dishwashers
Kenmore 655.16033401 clean light flashing - Kenmore Dishwashers
Clean light is flashing machine won't start
Hello & Welcome to FixYa
Flashing clean light is reset by pressing two buttons in sequence 3-4 times, to reset your kenmore press these buttons in sequence:
High temp wash-heated dry-high temp wash-heated dry
Please get back to me if you have any other questions.
Kevin
Dec 09, 2010 | Kenmore Dishwashers
66515919001 dishwasher doesn't finish washing. clean light flashes
The clean light is flashing due to a fault in heating the water properly. See the link below to reset the control so you can use the dishwasher and what might have caused it. Let me know if this was helpful.
Clean Light Flashing
May 28, 2010 | Kenmore Dishwashers
What is the sequence to reset our kenmore 16052
Hi
Thanks for using FixYa. If the clean light flashes, pauses, and then repeats. When the dishwasher doesn't sense a water temperature increase, it stops working and locks the functions (clean light flashes, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water.
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
May 26, 2010 | Kenmore 24 in. 16052 Built-in Dishwasher
Clean light flashing
Sorry you are having trouble, I put together a quick check list and instructions on how to reset the control. Let me know if this works for you, if not I can dig a bit deeper to help.
http://www.fixya.com/support/r4628906-flashing_or_blinking_green_clean_light_7
Apr 25, 2010 | Kenmore 24 in. 16293 Built-in Dishwasher
KENMORE ELITE DISHWASHER - MULTI-LIGHTS FLASHING
Look at your manual, usually available on net for reading or downloading. Blink lights are often used to code out a problem with various combinations and repetition rates to indicate trouble code number for look-up in manual.
Feb 22, 2009 | Kenmore Dishwashers
Light flashes remove filter and clean
did try kenmore website
sears has a great place for trouble shooting
Feb 06, 2009 | Kenmore KCM12 Coffee Maker
Kenmore dishwasher, model 665.170 344 01. "Clean" light keeps flashing and will not stop. Have tried everything in the manual and the light still will not stop flashing.
If the clean light flashes 7 times, pauses then repeats...
If the dishwasher doesn't sense a water temperature increase, it will stop working and lock the functions (clean light flashes 7 times, all buttons are non responsive).
-high temp wash
-heated dry
-high temp wash
-heated dry
...all the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cyle finish (1-2 minutes).
You should now be able to run the dishwasher as normal.
If the issue returns, you could have a problem with the heating circuit (ie. element, thermostat or wiring). It rarely happens but it could also be the door switch not engaging properly when the door is closed (slightly bend the door latch down making sure it doesn't hit the door when you close it).
Jul 18, 2008 | Kenmore 16602 / 16604 / 16609 Built-in...
Auto-off light keeps flashing
I have the same issue.  Any responses?
Jul 03, 2008 | Kenmore 54351 Dehumidifier
Dishwashers Logo
14 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
