Question about GARDENA Water Timer
I have a Gardena Water Timer T 1030 that won't stop beeping every 15 seconds. It does that when the battery is low. But I just installed a new battery, fresh out a package. I thought I may have put the battery in wrong, so reinstalled it. The beeping stopped for a few hours then started up again. Driving me crazy.
SOURCE: How do I program a Gardena Water Computer 1030
http://waterheatertimer.org/Gardena-1030-MANUAL.pdf
Gardena T1030 manual
Posted on Oct 12, 2010
SOURCE: My Gardena T 1030 D
1) I might have that manual in English:
http://waterheatertimer.org/pdf/Gardena-T1030.pdf
http://waterheatertimer.org/pdf/Gardena-T1030-MANUAL.pdf
2) If manual above doesn't work, I also used Google translate to translate Gardena manual; from Italian and German if I recall:
http://waterheatertimer.org/How-to-program-Gardena-C1060.html
You can enter whole sentences into google translate, and make sense of 70-80%.
I sometimes answer questions in Spanish at fixya using the translator. So we're not helpless any more.
3) Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, fixya expert speaks with you over phone while you work on timer.
Posted on Jan 10, 2011
SOURCE: A FRIEND GAVE ME A
Some Gardena manuals appear on following link, and additional manuals are posted as found:
http://waterheatertimer.org/How-to-program-Gardena-C1060.html#manuals
Also Google search "Gardena C1030 .pdf" or "Gardena C-1030 .pdf"
Be sure and add .pdf to search parameter to help isolate manuals from other internet posts
Gardena for some reason does not have manuals easily available as of today's date.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on Apr 14, 2011
SOURCE: Need an instruction manual for Gardena T 1030 D
Some Gardena manuals appear on following link:
Posted on May 13, 2011
Open following link for T1030 manual and Gardena links, including link to contact Gardena and link for parts.
http://waterheatertimer.org/images/Gardena-T1030D.jpg
I cannot find T1030D manual to help you solve the problem, other than suggest opening the cover using thumb-latch and change battery and clean the connections.
If you can scan your manual into pdf format and post it on your website, many folks would be happy to have a copy so fixya can help more folks solve Gardena problems.
Also add a comment and say what the manual says about the specific problem you are trying to solve.
Upvote the help.
And take advantage of fixya expert assistance live.
Posted on Jun 06, 2011
My gardena water timer won't stop bipping. See the picture. Is it the battery ?
for the Gardena-T-1030-1805 model....
Gardena 1030 1805 Operating Instructions Manual Page 7
11. Battery
11.1 Status indicator
If the battery capacity falls below a certain level, a warning signal sounds every 15 seconds. The programs you have set are not run. The water flow cannot be opened manually. If a valve is open, however, it will be closed.
11.2 Changing the battery
If the battery capacity is too low (the warning signal beeps every 15 seconds), you must change the battery.
To do this, the water timer must be removed from the tap.
Important : Changing the battery deletes the data you have set.
To change the battery :
1. Insert the battery in the battery compartment
2. Set the Run Time control knob
3. Reset the watering data as described in "Setting the watering data".
3 If the Run Time knob is not turned to Reset, 5 seconds after the
battery was inserted the current Run Time shall be accepted. This is confirmed by a double beep.
Note : The time the battery was changed is taken to be the starting time.
To ensure that the water timer works properly we recommend that you insert a new battery at the beginning of every gardening season, or at the latest after a year.
Important ! Please dispose of used batteries properly at the appropriate communal waste disposal site. Only dispose of batteries when flat.
May 28, 2016 | GARDENA Hardware & Accessories
Gardena C14e water timer won't start.
1) Copy following link to identify timer and download manual, to see if there is a reset protocol:
2) If functionality cannot be restored, buy another timer:
http://waterheatertimer.org/Woods-timers-and-manuals.html#sprinkler
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Feb 13, 2013 | GARDENA Hardware & Accessories
Need manual for gardena model T 1030 D i can only find T 1030 without D...!
I cannot find T1030D manual posted anywhere, Aug 2011.
The Gardena site does not return emails or post manuals.
You can try the following 'possible instructions' and then add a comment saying what you discover.
http://waterheatertimer.org/pdf/Instructions-for-setting-Gardena-T1030D.pdf
Aug 13, 2011 | GARDENA Water Timer
I do not have a manual and do not know how to set the timer correctly I have a gardena 1030
There are different 1030 gardena timers, and some gardena products have 3 different numbers, and sometime different timers have identical number.
Some Gardena manuals appear on following link with images of different products:
Jun 29, 2011 | GARDENA Water Timer
A FRIEND GAVE ME A GARDENA C 1030 plus WATER TIMER FOR MY GARDEN. I NEED URGENTLY A MANUAL THANK YOU
Apr 14, 2011 | GARDENA Water Timer
I have a Gardena WT 1030 water timer. The last battery is 10 months old and I have now replaced it as it is at my holiday home (very near to the sea) and we will not be back before April. The timer has...
I have Gardena 1030 manual
http://waterheatertimer.org/pdf/Gardena-1030-MANUAL.pdf
Jan 05, 2011 | GARDENA Water Timer
GARDENA  Water Timer Logo
928 people viewed this question
Top GARDENA Hardware & Accessories Experts
Gene Haynes
Tom Chichester
Bill Boyd
Are you a GARDENA Hardware and Accessory Expert? Answer questions, earn points and help others
