Question about Electrical Supplies
My pm0401850 coleman putting out 150 volts tried adjusting the screw which did help somewhat but does not handle a load very well any other suggestions
  • 98 Answers
Look...the screw you adjusted moves an arm which is connected to the scew-base by a spring...that arm has a nut that keeps it connected to a cylinder that goes into the engine...adjusting that arm will rase the rpm...that will make it produce more than 150 and it will automatically adjust itself with the load...
adjusting can be done by twisting that cylinder very slowly to the right direction....twist it a tiny bit and then tighten the nut and turn it on...if it got even lower then twist it to the opposite direction..and so on..
Posted on Oct 27, 2009
My just purchased/well used Coleman i/c 4000 generator puts out about 150 volts, no load, instead of 120v.The owners manual does not indicate how to adjust it; it says it is factory adjusted. It may have...
Probably running too fast. You can slow it down by adjusting a screw behind or near the carburetor. Monitor the voltage while doing this. The adjustment screw will be one which moves a lever with a spring attached to it.
here is a thread on it:
http://www.perr.com/forum/viewtopic.php?p=8748
Hope this helps Tim
Mar 12, 2011 | Garden
What type of oil do I use 1850 pm0401850
Oil Type. Use new good quality oil such as SC, SD, and
SE grades. The oil to be used depends upon the temperature
at which the engine is operated:
Summer: (temperatures of over 40 degrees F/10 degrees
C) SAE 30 or SAE 10W-30, SAE 10W-40
Winter: (temperatures of below 40 degrees F/10 degrees
C) SAE 20 or SAE 10W-30
Manual here:
http://www.powermate.com/pdfs/2007/11/12/pm0401850-52.pdf
Sep 12, 2010 | Coleman Powermate Powermate 5000W...
Oil capacity and weight of oil
If it comes with a Briggs & Stratton 3.5 HP series 93400 engine, then the oil capacity is 20 fl oz (0.59 L). Hope this helps!
Sep 20, 2009 | Coleman Powermate Powermate 5000W...
Voltage is high around 150 volts. I reduced the
The speed will change the 'frequency' too. You need to make sure you still have 60 Hz. You may have need a voltage regulator adjustment, not a speed adjustment.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Aug 01, 2009 | Coleman Powermate Powermate 5000W...
To many output volts
Jun 18, 2009 | Electrical Supplies
Need manual for coleman powermate 1850 generator
google it! use the specific search terms, Coleman power pulse 1850 - it worked for me!
Jun 05, 2009 | Coleman 10' X 10' Sundome Tent 9160K101
Three year old coleman 5000/6250 generator. High
Your RPM's are too high. There is no voltage regulator in coleman generators (generator is actually made by generac) and is 100% dependent on engine speed. There is a screw under the tank when your looking in from the recoil side. It controls the governor arm. Screw it in and it incresses the rpm, out decrease. Plug something in that draws a decent load while setting the rpms since you want it to put out 120 and 240 underload. Your idle voltage does not matter.
Apr 01, 2009 | Coleman Powermate Powermate 5000W...
Coleman 5000 generator will not idle up under load
Hi
You have to find the governor linkage.There is a spring adjusting by a screw to increese speed to get more power.Try to locate it.
best regards savumihai71
Feb 03, 2009 | Coleman Powermate Powermate 5000W...
Electrical Supplies Logo
183 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
