Question about GE (PSS26MSRSS) Side by Side Refrigerator
The waters going in the ice maker and it is makeing cubes but it does no dump in bin
  • 72 Answers
Sounds like you need a new ice maker
Posted on Jun 19, 2009
My ice maker inst working Whirlpoo; model gz25fsrxyy2
By "ice maker isn't working" do you mean it isn't filling with water, it isn't freezing the water in the ice maker, it isn't dumping the ice cubes into the bin, or it isn't dispensing ice cubes?
Was it previously working and it is not working now?
Typically one can hear the valve when it opens to fill the ice maker with water. Can you hear it attempting to do so? If so, and there isn't any water in the ice tray, check that there is water supplied to the valve at the wall and the valve is open. Is there a water filter? Has it been replaced per the manufacturer's recommendation? (Typically, the water filter should be replaced every six months.)
Is the "full" bar pushed up? It shouldn't be. The bar above the ice cubes should not be in the horizontal position. That position tells the ice maker the bin is full so it should wait until the bar goes down, indicating some ice has been used.
Can you hear the bayonet turning? Is the ice maker attempting to dump out cubes whether or not they exist? The next issue after you confirm there is water going into the ice maker that is being frozen and the ice maker knows to dump the ice, is the bayonet. There is a motor that turns the bayonet and a mechanical connection. Either could be at fault.
Jan 22, 2018 | Refrigerators
Freezer won't make ice cubes, but does provide cold water.
The water and ice maker are two seperate water control valves built onto the same. Your water control valve for the ice maker may be defective and require that you change the set. Fill ice maker with tap water and allow the water to freeze. If the ice maker dumps the ice into ice bin and then does not refill then this points to the water control valve. If the ice maker does nothing after water freezes then the problem is the ice maker. Send me a model number and I will look up the part numbers for you, Thanks, Sea Breeze
Jul 08, 2012 | Frigidaire Refrigerators
Ice maker not pushing out cubed ice makes funny sound also has a chlorine taste even after changing the water filter
The ice cubes may have melted somewhat and are sticking to the bottom of the ice bin.
Take the ice bin out and dump the ice. Wash and DRY the bin. Put it back in and wait for more ice to make,then try your dispenser.
Let us know the outcome.
Dec 01, 2009 | GE Refrigerators
Ice maker is making ice but not dropping into bin. i can dump in myself and it re fills water, but the cubes just stay in the maker and wont alow the next batch to be made.
Your trouble can be in the icemaker. An internal thermostat closes to begin the ice harvest cycle. A motor drives the ejector blades, and a heater releases the cubes from the mold. None of this will happen if the electronic sender and receiver are faulty. This device is to stop the ice production when the bin is full. How are you manually dumping ise into the bin?
Nov 04, 2009 | KitchenAid Superba Architect KSCS25INSS...
Ice maker not dispensing ice
If the dispensor light switches to cubed or crushed , the panel is good . Remove the ice bin , and hold the light switch in . Press the arm for CRUSHED ice , and if you hear a buzzing or hum , then the auger motor is frozen . Use a hair dryer directly on the " forks " for a while , ocasionally holding switch and activating arm , until the forks move . Lower the freezer temp slightly and reinstall the ice bin .
Aug 11, 2009 | GE Profile Arctica 25.4 Cubic Feet...
Frozen slabs of ice instead of ice cubes
the icemaker could be leaking by can you see where the water is coming down into the bin from??
Jan 23, 2008 | GALAXY Microsystems 55622
Ice maker not dumping ice
Make sure the freezer is at least 17 degrees or colder (colder is better). If you have a square cover on the end of the ice maker see if you can pull it off and press on the gear face (don't turn just press). That may clean the electrical contact springs and get it working again. Basically if ya got water, 17 degrees or colder you will get ice. Other than that the ice maker motor module is likely bad (broken gear, etc.). Pretty common.
Aug 17, 2006 | Frigidaire FRS26KF5C Side by Side...
GE (PSS26MSRSS) Side by Side Refrigerator Logo
66 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
