Question about Sabrent ECNU25K Hard Drive Enclosure 25 SATA to USB 20 Black Serial ATA USB USB 20 Drive Case
How do I allocate my Sabrent HD - Sabrent ECNU25K Hard Drive Enclosure 25 SATA to USB 20 Black Serial ATA USB USB 20 Drive Case
Driver included with sabrent tv-pcidg will not install on windows 7
Driver included with sabrent tv-pcidg will not Problem with the Sabrent TV Tuner / Video Capture Box USB 2.0 with Remote Control driver included with sabrent tv-pcidg will not install on windows 7
Oct 12, 2011 | Sabrent TV Tuner / Video Capture Box USB...
Hi i m using gateway nv55c03u. its using intel hd graphic.I know its integrated. is there anyway i can allocate more ram to the graphic card?or is it possible i cn put another card in?
if tehre is an ability to allocate more memory that feature would be in the BIOS otherwise you will have to stick with what you have
Jun 05, 2011 | Computers & Internet
Usb emp audio device cannot start code 10 error message appears in device manager. also usb device does not show up for a device when I launch video studio
Hi lynnembryant,
Your problem seems to be related to the driver your capture card uses. I would recommend updating them.
Here are the links:
For Windows XP, Vista and 7 32 bits : http://sabrent.com/drivers2/USB-AVCPT-32bit-XP-Vista-Win7.zip
For Windows Vista and 7 64 bits : http://sabrent.com/drivers2/USB-AVCPT-64bit-Vista-Win7.zip
You seem to need another driver as well for the audio, here it is : http://sabrent.com/drivers2/USB-AVCPT-USB-EPM-286x.zip
You might also want to check their support website here : http://sabrent.com/support/.
Cheers!
Mar 01, 2011 | Sabrent USB-AVCPT Video Capture
Is it compatible with window7
yes , it is compatible. Some peripherals may need an additional driver from the manufacturer website. Sabrent in this case. Here is the list of the latest drivers from Sabrent: <br /><br />http://sabrent.com/drivers.php<br /><br />Hope this helps:)<br /><br />
Aug 26, 2010 | Sabrent TV Tuner / Video Capture Box USB...
Windows Media Center can't detect a TV signal from a Sabrent card
If you have hd card, it might be your cable company not providing hd signal. If you have analog card, and have HD signal that will cause it too.
Nov 30, 2009 | Sabrent TV-PCIRC (TVPCIRC) Video Capture
Sabrent TV-BOX USB2.0 Windows Vista x64
Try this website
Both vista and windows 2000///XP are located on here
Click here
Oct 23, 2008 | Sabrent TV Tuner / Video Capture Box USB...
Sabrent 5 in 1 adapter usb-dsc5
Gateway hard drive need to be "slave"
usb need to be inserted before turning on the PC.
Oct 05, 2008 | Sabrent Computers & Internet
Computer doesn't see hd
hi, re: sabrent enclosure:
sort of same issues. documentation is feeble. hd powers up. red light is on.
but the new pc doesn't recognize the drive and, obvously doesn't assign a
drive letter to it.
i tried reversing the cable, changing the hard drive, using different usb port,
re-booting. still doesn't see the drive.
1. jumper settings are correct
2 i use vista, not win 2000 or xp
2 harddrive is old, from old computer
vista doesn't have 'my computer'
i can find manage disk management
can't right click becausse the drive isn't there
how do i change the hdd settings from dynamic to basic if i can't see the drive?
answers to your questions":
1. i'm running windows vista home
2 size of drive... it's old and probably fat(32) under 1g
3 i cycled through the settings
j8 jumper settings
slave, master, & single
no settings work
4. yes i heard the drive spin up
5 the led is red, not green
thx again for your efforts
ken bossewitch
kb@bossewitch.net
Dec 03, 2007 | Sabrent (USB-2535) (USB2535) IDE...
Sabrent ECNU25K Hard Drive Enclosure  25 SATA to USB 20 Black Serial ATA USB USB 20 Drive Case Logo
66 people viewed this question
Top Sabrent Computers & Internet Experts
Martin Murray
WTF Chuck.....
WTF Chuck.....
Colin Stickland
Colin Stickland
Are you a Sabrent Computer and Internet Expert? Answer questions, earn points and help others
