Question about Magellan RoadMate 2200T GPS Receiver
How can i delete an address book categories in gps 2145T
Delete an address book categories in gps 2145T
I need to know how to delete addresses that I do not need anymore on my Magellan RoadMate 1440
Here is a video that explains hoe to add, edit, AND DELETE address book entries in a Magellan Roadmate. The delete process is in the last minute or so if you don't want to view the entire process.
How do add edit and delete address book entries Video Demonstration
Oct 27, 2016 | Magellan GPS
I would like to delete one or more addresses without disturbing the rest. How? How can I edit an address?
I don't think you can delete the Address Book on the iQue, because the program resides in the iQue's ROM. Any programs that reside in ROM cannot be deleted.
Sep 16, 2008 | Garmin GPS
I need a user manual for a MagellanRoadmate 2145T-LM
You can find your manual and software updates online. CLICK HERE
Jun 03, 2012 | Magellan GPS
Hi, I have entered my new address into my Nuvi 1300 but my old address is still there. How do I delete my old address as well as other addresses I no longer need. Thank you Denise
There are two ways to do this. If you want to delete the address from showing up in the unit when accessing the "Recently Found" locations, simply go to "Recently Found" and select "Clear" from the bottom menu. If you want to delete the saved address from the "Favorites," go to the Home Screen and select "Where to?" Then select the category where you favorite is located (may not show categories if you have none). Now select the old address from the list and select "delete," and then confirm.
Apr 17, 2011 | Garmin nuvi 1300 Car GPS Receiver
HOW DO I DELETE ADRESSES FROM BINATONE G350 SAT NAV
You can only delete the Recent Destinations and destinations in the Address Book, the Sat Nav will still store destinations you have entered and as new ones are entered the older ones will fall off the system when maximum is reached.
Apr 03, 2011 | Toymax Binatone Carrera X350 Car GPS...
How do I remove old address from my Tomtom Xl
please tell me how to delete address from the tomtom system
May 27, 2009 | Tomtom ONE XL GPS
Can't open the phonebook of my motorola e398
Motorola E398/Razr address book disappears/bounces:--Solution
press 1+# (i.e. speed dial #1)
press Menu -> Categories -> Select -> All
Bingo. U r now in the Address Book --delete all entries which have no names against names or add some name.
Dec 11, 2008 | Motorola Mobility E398 Cellular Phone
Address book
That's easy just goto your address book
2.press the menu button
3.select filter
4.press the menu button again
5.and select uncheck filter'
thats should make your contacts reapear
Jan 22, 2008 | RIM BlackBerry Pearl 8100
Magellan Roadmate 700
J...
at the user menu press the "-" zoom out key the "+" zoom in key and the repeat button which is on top of your unit. Once your in the "hidden" menu, select reset user data.. your unit will reset and everything will be clean. If your trying to delete specific addresses I would use software to sync up and explore your MRM's files.
- If needed please ask more questions prior to rating -
Nov 03, 2007 | Magellan RoadMate 700 GPS Receiver
Magellan RoadMate 2200T GPS Receiver Logo
Top Magellan GPS Experts
Jungle Ghost
Jungle Ghost
Are you a Magellan GPS Expert? Answer questions, earn points and help others
