Question about Broan-NuTone Kitchen Ranges
Water coming out exhaust - Broan-NuTone Kitchen Ranges
Missing an water coming out the exhaust pipe
Some water coming out the exhaust is normal. If there is more water than usual it could be an indication of water in the fuel. Adding a product such as Heet can help to get rid of the water and I would recommend fueling your car at a different gas station. A leaking head gasket may also be the culprit. Coolant leaking into the engine will be partially burned but will also produce water out the exhaust. Check your coolant level. If it is low this may be the problem.
Hope this helps
Bob
Dec 16, 2014 | Cars & Trucks
Water is not coming out my exhaust
reverse flush it were the water should come out put the hose in there.
Nov 06, 2013 | Yamaha Waverunner Xl 700 Xl 760 Xl 1200...
Water is steaming from the exhaust while engine is running
Water coming from a exhaust is normal. The newer the car, the more emission control it has at protecting the environment and the more water you will see.
Remember that the combustion of hydrocarbon fuel produces both carbon dioxide AND water vapor as a normal part of the process. All gasoline engines produce water vapor and all water vapor condenses if the exhaust pipe is cool.
Apr 08, 2013 | 1999 GMC Yukon
Temp gauge shot up to max, grey smoke out of exhaust, never boiled up,car tried to run but lumpy, now no water in rad but oil is normal, filler bottle cap wont screw back on,, peugeot 405
sounds like blown head gasket (through exhaust port) fill with water and start up, look under car, and see if water is coming out of the exhaust pipe)note: if head gasket is blown thru exhaust port you won't have water in the oil. it will come out of the exhaust. if this is the case then possibly can fix with (k&w block sealer or comparable block sealer) since no water in oil engine should be fine.) but follow directions to a T on block sealer if you don't it could stop up the radiator and you'd be back in the same position. also make sure you fix problem that caused it, probably bad thermostat or water pump.
Aug 27, 2012 | Peugeot 405 Cars & Trucks
Hi i have a bmw 728i 1997 when i start the car water comes out from both exhausts even when i rev the car more water comes out. i want to know what the problem is thank you
thats normal, its just condensation in the exhaust from your emission systems working.
Now if it is green water, you have a problem on your hands. does the exhaust have a sweet smell? might be coolant in your exhaust from....
May 12, 2011 | BMW 7 Series 95-98
Water is coming out from my tail exhaust pipe Ford Expedition 2003 4X4
When gasoline is burnt the products are carbon dioxide and water:- 2C8H18 (gasoline) + 25O2 (air) ----------> 18H2O (water) + 16CO2 (carbon dioxide) If you take short trips the water content will condense in the cold exhaust pipe and collect in the muffler boxes (silencers). At a certain point the water will fill the mufflers, overflow and begin to dribble out of the exhaust tail pipe. It is worthwhile to occasionally give your car a longer run to allow the exhaust to become sufficiently hot and to evaporate all the collected water. The water is acidic and hastens the corrosion of the exhaust pipes.
Dec 06, 2010 | Ford Expedition Cars & Trucks
Water coming out the exhaust
Water out of the exhaust is a natural by product of the catalytic process that occurs in your converter. A lot of water coming out the exhaust is NOT normal and indicates a possible head gasket problem.Watch you engine temperature gauge for overheating.The only way to know 100% is to have a mechanic pressure test your cooling system. Good Luck
Oct 22, 2010 | 1996 Buick Park Avenue
Water cooling of exhaust
If its a newer model Mercury the Relief exhaust port does not receive water at an idle, all the cooling water is discharged through the Propeller hub exhaust and Tattletale.
Sep 20, 2009 | Boating
Water from exhaust
some water is normal but if you are loosing coolant, running hot or if water from exhaust smells like antifreeze you have a problem (head gasket or cracked head)
Jun 17, 2009 | 1991 Honda Accord
Kitchen Ranges Logo
65 people viewed this question
Top Broan-NuTone Kitchen Ranges Experts
Dan Phillips
Level 1 Expert
Phil Lovisek
Phil Lovisek
Are you a Broan-NuTone Kitchen Range Expert? Answer questions, earn points and help others
