Question about KitchenAid Kc010050b-1 Stainless Steel Toaster Oven
Kitchen aid KC010050b-1
Fuse
2 Suggested Answers
SOURCE: need fuse party number and supplier for KitchenAid
i tried that and they didn't have it..anywhere else I could find it?
Posted on May 01, 2013
Breville bov800xl wont turn on. Reset option?.
If the screen turns on and looks like it's working but there is no heat, then the problem is the thermal fuse. It takes reassembly and a $5 replacement fuse. I replaced mine with one of the same specifications and it lasted a month. I replaced it again with one that trips at a 10 degrees higher setting and it's been good for a couple of years now.
Feb 25, 2015 | Breville BOV800XL 1800 Watts Toaster Oven...
No Heat; Controls, LED work fine
I have the same toaster oven and it developed the same problem.
There is a thermal fuse with a 172C trip point. I replaced it with a new part and it worked fine for another week. I replaced it again with a fuse with a 192C trip point and that's been working for a couple of months now. Some pointers for replacing the fuse.
1) you need a Philips screwdriver with an 11" (30cm) shaft to get at the screws behind the control panel.
2) you only need to take off the feet and open the right side (looking at the toaster from the front).
3) The thermal fuse is in a white flexible plastic tube, held in place with a metal bracket.
4) You can pull the old fuse from the wire clamp using 2 pairs of plyers. I re-used the same clamps to connect the new fuse to the existing wires.
5) Replacement fuses can be found on EBAY for about $1.50 (includes shipping from Hong Kong)
Feb 06, 2014 | Breville BOV800XL 1800 Watts Toaster Oven...
Display will not come on oster TSSTTVDFL1 toaster oven dead how to reset it?
I found one of these on the curb. Took it home, and it was completely dead as you described. Took it apart, and there's a thermal fuse mounted above the convection fan that had blown. According to the data sheet, the fuse blows at 240C, but even if it never sees that temperature it will still fail eventually if exposed to high enough temperatures. The fuse is mounted against the chamber where it will get hot, so basically these ovens are designed to have a finite lifetime.
Anyway, long story short, you can buy replacement fuses online for a few bucks. It's a SEFUSE SF240E. Or just bypass the fuse. Keep in mind that the fuse is a safety feature that will kill the oven if it overheats, so keep that in mind if you decide to bypass it.
Jan 01, 2013 | Oster Toaster Ovens
My Breville BOV800XL doesn't have any power.
My BOV800XL did the same thing. Of the three parts you mention the thermal fuse is by far the easiest to test and in my opinion the most likely to go out first. Check it with a meter. If you have trouble locating it read the FixYa solution for "The Breville BOV650XL will not power on." Check it for continuity like you would any fuse.
I found replacement parts at ereplacementparts.com. The thermal fuse assembly was $23 when I checked. Or you could just replace the actual fuse portion of the assembly with a comporable fuse such as http://www.mcmelectronics.com/product/NTE8213. Basically you need a 216*C thermal fuse. These can be had for less than $2 plus shipping. Buy a few just in case.
I just ordered my fuses today so I can't report on the success of my repair, but I am confident the new fuse will solve the problem.
Aug 30, 2012 | Breville BOV800XL 1800 Watts Toaster Oven...
Problem with the T-Fal Avant Elite OT806552/4YA-4804 Toaster Oven. Oven won't come on at all, how do I get the cover off to check it out? Is there a fuse or breaker that I can replace. Thx. -mahen
I have the same toaster and the fuse burnt out a couple of days ago. Its a 10 Amp fuse behind the control panel under a white cover. You will need to remove the right side of the oven to see it. I've not found a replacement fuse yet. Let me know if you find one.
Mar 20, 2011 | T-Fal Avant Elite OT8085002 Toaster Oven...
3 yr old Bravetti Plat. Pro microwave/convection does not heat food. Lights, turntable work. Is there a fuse somewhere that is blown???
in 90 % of my microwave is damaged the magnetron, on the electronic plate you have 2 fuses and dawn under the rear fan you have another fuse(glass fuse) in a plastic cover.
Feb 21, 2010 | Euro-Pro EP278 Bravetti Platinum 1500...
Microwave will not heat.everything else is working.is there a fuse?
There is a fuse, it is a high voltage fuse. If this has blown there is a problem in the high voltage circuits
Feb 16, 2010 | Toaster Ovens
No broiler heat
its not a diode its a fuse a high temp fuse . there is a number on it with a "c" after it thats the temp it opens ..... you can jump it out with a small bare wire just to test your elements and thermostat . if the thermostat does not cycle this fuse will blow . do not leave it jumped out , this is just for testing . find one on line with the number . and high temp fuse ... good luck
Feb 05, 2009 | GE 168947 Toaster Oven with Convection...
Fused plug
If it is a moulded plug you will need to chop it off and wire on a standard 3 pin plug(if you are qualifiedor capable of doing so ) If its in guarantee though do not do this. There must be a reason it blew the fuse. If in guarantee get it repaired under the terms of the guarantee.
Oct 22, 2008 | Krups FBC112 1600 Watts Toaster Oven with...
KitchenAid Kc010050b-1 Stainless Steel Toaster Oven Logo
67 people viewed this question
Top KitchenAid Toaster Ovens Experts
Think Crucial
Think Crucial
Tom Chichester
Are you a KitchenAid Toaster Oven Expert? Answer questions, earn points and help others
