Question about Krups 300 Watts 418 PowerMix Pro Stand Mixer
I can't remove bowl from stand. How do I remove it? Bought it 2nd hand and no manual.
I have ordered 3 cooks professional stand mixers for myself, my daughter and daughter in law and none of us am remove the mixing bowl - can you help?
On the right hand side of the unit there is a lever..lift the lever upwards and tilt back the head.
Then hold the bowl with both hands and twist to the left to remove the bowl.
Hope this helps you.
Dec 17, 2016 | Food Mixers
Kitchen aid stand mixer blades do not reach bottom of bowl
go to youtube type in ajustment on kitchen aids and it will show u step by step hope this helps
Sep 28, 2012 | KitchenAid KSM5PS Heavy Duty Stand Mixer
My Sunbeam mixmaster bowl won't turn, how can I fix this?
I believe that this particular model is supposed to have the bowl mix separately. I have removed the black piece from the bottom of the larger bowl in order to allow manual spinning. If I am able to figure out how to fix the bowl spinner I will make another post.
Mar 06, 2011 | Sunbeam 2346 Heritage MixMaster Series...
Bowl broke. where can I get a new one?
try the retailer where you bought it, get online and find their site and see if you can order a replacement bowl.
may not be cheap! if you really are attached to your mixer, and it was expensive, then may be worth the cost! not many expensive, high quality mixers offer 'cheap' parts replacements. research it, and decide for yourself!
good luck!
Oct 17, 2009 | Bravetti 35-396 Power Hand/Stand Mixer
I have a Hobart N50 and am in need of a SS bowl. The bowl pins are 8 7/8" apart. Do they make a replacement bowl for this? I've seen the ones that have 9" bowl pins. Thanks, Ron
can buy hobart bowls from lots of places, or use the correctly shaped kitchenaid ones, both fit.. i like the lip and thickness of the hobart bowls, bought mine from globe equip.. do u still have the service manual, if so i would be real intrested in it, please
Jun 14, 2009 | Hobart N50 Stand Mixer
KitchenAid K5 Mixer Bowl Rocks Back & Forth
This may be explained with the bowl assembly. Being a bowl lift mixer, please follow the following steps to make sure the bowl is being secured before mixing:
There are the bowl-holding arms on the left and right hand side of the mixer. You will place the bowl on these arms, securing it onto the pegs.
Also, take your fingertips and press down firmly at the back of the bowl where it is resting against the base. You will hear an audible click as the bowl secures down into a spring latch mechanism on the stand mixer base, allowing the mixing bowl to sit flush and secure.
May 03, 2009 | KitchenAid K5AWH Stand Mixer
How to remove bwl from base
Should just be able to push down lightly and turn.
Jan 18, 2009 | Bravetti 35-396 Power Hand/Stand Mixer
Instructions for Sunbeam 2350 Heritage Series Mixmaster
Go to sunbeam.com, select "kitchen", then select "customer service", then "instruction manual", then "stand mixers", scroll down to model #
Nov 23, 2008 | Sunbeam 2350 Heritage Series Mixer
I just got a new Kitcheaid Artisan 5 qt stand mixer. i can't get the bowl off of the stand. seems like its too tight, and i can't budge it. is there something i can do?!?!?
These bowls can tighten during mixing. One solution is to fill it with ice while trying to unscrew it. Soaking the base with soap is another solution. In the worst case, the bowl and the cap it fits in are replaceable.
I have had to use a homemade strap wrench on others. Be careful not to warp the bowl out of round, or it will be un-usable.
Oct 22, 2008 | KitchenAid KSM150PS Artisan Series Stand...
Bowl Lift
Same problem here, went from working perfectly to mix cookie, now I can barely move it...help!
Dec 31, 2007 | KitchenAid KT2651X Epicurean Stand Mixer
Krups 300 Watts 418 PowerMix Pro Stand Mixer Logo
23 people viewed this question
Top Krups Food Mixers Experts
Oscar Netto
Oscar Netto
Are you a Krups Food Mixer Expert? Answer questions, earn points and help others
