Question about Brinkmann Smoke 'n Grill Double-Grill Charcoal 810-5301-C
Gaps in top of smoker - Brinkmann Smoke 'n Grill Double-Grill Charcoal 810-5301-C
Weber grand cafe heat
Some tips here
Weber com Support Help Grilling Tips
You can ask them for manual
Weber com Support Manuals
Some tips for smpking
Top Ten Tips for Smoking
The Best Setup for a Weber Smokey Mountain Barbecue Smoker and Other Bullet Shaped Charcoal Smokers
amazingribs com
Watch this video
Weber Grills Smoking on Your Smoker
May 24, 2015 | Weber Grilling
Where can I find the Owners Manual for a Outer Electric Smoker?
I could not find a manual for your Outer's Smoker however, most electric smokers are preset to have a heat output between 225*-250*. The smoker should have a smoke box that sits on top of the heating element. Preheat your smoker by plugging it in, then add wood chips to the box with your food on the racks.
There is a great blog that has a forum dealing specifically with smokers (with a section on electric smokers):
http://www.smokingmeatforums.com/f/
or
http://www.smokingmeatforums.com/f/110/electric-smokers
Good Luck!
Jul 14, 2014 | Grilling
My grill has a side stove and I had left the top open on a rainy day. Now when I turn it on the flames shoots out in the gap under the stovetop. What can I do?
I would think the burner is blocked and the gas is lighting off the injector , clean the burner , or replace it , it sounds like it is blocked .
Jan 27, 2012 | Uniflame Grilling
My smoker does not smoke at 220 degrees it did fine in colder weather
Either the heating element or the controller on top of the smoker has failed. This is a chronic problem with Masterbuilt electric smokers. That's probably the reason it on has a 90 day warranty.
You can purchase the part(s) from Masterbuilt or from Factory Appliance Parts
http://www.appliancefactoryparts.com/search/partinfo.php?partsID=491507&modelsID=135884&typeName=gas%20grill
Hope this helps you & thanks for choosing FixYa.
Sep 11, 2011 | Masterbuilt 20070106 Electric Smoker
The lid does not seat squarely on the base. There is a 3/16'' gap on the hinge side. Plus the lid is offset back a bit so that it is not square on the base.
They dont always fit perfectly, To have it fit as good as possible,
put lid in down position loosen bands slightly manipulate bands to allow lid weight to close gap then retigthen bands in this position now when closed lid should sit fairly squarely on base
Sep 10, 2011 | Big Green Egg Extra Large - XLHD...
Have a PF-27G, erroneously shipped to Hawaii with connection for Nat gas. Replaced orifices and electrodes to convert. Having problem with igniter not sparking and technician here told me to get the...
If you can light the burners manualy then recheck gap distance on electrodes and on igniter. If gap is to close or to fare this will cause a problem.
Nov 14, 2009 | ProFire PF27G Grill
Brinkman electric smoker
The pan for the wood chips is a round shallow (1/2 or so high) pan, about 8 inches in diameter, that sits right on top of the heating element. The element doesn't get too terribly hot, so you could probably substitute a foil pie plate or even a double wrapped package of aluminum foil with some holes punched in the top. When you see the smoke - its time for the meat!
Good eats!
Pat
Jun 29, 2008 | Brinkmann Smoke' n Grill Electric Double...
Burner adjustment
HE PART YOU REFER TO IS THE BAFFLE, TURN IT UNTIL YOU GET A BLUE FLAME
Mar 08, 2008 | Kenmore 632 sq. in. 16324
Char-broil water smoker
first, a charcoal fire in bottom tray, then a pan filled with hot (boiled) water above it, then the meat on top tray, then keep lid on a long time (hours) without peeking and remember to keep charcoal topped off. you should also soak hardwood hickory sticks in water for a day or 2 and wrap in aluminum foil with small holes punched through and place on top of charcoal to provide smoke. usually a large chicken is done in about 4 hours.
Oct 12, 2007 | Char-Broil Charcoal Water Smoker 4654301
Brinkmann Smoke 'n Grill Double-Grill Charcoal 810-5301-C Logo
23 people viewed this question
Top Brinkmann Grilling Experts
paulcarew
Dan Webster
Dan Webster
Lyle Siemens
Lyle Siemens
Are you a Brinkmann Grilling Expert? Answer questions, earn points and help others
