Question about Hunter 27185 Remote Control
Changing 5 pin remote with four pin remote
Bought a new one, to replace hunter 27185, new remote has four pins and the hunter fan has five pins how do I make it work?
SOURCE: trouble with hunter remote 27185
The problem is most likely a interruption in power. I just e-mailed Hunter asking if I could stop this from happening since my fan is over the bed. Their reply is as follows... The light will come on after power is restored following an interruption. This is a design feature of the remote control and cannot be modified or adjusted. We apologize for the inconvenience.
If you have further questions, please phone us toll free at 888-830-1326. Our hours are from 7:00am-7:00pm (central) on weekdays and 8:00am-5:00pm on Saturdays. Any representative can assist you.
Posted on Jan 13, 2009
SOURCE: Hunter remote Model 27185. Light
There is no fused protection in the receiver -- I just had the same problem.  When replacing a bulb, somehow the bulb arced in the socket on the fan and blew out the unit.  Time to replace the unit.  I may put an inline fuse this time for protection.
Posted on Mar 14, 2009
  • 4 Answers
SOURCE: Hunter Remote Control # 27185
Do not use the factory default position in either fan. Double check the dip switches, and make sure they are the same for each individual receiver and remote.Different codes for each. Dip switches are the oppsite direction in the remote for some reason?
Posted on Mar 31, 2009
SOURCE: No dip switch in Hunter 27157 remote control.
Those aren't transistors in the transmitter they are jumpers. Match the jumper settings with your dip switch settings in the receiver. You can move the jumpers in the transmitter using a small needle nose pliers. An open jumper in the transmitter equals an OFF setting on the dip switch in the receiver.
Posted on Jul 16, 2009
snakehead
  • 1074 Answers
SOURCE: light won't work on hunter fan with wireless remote
probably your lights are blown replace them.good luck.
Posted on Feb 28, 2010
Hunter fan 27185 has lost speed
Remote controlled ceiling fans can suffer a lapse of memory when there is a power outage. You eliminated the possibility of a dead battery in the remote by installing a new battery, but just to be sure remove the new battery and press all the buttons on the remote to eliminate the possibility of a stuck button then reinstall the battery. Next disconnect power to the fan at the breaker box, not a wall switch or by tugging on a chain. Turn the fan power on again. Using only the remote, check operation.
Apr 20, 2013 | Hunter Dryers
Hunter model 27185-060 remote problems
1) clean the contacts batteries 2) change the new batteries 3)resolder the wires contacts batteries 4) open the remote, and clean the keypads with special spray very well, 5) resoldert any colder joints for better contacts 6) reset the code again and proof 7) otherwise you must go to the repair shop TV, or replace by new ones.
God bless you
Jun 19, 2012 | Hunter 27185 Remote Control
I have a Hunter fan with remote and the light flickers without coming on completely - and you can hear a clicking noise coming from the fan. The fan works and the bulbs and batteries were changed
The pins inside the remote could have been switched or the wiring inside the fan could have come loose. Check the wiring at the fan first. The vibrations of the fan could have worked the light conrol wire loose.
Oct 10, 2010 | Hunter 27185 Remote Control
Jun 24, 2009 | Hunter 27185 Remote Control
Hunter fan/light with remote installed turns on by itself
Many times this is caused by stray frequencies in the neighborhood. And, sometimes changing the frequencies on the remote and receiver reduce the occurrence.
But it sounds like this may not be the case, here. If not, the receiver in the fan is the culprit and should be replaced. No danger, just annoying.
Apr 01, 2009 | Hunter 52" Ceiling Fan With Light And...
Trouble with hunter remote 27185
Dec 06, 2008 | Hunter 27185 Remote Control
Jan 01, 2008 | Hunter 27185 Remote Control
Televison & Video Logo
41 people viewed this question
Top Hunter Televison & Video Experts
pblo
Level 1 Expert
Paul Bade
Jim Goldsmith
Jim Goldsmith
Are you a Hunter Televison and Video Expert? Answer questions, earn points and help others
