Question about Dell 3100MP Multimedia Projector
Dell 3100MP just powers off
I have a Dell 3100MP that will randomly power off while in use. Sometimes it's right after I turn it on, other times it's an hour plus into my presentation.
The only way I have found to resolve it is to unplug it from the power strip and plug it back in. Sometimes I even have to put it in a different slot on the power strip. The PC is plugged into the same strip, yet never goes down.
Any suggestions would be helpful.
  • dashrender Jun 19, 2009
    Thanks for the fast reply. I used a can of compressed air and blew out the fans, but they were really clean already, and no dust came out while I cleaned.
    The PC is on the floor and the projector is on top of the table, so the heat from the PC should not effect it. The unit is very warm, I'd say hot. Though I know this is common on these devices. I powered it up and it shut off less than 5 mins after I started using it. I tried turning it back on using the power button, but nothing happened. I had to pull the power from the surge bar and plug it back in (same socket) and it then fired back up.
    Do you think there is any chance that a going bad bulb could be the cause? Or is more likely that the unit is 5+ yrs old and just getting worn out? That really would not surprise me. As hot as it gets, then cooling down.. repeatedly that just kills electronics.
    Dell has suggested that I have a hardware problem with the Projector. and they suggest that I call it in for repair.
  • 674 Answers
Check the heating of your laptop. it more heat chek your fan or cfu fan, if work properly.. shuting down is a lot of cause. over heating, fan not work properly case over heating... processor.. or board..
Posted on Jun 19, 2009
  • 1 more comment
  • Alexander Calidguid
    Alexander Calidguid Jun 19, 2009
    try to use collera fan for support your pc.. or to minimix the warm of you pac.. this is good for laptop if its became heat... coller fan for laptop
    or use electric fan when you are using..
    if this free , its okay but sometime they asking the payment its up to you.. i know that has problem from the hardwre. if that is under warranty must better bring to warranty... they are responsible to fix the problem
Casio - 120 Turns itself off randomly
Casio CDP has Auto Power Off: 30 minutes after last key operation, Auto Power Off can be disabled.
Please read the manual.
Jan 06, 2014 | Casio Music
Power supply fuse
HI,
Do you need to know the rating of fuse used in the power supply. Or do you mean that Power supply is not working.
Jan 04, 2013 | Dell 3100MP Multimedia Projector
I have a Dell Inspiron E1705 that seizes up.
sounds like your hard drive is about to take a dump or cpu is not cooling good and she is over heating mite get a can of air and blow your fan area out mite be stopped up by some dust try this and see if it helps....
Dec 10, 2009 | Dell Inspiron E1705 Notebook
TV Turns Off Automatically While Watching
Stop trying to turn on the set. You are causing more damage. The hissing sound you are hearing is either a High Voltage Transformer on the SMPS (Switched Mode Power Supply) indicating a short somewhere in the set or some capicitors that have shorted out. Also there can be a CRT that is leaking cooling fluid onto the Main bd or the Power/Deflection bd or both bds. Have a trained Samsung tech troubleshoot the set.
Jul 15, 2009 | Samsung HCM4215W 42" Rear Projection...
Dell Inspiron 1501 random freeze
If you can take the unit apart, check the LVDS cable from the mother board to the Formatter/T-con assy. a good cleaning with alcohol should work.
May 08, 2009 | Dell Inspiron 1501 Notebook
Dell 3100MP Projector - No Signal Check Cable
Make sure you have the right input source selected. It may be looking for a signal from some input other than the one you're connected to. Beyond that, if it truly isn't seeing the input then you'll need to have the projector serviced.
Dec 17, 2008 | Dell 3100MP Multimedia Projector
Power shuts off randomly
Sounds like you have a bad connection somewhere. pull the radio out and check your power and ground connections to ensure that they are tight.
Nov 17, 2008 | Alpine CDA-9857 CD Player
Random shutdown
The power supply would have been my 2nd option too. It can build up quite a bit of dust which gets very hot inside and overheats. Good thing power supplies are cheap. I assume since you cleaned the heatsink area that your fan is working and plugged in. A bigger fan might be needed too.
Oct 28, 2007 | Dell Dimension 8400 PC Desktop
Problems with dell 4600
Try to open it in safe mode. If it opens and don't reboot then right click on my computer->click on properties->click on Advanced Tab->setup and recovery framework click on settings->in system failure framework remove checked from Automatically restart.
Oct 23, 2007 | Dell Dimension 4600 PC Desktop
Dell 3100MP Multimedia Projector Logo
539 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
