Question about Rheem Professional Spiderfire 100 Gallon Sealed-Combustion Natural Gas-Fired Commercial Water Heater
Blower and Air Flow Proving Switch - Rheem Professional Spiderfire 100 Gallon Sealed-Combustion Natural Gas-Fired Commercial Water Heater
Aircondition builds ice on coil
Either lack of refrigerant, stopped up metering device or capillary tube/s, or lack of air flow (due to bad blower motor, or dirty indoor coil) Good luck.
May 19, 2014 | Rheem Complete Split System Gas Furnace 5...
Richmond power vent 2 flashes code 4-4
Sounds like a pressure switch or simular sensing device that is not proving positive, thus a possible vent blockage or defective sensing device.
Mar 05, 2013 | Water Heaters
GX90-715A wont stay fired
1) Product manual has burner info page 11, maintenance 12, and troubleshoot flow charts starting page 17
Otherwise, Rheem does not post service manuals.
http://bostonheatingsupply.com/Rheem/Rheem%20Commerical%20Gas/Rheem_CommGas_Extreme_Use%20and%20Care%20Manual.pdf
2) Post question on pro water heater forum.
http://www.thetankatwaterheaterrescue.com/forums/forum3/
3) Is air intake clear? Is the burner sooted? Is the flame large and clear blue? Is the vent obstructed? Does air draft when blower activates?
Feb 14, 2013 | Rheem RUUD GX90-715A Water Heater,gas,90...
Richmond water heater goes into lockout condition, ignition failure and I have to turn the blower switch off then on to get the water heater to work. Its getting to be a everyday thing. Also would like to...
Start-point is to inspect and clean burner parts and combustion chamber, clean air intake, bleed air out of gas line, test gas pressure, test electronic gas control valve, check for venting issues.
As general rule, gas water heater manuals recommend professional service once a year that would cover most items listed above.
To see images, and for more reading and resources, look at your product manual and open following link:
http://waterheatertimer.org/How-to-install-gas-water-heater.html#clean
Richmond/Rheem sells power vent blower assembly that cost about $300.
Your product manual shows part numbers.
http://www.monstermarketplace.com/heating-supplies/rheem-sp12562-blower-assembly-powervent-2
Replacement gas control valve costs $300
Aug 16, 2011 | Audiovox Richmond 6G40-36F 6-Year Tall Gas...
Pilot light won't stay on, and water not being heated. Is it because of the magnetic valve not staying open allowing gas to flow through?
hi
could be gas valve. check that the fan and pump run.if not could be an air flow switch.
hopes this guides you the wright way
Dec 29, 2010 | Bosch & Tankless LP Hot Water Heater
I haye a power vent hot water heater that wont light . the fan continues to run what could be wrong
The problem is probably in the pressure switch. The switch is usually a round thing with a hose or two going to it.
You must figure out though if the vent is blocked or if the switch is bad. Check the vent outside to make sure that air is coming out. If no air or little air is coming out of the vent then your vent may be blocked and the pressure switch is keeping the burner from coming on because of that. If air flow is okay then the switch is probably bad. Replace the pressure switch.
heatman101
Mar 26, 2010 | Water Heaters
Noisy water heater blower
There really is no way to do this. If you put a cap you will restrict the air flow which will cause you to have problems with the water heater, same thing if you where to put screen on it. You can try enlarging the pipe to a 3 inch and see if that works. But 15 years in the trade nothing has been made to reduce the noise
Jun 01, 2009 | Fasco Bradford White Hot Water Heater...
Where do install a Heil furnace filter?
MAYBE IT DOES NEED IF THE FILTER IN THE COLD AIR RETURN GRILL MAKE SURE THEIR IS NO FILTER IN THIS FIRST , AS 2 FILTERS ARE NOT BETTER THAN ONE WHEN COME TO ELECTRIC FURN AND H/P ALSO IS THIS A UP-FLOW ,DOWN FLOW OR HORZ MEANING AIR #1 RTN IN BOTTOM DISCHARGE COMING OUT OF TOP OR#2 COLD AIR COMING IN TOP AND DISCHARGE OUT OF BOTTOM OR #3FURNACE LAYING SIDE-WAYS AIR COMING IN ONE END AND OUT OTHER THESE WOULD DETERMINE FILTER LOCATIONS
Nov 19, 2008 | Water Heaters
Rheem Professional Spiderfire 100 Gallon Sealed-Combustion Natural Gas-Fired Commercial Water Heater Logo
37 people viewed this question
Top Rheem Water Heaters Experts
Donni Steen
gizmonix
Level 1 Expert
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
