Question about Fujitsu Siemens AMILO Pro V2010 Notebook
The cursor jumps somewhere else on the screen as I am typing causing me to stop typing and put the cursor back at the end of the text which I am writing. If I don't spot it straight away it can mean I have typed a few words in the wrong place. When this happens continously it is very irritating not to mention time consuming in having to delete words and move the cursor back to where it should be. Any ideas anyone?
    Sergeant:
  • 361 Answers
GO run type control then click mouse. there is four option button,pointer.pointeroption.hardwere, i think point optiom option may be change . reset it.
Posted on Jun 19, 2009
  • 334 Answers
Chances are you are either taping the mouse pad or if you have one of those glide sticks in your keyboard, its probably that. If you right click on the mosepad icon in the bottom right tool bar (by the clock) click properties and in there you should be able to disable the glide stick and also disable the mousepad if it senses a usb mouse is being used. Let me know what you find out.
How do I stop the cursor from jumping around while I'm typing
Click on the "Start" icon in the lower left corner of the screen. Select "Control Panel." Next select "Mouse" under "Hardware and Sound." You can also left-click the touchpad while the cursor is anywhere on the desktop For more Call us +1-800-204-4427 USA toll-free number
Jun 22, 2017 | Acer Aspire 5740-5255 - 18531
Cursor and text jumps for dell inspiron 1150
Click the Windows "Start" button or press the "Windows" key. The "Start" menu opens. Type "Cursor blink" in the "Search programs and file" text box. A list opens. Click "Change Cursor Blink Rate." The "Keyboard Properties" window opens. Click the "Speed" tab. A list of options appears. The "Cursor Blink Rate" section shows a "Cursor Blink Rate" slider displaying a range from "None" to "Fast." Click and drag the slider button to the "None" area in the far left portion of the "Cursor Blink Rate" scale. Click "Apply." Click "OK." The cursor stops flickering on the screen.
Feb 04, 2013 | Dell Inspiron Computers & Internet
On my laptop, the cursor jumps unpredictably to previously entered text.
The space bar 'contacts', internally are dirty or defective. You will probably need to replace the keyboard or seek from manufacturer a 'cleaning process ' for this keyboard.
Mar 03, 2012 | Computers & Internet
While typing a line of text , I will look at text only to discover that it has jumped back and start typing somewhere in the text. It happens so much that I have to type with only my fingers touching the...
I have had exactly the same problem with most laptops I have used in the last 5 years, Compaq, Dell and HP.
what is happening is simple. as you are typing you are inadvertantly skimming the touchpad or the cursor buttons with the base of your thumb - well thats what I was doing - and moving the cursor.
I got an external keyboard & mouse - worked for me!
if there is a setting in the BIOS that enables you to turn OFF the touchpad and / or keyboard cursor buttons when an external KB / MOUSE is connected then enable it otherwise your problem will still continue.
Unfortunately, if youre using the laptop away from base, or there isnt such an option in the bios you basically just have to be more careful!
Nov 28, 2010 | Acer Aspire 5315 Notebook
Cursor keeps jumping back in text when typing. This results in over typing things already typed. Not sure if this is me or a problem with my new laptop ?
This is either caused by a remaining flea power on the laptop.
Try draining the flea power first:
1. Remove the battery and ac adapter
2. Press and hold the power button for at least 10sec.
3. Put back the battery and ac adapter
4. Turn on the computer
open a notepad, or any microsoft office and check if the cursor keeps jumping. If yes, try updating the touchpad driver / BIOS update.
Hope this helps.
Mar 22, 2010 | Computers & Internet
Jumping cursor whilst typing on an acer aspire 5315
Is the touchpad active?
It is common that users accidently touches the touchpad while writing and this causes the cursor to "jump"...
Another possibility is that the "TAB" key is jammed...
May 05, 2009 | Computers & Internet
Cursor skipping and jumping back into previously typed text
Have a D600 myself and found anothe post that worked for me!
First, my problem was replying to emails the cursor would jump when typing usually back up into the middle of the text somewhere.
If this is similar, read on.
First, go to Dell's website, downlaod the latest driver for the Alps Touchpad: http://support.dell.com/support/downloads/download.aspx?c=us&l=en&s=gen&releaseid=R113813&SystemID=LAT_PNT_PM_D600&servicetag=&os=WW1&osl=en&deviceid=2514&devlib=0&typecnt=0&vercnt=7&catid=-1&impid=-1&formatcnt=1&libid=17&fileid=149404
Download the driver but do not install yet. Note, this is for a Dell Latitude D600, Windows XP. Vista may have a different driver.
Open Control Panel/Mouse/TouchPad Tab/Touch Sensitivity Button. Open Touch Sensitivity, adjust below the halfway point on the slider. Try different settings, you may also want to check the "Tap off when typing" box.
If you do not show these properties as above, you probably don't have the latest driver installed. In that case, install the driver you downloaded above then come back and refer to the instructions.
I spend 90% of my day on this D600 and really love it, not a speed demon, but light enought to carry with one hand and is a great email/browser machine as you probably already know!
Before installing tis driver
Apr 04, 2009 | Dell Latitude D600 Notebook
While typing an email the cursor will jump back a few sentences
I recently acquired this problem after having my computer serviced. I have been using it for over a year with no difficulty. I read somewhere that this is a microsoft problem, one of their service packages. The question is, which one?
Nov 16, 2008 | Toshiba Tecra M2V-S310 Notebook
Jumping cursor when typing
Since you have a logitech mouse, lets just disable the touchpad. You should be able to disable the touchpad via one of these methods:
  1. Look on the top row of keys. You should have one that looks like a little mouse. If you do, hold down the "fn" key in the bottom, and press the key with the mouse on it. That *should* disable the touchpad.
  2. Go to the control panel, and find the keyboard and mouse settings. Digging through the menus, you should find a touchpad. You can disable it through there.
Steven
Sep 17, 2008 | Microsoft Windows Vista Ultimate Edition
Cursor skips lines while typing
My experience: cursor suddenly moving backward when i was typing, or moving somewhere else on the page. I would be typing and text suddenly would get highlighted. I followed someone's advice to disable the touch pad. Since I do have a mouse & key pad that was all i had to do.
HOW TO DISABLE THE TOUCHPAD FOR ACER 3680 AND OTHERS??? PRESS Fn +F7
Yep, it was that simple. At first I made sure i typed without my fingers or palms touching or near the touchpad. I noticed it seemed to stop or happen less. Soon as I disabled the touch pad all is back to normal. Yet I spent hrs trying to find out how and there were all these posts by people suggesting downloads and other more complicated things etc..
May 12, 2007 | Acer NSK8458AN Keyboard
Fujitsu Siemens AMILO Pro V2010 Notebook Logo
373 people viewed this question
Top Fujitsu Siemens Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you a Fujitsu Siemens Computer and Internet Expert? Answer questions, earn points and help others
