Question about Samsung RF265ABBP (25.8 cu. ft.) Bottom Freezer French Door Refrigerator
Samsung rf265abbp error code pc
Refrigerator light off, control panel off, fridge not working, er and PC on the panel
SOURCE: control panel not working Samsung refrigerator
I have a samsung refrigertor rs2555sl and my control panel stopped working after I turned the power off to the house (to install a light fixture elsewhere). There was one green light blinking on the refrigerator temp display.
Hold down the "power freeze" and "power cool" buttons at the same time for at least 8 seconds. This is a self diagnostic program. A number should appear on the refrigerator temp display (1-9)...it will hold for 30 seconds and then the panel should function again.
In my case the number that appeared was "3" which can indicate a multitude of things including a short circuit or power outage (which was it was for me).
Hope this helps!
Posted on Jul 26, 2009
  • 3 Answers
SOURCE: error codes for Samsung Fridge
does anyone know what error code 3 is? Have the same problem, wont cool on fridge side freezer side is fine...
Posted on Mar 01, 2010
kel1guy2002
  • 3740 Answers
SOURCE: I have a Samsung RF4287HARS.
Pc code is saying there was a momentary power loss. Try resetting the control panel by depressing power frig and power freeze for more than 8 seconds. You may have to unplug the unit for 20 minutes if the compressor it very hot and not starting. You may have to depress power frig and power freeze to reset the units control panel to restart the compressor after the 20 min let the cooling system stabilize period.
If after all of this you still have issues with the lights or the unit is not working properly just repsond here and we will help you.
Thanks for Choosing FixYa. Kelly
Posted on Sep 29, 2010
  • 9 Answers
SOURCE: i got a samsung refrigerator model rs2534ww
Sounds like you just need to do a reset, press and hold the top 2 buttons till it flashes then let go. If you hold it to long it will run a diagnostic mode and may lock up on the blinking light again. The blinking light is a trouble indicator for the service tech. It tells them that sensor or heater is faulty or will point them in the right direction. I found a repair manual on the online auction place E b a y that can help you troubleshoot further but have not bought it as of yet. I just purchased my Samsung and was reading some reviews to see what kind of problems i may run in to.
Posted on Jan 29, 2011
ZJLimited
  • 17970 Answers
SOURCE: I have a samsun fridge
"PC-ER" its a error in the PCB (computer).
Samsung says that... if the code "PC-ER" appears on the display panel or if you cannot resolve the issue, the refrigerator needs to be repaired. Contact a Samsung service technician.
Hope this helps.
Posted on Jun 09, 2011
The code ER CO keeps coming on, on the display panel. The fridge and freezer still work but the code keeps coming up. Any info on that?
LG Bottom Freezer Refrigerator Error Codes Sears PartsDirect
Select
Use our model number finder
Choose your product type
Common model number plates
Close
LG Refrigerator Error Codes
These error code explanations can help you diagnose a problem with your LG bottom-freezer refrigerator. For repair how-to help, visit the PartsDirect repair help section, which includes repair help for washing machines, other major appliances, lawn and garden equipment, garage door openers, vacuum cleaners and more. You can also search for owner's manuals, get advice from an expert and find refrigerator replacement parts. Error Code
Er FS Error Code
Er rS Error Code
F dS Error Code
r dS Error Code
Er HS Error Code
Er IS Error Code
Er SS Error Code
Er rt Error Code
Er It Error Code
Er gF Error Code Error Code
r dH Error Code
Er IF Error Code
Er FF Error Code
Er CF Condition
Condenser fan motor is defective Check/Repair
Condenser fan motor, wiring or the control board Shop Parts
Condenser fan motor, Power control board, Wiring harness Error Code
Er CO Condition
Communication error Check/Repair
Communication error between main board and display board Shop Parts
Display control board, Power control board, Wiring harness
Jul 16, 2015 | LG LFX25974ST 24.7 cu. ft. French Door...
Pc Er Error code
Jim, Pc Er is a Communication circuit failure on main board or
Communication circuit failure on control panel board
Could be a loose or corroded connection, a bad mother board or a bad display board. Before doing anything, unplug the refrigerator for 5 min and plug it back in. This may reset the motherboard. If not, check the comm cable at the display and the motherboard. if ok, then you will need to replace either the motherboard or the display board. There is no way of determining which one to replace.
Apr 10, 2014 | GE (PSS26MSRSS) Side by Side Refrigerator
Error codes Er rF
Hello, you have to down load the LG smart refrigerator app.
once you do this then you open the right door of the Refrigerator then press lock on the fridges control panel.... Turn on your smart app and place near the top right of the fridge with the door still open, you will hear a series of beeps and then your phone will tell you what the Diagnose is for the error code.
Nov 14, 2013 | LG LFX31925ST 31CuFt French Door...
I have a samsun fridge and the code pc er came on and the light is not working nor the temp why????
Hope this helps.
Jun 09, 2011 | Samsung Refrigerators
Have a LG 3 door bottom freezer with error code Er dH. Was told by tech support to unplug for 10 mins. If this fails unit needs service. Is this correct?
dh means defrost problem.replace defrost control and element,behind freezer panel.dont forget to unplug fridge before you work on it
Nov 17, 2009 | LG LRBC22544 Bottom Freezer Refrigerator
LG Bottom freezer refrigerator Model LFC21760 does not cool
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages
Sep 28, 2009 | Refrigerators
GE side by side refrigerator model GSH25KGREWW
You said that the control board on rear of your refrigerator was replaced and there is still nothing happening? You do need to check the power behind the refrigerator to make sure there is power, yes.When did the control board get replaced and was it new?. Sea Breeze.
May 28, 2009 | GE GSH25KGRWW Side by Side Refrigerator
Unable to adjust the temperatures on the control panel
Turns out that unplugging the fridge and then plugging it back in reset the control panel. But, the technician at Sears suggested that we still have someone come out to take a look. Apparently, this is a very common problem with our type of refrigerator, and it's either the freezer fan or the control panel itself that is malfunctioning. He said this will undoubtedly happen again, so as soon as the parts come in, we will be scheduling a service appointment. Thankfully, our fridge is still under warranty.
Thanks for your response, and I hope this is helpful to others experiencing the same problems.
Mar 22, 2009 | Kenmore Refrigerators
Freezer cold/fridge warm
You have a defrost issue and needs to be serviced by a qualified LG technician.  The freezer fan motor is blocked by a large chunk of ice behind the rear panel of the freezer section.  You will need to remove the rear panel to get access to the fan and get rid of the ice.  This will get your refrigerator working again but this problem will return.  You will need to have your control board replaced.
May 10, 2008 | LG LRFD25850 French Door Refrigerator
Fan in the freezer stop working ater a while
You may have a serious issue with the wiring harness inside the refrigerator.  You will need to have the technician come back out and check the continuity of the wires leading from the control board to the fan checked out.  If there is no continuity, it is not repairable.
Mar 13, 2008 | LG LRSC21935 Side by Side Refrigerator
Samsung RF265ABBP (25.8 cu. ft.) Bottom Freezer French Door Refrigerator Logo
50 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
