Question about Dell W2606C 26 in. HD-Ready LCD Television
Where to plug antena on prima dnx pixelworks - Dell W2606C 26 in. HD-Ready LCD Television
My screen on my kenwood dnx 6990hd says (DC OFFSET ERROR) What does thay mean
Basically that means there is an overload or some form of power issue with the machine.
The best thing to do is reset the unit to start with. Do you have the manual?
ELECTREPAIRUSA@ELECTREPAIRUSA.COM
Dec 28, 2016 | Kenwood Knob Dnx-6980 Dnx-6180 Dnx-6190hd...
The picture looks like it's moving in slow motion...
Ur tv incomming broadcasting tv channels signals are pick up and using are Free over the AIR broadcasting tv channels pick up are by a Antena signal wright?Not signals by a pay cables or satalites tvs incomming broadcasting input signals?Yes?This tv causes are low and weak ranges of a tv Antena incomming recieving broadcasting tv channels signal.Buy a better design Antena like a Digital Antena and used it will solved this problems.Plug it in ur Digital Antena and rescan ur Free over the AIR broadcasting tv channels again.
Aug 15, 2011 | TruTech PVS31170S1W 17 in. LCD Television
The picture on my prima tv(HDMI,dnx pixelworks) is no longer working,the sound works.
Is this an lcd or plasma flat panel? Or is it a dlp or crt projection tv? What is the make and model of your tv. I need this information to download a manual. Please get back to me with this info so that I can help. Thank you,
Apr 04, 2011 | Televison & Video
My monitor will not come on, it only states going to sleep, what can i do
It's a connection issue. Check that monitor and cpu are properly connected. Also check for faulty cables.
Jun 04, 2010 | PC Mall Pixelworks Cluster System...
TV not coming on
You need a Tech to look at this issue. Too many PCB;s that could cause problem. Also for your info., Prima is no longer in business.
Dec 30, 2009 | Prima Televison & Video
Trying to install channels on goodmans ld1962d. Not sure what active antenna is. No channels are found when we have aerial in or out.
check for antena cable plug condition, normaly 80% of low quality of antena signal, is conection on antena plug (inside)
1st open antena plug, check for condition/connection of cable.
2nd check for each part of cable well connected, and no wires crossed on middle cable
3rd check same to the other end of cable.
4rd check the signal on diferent tvs around house (if available)
if this general you dont have aerial signal in your house, check for your TV provider (cable) to test your arial signal.(Normaly this maybe a cable broken outside house).
Nov 22, 2009 | Televison & Video
I have Kenwood DNX 7100. I plugged my car charger
how do i put my kenwood 7100 in discovery mode so i can pair to my phone?
Oct 15, 2009 | Kenwood DNX7100 Car Video Player
1997 chevy silverado has crappy radio reception. How do I find out if it is the antena or the cable?
If you pull the radio carriage out you should see a cable plugged into the antena port of the radio. If this is plugged in check the cable up to the antena
May 05, 2009 | 1995-1997 Chevy 1500 Truck Ignition...
Dnx-7100 and XM
the Garmin GXM-30 antena works
Apr 04, 2008 | Kenwood DNX7100 Car Video Player
Dell W2606C 26 in. HD-Ready LCD Television Logo
15 people viewed this question
Top Dell Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
CoppellTVRepair.com
Are you a Dell Televison and Video Expert? Answer questions, earn points and help others
