Question about Metrokane Rabbit Electric Wine Opener
Display will not show if low or how many bottles have been opened
Is there some way to activate the display screen on top of the rabbit?
How do I use the original rabbit
I assume you are talking about the rabbit wine bottle cork remover. here is a you tube video on how to. hope this helps . How To Use The Metrokane Rabbit Corkscrew
Sep 25, 2014 | Vehicle Parts & Accessories
How to lock the keys to avoid any accidental press of screen in my Sony Ericsson X 10.
http://end.sonyericsson.com/cws/support/phones/detailed/howtolockthekeypad/xperiax10?cc=il&lc=en
To activate automatic screen and keylock:
  1. From the Home screen, tap the applications bar.
  2. Tap Settings > Sound & display.
  3. Scroll to Display settings and tap Screen timeout.
  4. Select an option and tap OK.
To lock the screen:
  • Press the Power key.
To unlock the screen:
  1. Press the Home key or Power key to activate the phone.
  2. Drag your finger along the path.
Tip: You can change the path direction, by touching and holding at the top of the path and then flicking to the left or right.
  • Open in Google Docs Viewer
  • Open link in new tab
  • Open link in new window
  • Open link in new incognito window
  • Download file
  • Copy link address
  • Edit PDF File on PDFescape.com
Nov 24, 2010 | Cell Phones
How do you program so that when the phone rings you are able to pick up the call without hitting a button. Also when you make an outgoing call and you pick up the phone you get an active line instead of...
Sets that are programmed to ring should automatically have ringing line preference.
Programming is done on M7310, M7324 and T7316 sets.
To set up ringing you need to enter programming by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say TERMINALS&SETS.
The 4 top line/feature keys are now used for programming2.gif.
At the terminals&sets prompt, press the show key (top right arrow).
The display should now ask for an extension number. Enter extension number you wish to program ringing on.
Press the show key (top right arrow)
The display should sat LINE ACCESS
Press the show key (top right arrow) .
The display should say LINE ASSIGNMENT.
The display ask for a line number. press list
The display should say line 001: appear only
press the Chng key till it says appear & ring
press next key (lower right arrow)The display should say line 002: appear only
repeat procedure for remailing active lines
press the heading key (top left arrow) til the screen says terminals&sets again
Prime line assignment is also programmed at the terminals&sets prompt.
press the show key (top right arrow). The display should now ask for an extension number. Enter extension number you want to change the prime line on.
The display should say Line Access
The display should say Line Assignment
Press the next key (bottom right arrow) .
The display should say Line Pool Access.
Press the next key (top right arrow)
The display should say Prime Line
Press the Chng soft key till you get to the desired line or pool to pick up on
Press the release key when finished
Oct 19, 2009 | NorStar Meridian M7310 Phone
Screen showing J00
If this is the model that I think it is this one stumped me and come to find out it was related to toner. Is the toner bottle full or is the waste toner bottle full. It seems and agian this may not be the model, you have to put in new toner and the machine will run untill it tones up. During that time the machine will not work...Again i have seen this but do not know if this is the correct model, Good luck..
Jul 17, 2008 | Copystar CS-2020 Copier
1981 volkswagen rabbit convertible top replacement
You can get them here for $19.99 USD.
It is an actual video showing each step.
http://www.topgunwon.com/DVD/
Jul 08, 2008 | 1983 Volkswagen Rabbit Pickup
Canon ir1510 blank copy problem, and always showing toner level low indication... but toner and drum is new... whats a solution.. pls any one tel me..
check the hopper motor of the machine. the motor near behind the toner. check if it turns. open the front cover. check the cover for switch activation. activate the switch and make a copy if the toner bottle turns the hopper motor is ok.
Mar 19, 2008 | Office Equipment & Supplies
Black Screen
Can you shoot? battery might be low taking it to "save-power" mode. Try hitting "DISPLAY" to force the LCD screen to show.
Oct 23, 2007 | Cameras
Metrokane Rabbit Electric Wine Opener Logo
Top Metrokane Home Experts
john h
Tom Chichester
Are you a Metrokane Home Expert? Answer questions, earn points and help others
