Question about Electrolux Irons
I want to disassemble the electrolux Iron - Electrolux Irons
Shark iron leaks water from the bottom of the body where the power cord come out. could it be a crack in the holding tank? Is there a way to fix it,or will I need to purchase a new iron?
It is hard to assess what would be the cause, but I think your diagnosis may be correct, of a possible crack, or a tube has come loose. You tube has instructions on how to disassemble and iron if you are up to it and have the tools. Then you'd have to order a replacement part, and re-assemble. I'd just go to walmart & buy a new iron! But that's me! :)
Iron Disassembly Process
Nov 16, 2016 | Irons
Tip
I just took apart a Sunbeam iron. This is how it disassembles: first remove the...
I recently had a problem with the steam button. It somehow during normal use came off its track in the handle and was stuck down in the "slot". After several searches online and this site i tried a knife along all the edges trying to figure out how to disassemble the iron. Well one quick flick with my knife to the side of the steam button and it came out. Well the surprise was the screw under these buttons. Hopefully this can help someone looking to disassemble the iron when they have problems.
on Jun 11, 2011 | Sunbeam 4214 Iron
Tip
Disassemble?
on May 08, 2009 | Sunbeam 4214 Iron
I plug iron red light stays lit but sole plate dont get hot
The connection to the resistance might be burned out. disassemble carully, might need soldering.
If you disassemble and don't have experience repairing an iron, take photos for each step. See some videos about iron repairing
Iron Repair No Power or Short in cord wire Rowenta Master
How to repair broken iron
Iron Repairing sajid salman flv
Oct 26, 2015 | Irons
Bosch iron TDA76 light comes, on no heat
Hello, welcome to Fixya!
The problem is either from the heating element or a disconnected/loosed wire.
Get a screw driver disassemble the iron and check for any visible wire disconnection or burn. If all wire connection in the iron are intact, then it means the heating element of the iron is defective and needs to be replaced.
Good luck.
Nov 04, 2011 | Irons
My wife's sunbeam microglide iron does not get hot. What could it be the problem?. Mauricio. Thanks.
first remove the screw at the base. Next remove the moisture dial top (it should just pop off). This allows the iron to slide apart - the metal base from the top. It should slide about an inch then lift off.
My iron didn't get hot, and what I found is the gear that attaches the temp setting to the electrical was missing a tooth. Perhaps you could set the gear to permanently "ON". In my case I found out with brute force how the iron is supposed to disassemble... time for a new iron...
Mar 27, 2011 | Sunbeam 4214 Iron
Water is coming out the bottom of the iron
There is a rubber grommet that lives between the water tank and the heating plate chamber. If the iron was dropped, this grommet might have become disloged. Another possibility is that there is a problem with the chamber, and lastly with the heater plate. Irons are easy to disassemble if they don't have those special little screws that attempt to thwart the efforts from a standard screwdriver. (Please have the iron unplugged. Connectors in there love to hit stuff and you when disassembled.) Good luck.
Feb 26, 2010 | Rowenta Power Duo Iron
Blinking red light
This is a problem with a lot of Rowenta irons. It is the auto shut off that is not working properly and the only way to fix it is to have it disassembled and the switch hardwired to be on whenever the iron it plugged in. It is a thermal metal switch and it just stops working and then the iron will not turn on and the yellow light blinks.
Sep 06, 2008 | Irons
Hi i have an edbs920 steam generator iron, my problem is that it will dry iron but wont steam up anymore, after turning the system on the power indicator light should turn from the flashing orange pre...
it can be that one of the thermostats controlling the water flow pump into the steam generator has become open circuit, caution is advised as this can potentially overheat the steam generator for there being lack of water, depending on your system design...i could be wrong just a guess !
Apr 30, 2008 | Euro-Pro Steam Generator EP8001 Iron
Irons Logo
50 people viewed this question
Top Electrolux Irons Experts
Are you an Electrolux Iron Expert? Answer questions, earn points and help others
