Question about Konica Minolta Minolta Di 650 Di 551 Di 5510 Di 7210 Copier Toner 604a
Error code 42-2
Di650 error code 42-2
  • Konica Minolta Master
  • 6,850 Answers
Below the main power switch (Located left rear) now move your down and towards the front about in the middle is vent well check the fan behind that vent. clean/replace worse case the board controlling it is bad.$$$$$$$$$$$$$$$$$$$$$$$$$$$
try this site for parts as a start
Precision Roller Printer Toner Cartridges Parts and Supplies Office...
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Posted on Jan 10, 2016
SOURCE:
How do I clear a SC35-02 code on a di650 Minolta copier ?
sir/mam
Power off the machine power on with the 2 and 5 depressed. Then go to soft switch set 3-1-1 if the code comes back its the fuser have a tech look at as it can start a fire ruining a perfectly good day
Apr 05, 2018 | Minolta Office Equipment & Supplies
How do i fix error code 42 on my cellphone? Help! Ive tried everything!
How to Repair Error Code 42 ' Windows Error Support - Error Tools
errortools.com/en/drivers/how-to-repair-error-code-42/
  1. Cached
  2. Similar
Code 42 Error is referred to as a Device Manager Error code. Before we explain what this code indicates, it is important to understand what 'Device Manager' is and its functions. Device Manager is basically a Windows tool that helps manage devices attached to the system such as the Printer, Scanner and the USB Device.
Error codes in Device Manager in Windows - Microsoft Support
https://support.microsoft.com/en-ca/help/.../error-codes-in-device-manager-in-windo...
  1. Cached
Lists the error codes that may be reported by Device Manager and the possible resolutions in Windows. ... Manager. If you are getting an error code that isn't listed here, you can contact the hardware device vendor's technical support or Microsoft Support for help. ..... Code 42 "Windows cannot load the device driver... (Code ...
ERROR CODE 42 - Boost Mobile Community
https://community.boost.com.au/t5/Setup-Phone-Support/ERROR-CODE-42/.../20989
  1. Cached
Sep 3, 2017 - 1 post Help! I can't send or receive text messages! It keeps saying: Error code 42 I can't call or receive calls either and I know that my bill isn't due.
Instructions To Fix Windows Error Code 42 - Error.info
https://www.error.info/windows/bus-driver-42.html
  1. Cached
  2. Similar
About the Error. The Windows error code 42 indicates the fact that the operating system has detected a duplicate device. This is usually caused by a sub-process that the system accidentally named incorrectly. Windows code 42 - Read what really helps. Though Windows error code can sound quite intimidating, fixing the ...
Dec 14, 2017 | Cell Phones
FM-2 Fan code, Below the main power switch (Located left rear) now move your down and towards the front about in the middle is vent well check the fan behind that vent. clean/replace worse case the board controlling it is bad.$$$$$$$$$$$$$$$$$$$$$$$$$$$
try this site
Apr 19, 2014 | Konica Minolta Minolta Di 650 Di 551 Di...
Minolta di650 error code sc50-01
If powering off then on the machine does not clear this code it is a fault with the serial drive signal from Printer control Board! Quite Expensive! Or main dive section of the machine. Recommend a Certified Tech look at it, sir/mam
Mar 14, 2014 | Konica Minolta Start Up Kit for DI650...
Code d'erreur sc29-03 minolta di650
Sir/Mam,
When was the last time your machine had a 250,000 Preventive Maintenance kit installed. Very 250K copies/print the Developer and certain parts need replacement, the drum at 500K. The code your machine has is telling you that either the drum is bad a sensor/sensor board is bad, or the drum is old and needs replacement. Also possible the sensor needs to be cleaned. Have to remove the drum cart then the drum to get to it. Recommend a tech do it.
Aug 01, 2013 | Konica Minolta Start Up Kit for DI650...
SC46-99 copier Di650
Bad Memory Chip (DIMM)
Oct 09, 2011 | Konica Minolta Start Up Kit for DI650...
Minolta di650 error code sc90-01
Sir, Mam
The middle section of the that you pull out to get paper jams will the circuit board the controls that section or a major board is bad you mite want to check for any paper that left a part of stuck inside that area of the machine look in the back (When you pull it out) IF not you Need a Technician!!! Not a normal code!!!!!!!
Feb 03, 2011 | Konica Minolta Start Up Kit for DI650...
Toner
Absolutely not. The Di650 is a Konica based machine and uses metalic developer. The Di450 uses a different process unit and the 2 toners are not compatible. Use of the 650 toner in the 450 toner will cost you hundreds of dollars in repairs.
Dec 31, 2009 | Office Equipment & Supplies
Konica Minolta Minolta Di 650 Di 551 Di 5510 Di 7210 Copier Toner 604a Logo
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
George Mclaughlin
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
