Question about Samsung FE710DRS Stainless Steel 30" Electric Range 5.9 Cu Ft
I want to replace glass top on samsung FE710DRS/XXA
Samsung wf328AA/XXA nf error
I believe that means "non functioning", but I am not positive. You will need to call a repairman. Check your Samsung washing machine booklet first.
May 22, 2014 | Samsung WF328AAW Front Load Washer
Samsung wf328AA/XXA d5 error
the lock system comes as one unit and that is how you replace it
May 21, 2014 | Samsung WF328AAW Front Load Washer
Samsung LCD 1080 flat screen tv model LNT4661FX/XXA clicks before taking 30 seconds to turn on.
Delay in turning on in flat panel TVs is mostly caused by weak and defective electrolytic capacitors in the power supply board. Most of the times they are easily recognized by their bulged top. Some times one has to hunt for them. If one can do it, it is a simple job. Good luck to you.
Dec 29, 2013 | Samsung LN-S4041D 40 in. LCD HDTV
I have samsung plasma tv 42" ps42c7s,have sound but dark ,no picture
Hi friend,,,
welcome to fixya
Commonly for Plasma tv's if the screen went out,,the problem will be the CATHODE RAY TUBE,it is costly to buy.if you want you can buy it,,or it may be the D-board problem will be also,,,
but it is unusual,so check the tube.
if your satisfied with my solution PLEASE RATE IT
thank u...
Apr 09, 2010 | Samsung SPN4235 42 in. Plasma HDTV
Tv doesn`t start
Howdy,
It sounds like you have a Power Supply Board problem. The PSB is the center Board (towards left) after you remove the back off the TV. Remove Board from TV with the 6-7 screws. Replace capacitors CM811, CM812, CM817 & CS806; 1000ufd 25volts. The board on left, you will see the cap tops are swollen.
Thanks for using FIXYA, BIG IRISH.
Jun 03, 2009 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
Vertical line on LCD TV Panel
Had this same issue on right side of 52" about 1 inch from side but had 3 vertical lines that disappeared after 40 minutes. Have Samsung LNT5265FX/XXA and about 16 months old. LCD Panel itself had to be replaced to fix it, fortunately had extended service plan
Oct 17, 2008 | LG 42LC2D 42 in. LCD HDTV
Samsung FE710DRS Stainless Steel 30" Electric Range 5.9 Cu Ft Logo
Top Samsung Kitchen Ranges Experts
Are you a Samsung Kitchen Range Expert? Answer questions, earn points and help others
