Question about Nikon D60 Digital Camera
Turning flash off on Nikon D60 - Nikon D60 Digital Camera
    Novelist:
    Scholar:
  • Nikon Expert
  • 197 Answers
Based on what you said, it appears that you want to know how to turn the flash off on your D-60.
On my D-90, you do this by rotating the mode switch on the top center left side of the camera one click counterclockwise, from the green automatic setting, to the white automatic with no flash setting.
You can also change flash settings from the menu. For my D-90, the manual says you use custom setting "e2." Check your manual for the D-60.
I never turn my flash off from the menu because it takes too long to turn it back on when you need it. Another alternative is to simply hold the on-camera flash in the down position while you shoot.
Posted on Jun 25, 2014
Steve5
  • 423 Answers
SOURCE: Nikon D60 highlight
When you have the flashing highlight areas, press the down arrow on the command dial and it will scroll through various playback screen options until you get to the screen you prefer to view.
Posted on May 30, 2009
pixeldawg
  • 71 Answers
SOURCE: need to change language on Nikon D60
Within the menu items that can be viewed on the back of the camera, there is a language option that you can set. You may have to scroll through all of these to get the correct setting. Nikon tends to change the menu layout from camera to camera, so it may not be the same in your D60 as it is in a D300 or other model.
Posted on Jun 03, 2009
tonyy168
  • 45 Answers
SOURCE: have a nikon d60 and the flash will not go off
if it pops up then the sensor is working and the mechanical parts are working,
Next is manual force flash test, if is manually flashes, the bulb is good else replace the bulb.
Posted on Sep 15, 2009
SOURCE: Nikon D60 is taking very dark pictures!!
elis - did you ever solve this problem? the same thing is happening with my d60 and i don't know what to do!
Posted on Jan 06, 2010
SOURCE: My Nikon D60 flash has
My D60 flash problem was that the flash would pop up, but would not flash. The release lever would keep "clicking"...it did no know that the flash was up. Since I was told that the min cost of sending it to Nikon for repair was $250, I downloaded a repair/service manual for the D60 from http://www.tradebit.com/filedetail.php/9029672-nikon-d60-service-repair-manual ($8.99)
This manual gives a step by step assembly and disassembly of the camera.
I actually lucked up and fixed my problem...
Problem Descripton/Solution (short version):
There was a tiny plastic collar at the flash hinge that got pushed back into the camera. This collar served to close a couple of contacts. I stuck a home made wire/double hook tool into the hinge clearance hole and pulled the collar out and snapped it back into place.
Problem Description/Solution (LONG version)
WARNINGS (based on experience)
1. Yes, the flash will still shock the **** out of you..even with the battery out. You will smell burnt hair/flesh.
2. Be careful of the tiny contact leaf springs. They are hard to bend back into the correct position.
3. The #00 screws are easy to strip out. Apply firm pressure, turn slowly, and make sure screw driver is aligned properly.
4. Proceed at own risk (to camera). Make sure your warranty really has run out. There are many ways to make things worse. You can back out now and buy an external flash.
All I had to take apart however was the top cover of the flash (two tiny screws on underside of the flash #00 philips head). I found that there are two tiny copper or gold "leaf spring" contacts that have to close to send a signal that the flash is up. These are located at the hinge where the flash wiring runs into a clearance hole into the camera (hole is a center of rotation of the flash). There is a small plasitc collar that fits into this clearance hole from inside the flash/camera base and through the flash housing at the pivot point and snaps into place via 2 plastic hooks or tabs (download/see repair manual). This collar serves to secure the flash housing to the base but also has a tiny pin sticking out that catches one of the contact leaf springs and closes the circuit. The problem is that this collar got knocked out of place and pushed back into the camera. I made a home made wire/double hook tool out of 22 gauge wire (see attached picture) and worked it into the clearance hole by pinching the hooks together and working it in. Go in above the flash wires (top of hole) since the wire path goes downward into the camera. With some work and luck I was able to hook the edge of the collar and pull it back out and snap it back in place.
I then put the flash cover back on and everything still seems to work.
My Hook Tool....
Posted on Oct 16, 2010
I've used the Quantaray PZ-1 DSZ on my Nikon N80 film camera and had no problems. I would like to use it on my digital Nikon D60.
There is no problem with the trigger voltage, which I assume is your primary concern. You may not get all of the features you would with a Nikon flash, but you should be able to use it with the D60 just as you use it with the N80.
Jan 05, 2013 | Quantaray PZ-1 DSZ for Nikon TTL Flash
Is the Sigma ES 430 ST compatible with my Nikon D60 or D7000?
Do you mean the EF 430? If so, then yes, it is compatible with the D60 and D7000, at least as far as the flash trigger voltage is concerned. You may not get all the capabilities of more recent Nikon flashes, but it will work.
Nov 05, 2011 | Nikon Cameras
Will the nikon sb16 flash unit work with the Nikon D60
Yes. The trigger voltage of the SB-16 is well within the safety range of the D60 and other digital cameras. I use mine with my D90 without any problems. However, be aware that the SB-16 is a rather old flash, and will not work in the iTTL mode with the D60.
Oct 29, 2011 | Cameras
Hello i have nikon d60 and the flash do not pup out
In what mode(s)? In the point&shoot modes the camera decides whether to pop up the flash. In PSAM modes you decide.
Dec 25, 2009 | Nikon D60 Digital Camera
Aug 14, 2009 | Nikon D60 Digital Camera with 18-55mm +...
What is night mode on a Nikon d60. How do I turn it on and off?
Night mode?
Do you mean Night Portrait mode? Select it by turning the mode dial to the appropriate icon, deselect it by turning the mode dial to some other mode.
Do you mean flash? It pops up automatically in the point&shoot modes (except for Sports, Landscape, and NoFlash). You have to pop it up in PSAM modes.
Jul 17, 2009 | Nikon D60 Digital Camera
Nikon D60 highlight
May 29, 2009 | Nikon D60 Digital Camera with 18-55mm lens
Flash on Nikon D60 does not work
Hello. When i first bought a D60, it was working perfectly outdoors at day and would work without a hitch with external flash. However, the internal flash would never get released. No menu option would be of any use, only symptoms were flashing 'flash' and 'question mark' symbols in the finder. NIKON service fixed it - There was nothing wrong with the camera electronics. The little flash release mechanism somehow acted up and NIKON staff fixed it in +- 5 minutes. I do hope you have yours in full working condition by now.
May 19, 2009 | Nikon D60 Digital Camera
Using a speedlight
the SB-22 has a voltage of around 4.5v this means that it will not fry you D60 SLR so the answer is YES you can use you old flash gun with your D60
Feb 21, 2009 | Nikon Speedlight SB-22S TTL Flash
Nikon D60 Digital Camera Logo
61 people viewed this question
Top Nikon Cameras Experts
Steve
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
