Question about Hobart Food Mixers
Where can you find the dough hook for hobart mixer s601
ricardok45
  • 135 Answers
SOURCE: KitchenAid 600, Stand Mixer -
Hi. Stop using your mixer. If your mixer is still covered by warranty, call Kitchenaid Customer Service, they are very good with warranty repairs.
If your mixer is out of warranty, remove the silver band that surrounds the top of mixer. Remove the top cover. At the front of the mixer, locate the transmission housing which is now exposed. Examine this housing carefully for cracks. If you find cracks anywhere in this housing, you have found the under-engineered plastic transmission housing. Kitchenaid's replacement housing is made of metal. Your plastic housing has no business being in a mixer that is marketed as being able to mix bread dough. It cannot!
If you're confident that you can make the repairs yourself, go to the Kitchenaid website and download the parts drawings. Remove the Trans. housing, remove the worm gear shaft assembly which is driven by the motor.. Remove and save as much grease as necessary to thoroughly inspect the worm gear. Inspect the worm shaft bearings. Look for cracks, or missing pieces on the bearings. Look for crunched cogs on all gears. Be prepared to wait at least a month for your parts to arrive after you order them. The replacement grease should be Shell Darina 2, or Chevron FM ALC EP 2.
If you're not confident about repairing this yourself, call Kitchenaid and determine the nearest "approved" repair shop.
You may be able to pressure Kitchenaid to pay for the damaged parts in your mixer. They are still installing these plastic Trans. housing on new mixers. Insist on a metal cover when replacing. Apparently, Kitchenaid feels no shame in their manufacturing process, and will not issue a recall notice for these housings. They are substandard at best.
If you found this solution helpful, please rate it. Good luck! ricardok45.
Posted on Feb 13, 2009
bigg t
  • 640 Answers
SOURCE: Hobart H-600-T Mixer Shuts down while mixing bread dough
What you replaced were the contacts on the overload,correct?These 'heaters' look like springs?If so you have other issues.I'm a hobart tech and repair these mixers often.Are you mixing pizza dough?
Posted on Mar 07, 2009
SOURCE: I recently acquired a KitchenAid/Hobart Model 4C
A number of attachments were available for the 4C, such as a juicer, a meat grinder, etc., all of which ran off the PTO on the front of the housing.  The only beater, however, was the wire one.  No dough hook was ever made.  I have been told that the motor didn't have the necessary power to run a dough hook.
Posted on Oct 02, 2009
milten1
  • 1304 Answers
SOURCE: how do you change the oil in a hobart h 600-dt
there is an oil case drain pulg under the top by the clutch, you can drain the motor housing through there, \
i have used 5w30 in a pinch
but it would be better if you ordered hobart oil from the website
its cheap but very very good
Posted on Oct 16, 2009
  • 10 Answers
SOURCE: Looking for a dough hook and bowl for a blakeslee
Blakeslee is still around phone # 1-708-656-0660
Posted on May 25, 2010
My dough keeps on rising up to the top of the hook
change the hook to spiral. J hooks tend to have dough crawl up
Feb 23, 2011 | Hobart D300 Stand Mixer
What is the correct dough hook to get for my 'OLD' A200 Hobart?
Check with your local Hobart office.
www.hobartservice.com Click on "Locate an Office" and enter your Zip.
Jan 20, 2010 | Hobart A200 Stand Mixer
The dough hook wont cone off.
Got a hold of Hobart company and resolved the problem.
Jan 06, 2010 | Hobart D340-6009 Mixer
Need to know the part number for a dough hook for a hobart a200c stand mixer. What number would be stamped on the hook?
A 20 qt "E" dough arm is S-23467. A 12 qt is S-62886.
A 20 qt "S" sweet dough beater is R-8022.
Jan 05, 2010 | Hobart A200 Stand Mixer
Having a hard time removing the dough hook on the h-600.
make sure the beater shaft is clean. is the dough hook new or old if its new you can deburr inside of dough hook to ease in install and removal of attch. please let me know so i can futher asist
Dec 03, 2009 | Hobart H600 Stand Mixer
Can you use a spiral dough hook when the mkixer runs in reverse?
You can but the dough would ride down towards the bowl instead of up and your mix would not turn out properly.What kind of mixer do you have?i'm a hobart tech and repair these mixers often.Let me know.
Nov 04, 2009 | Hobart H600 Stand Mixer
Dry clumps in pizza dough
Hi. You should consider a few things. They type of hook you use, can greatly affect your end result. If you're making a yeasted dough with a high protein percentage 12-13%, you should be using an "ED" hook, this is a spiral hook that has a sharp turn at the tip. You can find them on eBay for a competitive price. I believe that Hobart also sells them, but for a higher price. They are very good for mixing pizza type doughs, they also do an excellent job kneading the dough.
Have you checked the flour for lumps before it goes into the mixer? Have you tried sifting the flour?
Are you adding all the liquid and flour at once? If so try adding flour in stages to all the liquid. If you find that this solution helps you, please rate it. Good luck! ricardok45
Feb 19, 2009 | Hobart D340-6007 Mixer
The gear is slipping on my Hobart A200
In what speed is it slipping?You only use 1st speed for dough,right?Can you put it in gear and stop the hook from moving with your hand?Let me know.
Jan 13, 2009 | Hobart N50 Stand Mixer
Hobart a200 mixer won't mix
The bowl holds 20 quarts--are you overloading the mix?This mixer is not made for medium/heavy pizza dough.Depending on the pounds of dough,water and other ingredients will affect the mixer in some way.
Nov 09, 2008 | Hobart A200 Stand Mixer
Dough Hook Stops moveing under heavy load
Does the mixer work in any other speeds?Are you mixing pizza dough and in what speed?I service these mixers alot--i work for hobart.It sounds to me like you have a sheared key on one of the shafts.The mixer doesnt have a clutch.
Feb 21, 2008 | Hobart H600 Stand Mixer
Food Mixers Logo
27 people viewed this question
Top Hobart Food Mixers Experts
Ross Keen
John Tripp
John Tripp
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Hobart Food Mixer Expert? Answer questions, earn points and help others
