Question about Garden
How to replace self propelled cable on troy bilt 12av834q711 cable
landsend
  • 1066 Answers
SOURCE: Troy Bilt Self Propelled Lawnmower drive belt
belts usually come off for a few reasons.
They become loose...stretch or the tensioner moves,  Make sure that none of the tightening bolds are slipping.  You can dab them with a bit of paint.
when the pulleys are not in alignment or crooked or bent.  Eyeball the path from one pulley to another, also make sure the tensioner is in alignment and there are no other obstructions.
good, high quality belts are required, and they must be real drive belts...not regular v belts.  If there is a way to watch the belt in operation you can usually see what's going wrong.
On my lawnmower I had to grind some metal away where the belt went from the motor to the transmission.  Good luck
Posted on Apr 18, 2009
SOURCE: how do i replace a drive belt on a troy bilt self propelled lawn
You turn the mower over, remove the blade with a 9/16 or 5/8 socket. There is a bolt holding shroud on, 3/8 or 7/16, there are two screws by the rear wheels, 7/16 that need to be removed. Once the shroud is removed, belt can be removed and new one put on.
Posted on May 26, 2009
#1 Taper
  • 1040 Answers
SOURCE: Troy Bilt 190cc Z-Start Model 12A-446A011 21"Inch Deck
You need to remove a pulley to put the new belt on.
Jim
Posted on Jun 05, 2009
radar001
  • 1051 Answers
SOURCE: front wheels lock up when pull mower backwards
Typically self-propelled mowers are propelled using the front wheels, which only turn forward. Pulling the mower back while the front wheels are turning will damage the drive gears. It's best to raise the front wheels slightly off the ground before pulling back.
Posted on Mar 24, 2010
huffman49
  • 235 Answers
SOURCE: My Troy Bilt self propelled mower won't crank or
just tighten the adjustment screw after you push the throttle all the way down...good luck
Posted on Apr 14, 2010
How do you replace a drive cable on a troy bilt push mower model 12av834q711
I am assuming you want to replace the drive cable on this mover.
You can view this in detail in this video
https://www.youtube.com/watch?v=PbwO2ygfS0k
If you need the manual you can download from this site
Manual Troybilt Rotary mower 12AV834Q711
If not then please send a comment clarifying which cable you are referring to.
Parts can be purchased from this site
http://www.searspartsdirect.com/partsdirect/part-model/Troybilt-Parts/Walk-behind-lawn-mower-Parts/Model-12AV834Q711/1307/1500600/P0601106/00002
Aug 12, 2014 | Troy Bilt 5.5hp Self Propelled Mower
Variable speed doesn't work troy bilt self propelled lawnmower
Cable could be stretched belt could be worn or old, if it has a gear box maybe it slipped a gear or lost some teeth. Do some investigation, Good Luck
Jul 26, 2010 | Troy Bilt 5.5hp Self Propelled Mower
How would I get an owner's manual for a Toro
go to www.troybuilt.com u can request one on line or can be advised where to pick one up
Mar 10, 2010 | Troy Bilt 5.5hp Self Propelled Mower
Honda harmony self propelled cable snapped at end
Get a replacement cable, part number should be in your user manual...when you get the cable it should have directions on how to replace.
Sep 08, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Replacing Drive Cable on 05 Troy Bilt Self Propelled Lawn Mower
It is a pain in the ***!!! but not impossible to do it your self.
Jul 27, 2009 | 2005 Ford Focus
Jim
Jun 05, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Lawn mower cable won't pull to start engine. troy bilt 210 self propelled mower.
It's possible the rope came out of it's pulley groove and is jammed inside the engine housing.
Apr 25, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Garden Logo
49 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
