Question about Video Game Consoles & Games
How do i stop my ipv4 from disconnecting - Video Game Consoles & Games
How can i retrieve my IPv4 DNS #
Go to System Preferences -> Network -> Highlight the connection on the left side of the pane, on the right side you'll see your IPv4 information. If you need more detailed information, Click the advanced button.
Aug 26, 2014 | Apple MacBook Pro Laptop Computer with...
Tip
EPrinter Not Detecting iPhone or iPad to "Airprint" or "Direct Print"
I run an ePrinter wirelessly (WiFi) off a ASUS EA-N66 wireless repeater. This tip pertains to a HP 6525 printer in case you find this attempting to correct the same problem.
When first connected everything connected except the "Airprint" features or 'Direct Print" off my iPhone and iPad. I found the default printer settings were set to "Simultaneous IPv4 & IPv6". The iPhone/iPads communicate at IPv4. Theoretically they should function in the "Simultaneous IPv4 & IPv6" setting but they did not. Changing to the "IPv4" only setting corrected the issue and the printer functions with everything I have including a WiFi PC laptop, a Wifi Mac, iPhone and iPad.
on Feb 03, 2015 | HP Office Equipment & Supplies
I have been having issues with my internet connectivity for a while - its been fix after fix and i feel like im slowly fixing the problem but adding more onto it. The exact problem from the top - Spee
Problem is that ipv4 config.
For any computer on a home network an automatic IP-address is handy. So the ipv4 config should be set to DHCP.
But then there should be a router that hands out IP-addresses and the IP adress of this router should be given in the ipv4 config as Standard gateway.
That is for home, but to resolve internet adresses your computer needs DNS, you can use common dns servers, or the ones given by your internet provider.
Fill these in under DNS in the config.
Aug 23, 2014 | Microsoft Windows 7 Home Premium 64BIT...
Internet explolar 8
You can do this:
[Start], Control Panel, Network and Sharing Center, Change Adapter Settings, click the WiFi, click Change Settings of this Connection.
In the Networking tab, scroll down. If you see unchecked Internal Protocol Version 4 (TCP/IPv4) box, then check it.
If you don't see the TCP/IPv4 in the list, then you need to click the Install button and follow the instruction.
Mar 05, 2014 | HP 15.6" Compaq Presario CQ58-A10NR Laptop...
GETCE6B1, Internet Protocol Version 6 Not Available
The 'IPV4' (Internet Protocol Version 4) was designed for a world with 4 billion unique devices (desktops, laptops, netbooks, iPod Touch/Phone, IP-TV, cell-phones, et cetera).
That limit is being reached!
The newer 'IPV6' (Internet Protocol Version 6) was designed to give a unique IPV6 address for EVERY SQUARE INCH of surface of our planet.
So, if your computer is "talking" to an IPV6 device (router or modem), you should _NOT_ get "IPV6 not available". However, if your computer is "talking" using IPV4, you probably _WILL_ get the IPV6 not available" message.
No big deal. If your computer cannot "talk" IPV6, then it should "talk" IPV4.
Jan 18, 2011 | Sylvania G-Netbook
Internet setting
i m sending u some network's settings...
send me ur network's name ....i will send u thier settings
For idea-
account name-spicegprs
proxy - enable
use pref. access pt.- No
data bearer- packet data
packet data acc. pt. - spicegprs
network type - IPv4
For AIRCEL-
account name-aircelgprs
proxy - enable
packet data acc. pt. - aircelgprs
network type - IPv4
FOR AIRTEL-
account name-mobileoffice
proxy - enable
packet data acc. pt. - mobile office
network type - IPv4
Dec 22, 2010 | Nokia 5320 XpressMusic Cellular Phone
How do i find my ip address because when i go on run,cmd then you get the command promt i type in ipconfig it comes up with ipv4 instead of ip address and when i hav my ip how do i get my wep key please...
i'm sorry, but the IPV4 address should look like, (204.555.234.343), where an IPV6 address is a BUNCH of letters and numbers separated by colon's, try ipconfig /all 'more
if you get an AUTOCONFIG ip address, then something is setup wrong in your network. btw, IPV4 is practically what everyone uses....
Sep 25, 2010 | D-Link DSL-G604T Wireless Router
What is ... '' Teredo Tunneling Pseudo-Interface , something to do with IPv6 as part of networking ??
Teredo is an IPv6 transition technology that provides address assignment and host-to-host automatic tunneling for unicast IPv6 traffic when IPv6/IPv4 hosts are located behind one or multiple IPv4 network address translators (NATs). To traverse IPv4 NATs, IPv6 packets are sent as IPv4-based User Datagram Protocol (UDP) messages. This article provides an overview of Teredo—including Teredo addresses and packet structures—and detailed explanations of how communication is initiated between Teredo clients, Teredo host-specific relays, and IPv6-only hosts using the IPv4 Internet, the IPv6 Internet, Teredo servers, and Teredo relays.
more at http://technet.microsoft.com/en-us/network/cc917486.aspx
Dec 31, 2009 | Computers & Internet
Wireless router problems
your computer is only connected to the signal coming from the router that's why it's saying connected but it seems that your router is not properly configured to provide internet access since your dns server is the same as your default gaetway. it could be that the your router is not in sync with the modem.
- if it's working before, tyr to power cycle everything by turning all the devices off then turn on the modem first, wait for all the lights on the modem to turn on then power on the router and the computer.
- if the router is for initial setup, kindly provide me you ISP, brand and model of the modem and how you connect the modem to the router and tell me if how you access the internet directly from the modem.
Jul 02, 2008 | D-Link 802.11g Wireless Router WBR-1310...
Video Game Consoles & Games Logo
248 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
