Question about Sony Alpha DSLR-A100 Digital Camera
Sony dslr a100 won't switch on. battery ok - Sony Alpha DSLR-A100 Digital Camera
  • 31 Answers
The problem is with the CF card nit the camera
get a new card and your good to go
Posted on Dec 26, 2014
5 Suggested Answers
SOURCE: Sony DSLR-A100, error code 0x5b
Same here. My camera gives me the same error code unless I shoot with the largest aperture/smallest F-number.
Posted on Aug 30, 2008
  • 9 Answers
SOURCE: MY MEMORY CARDS NO LONGER
Hi! I just had the same problem with my Sony A100, when I tried two different CF cards. Thinking the camera is broken, I checked online camera repair sites and also called Sony directly. Sony's flat rate, and that of PrecisionCamera is $228 to fix CF card failure. Then my daughter said, "the CF card in my room works fine in the camera" - and lo and behold - it does. The CF card that works is brand PQI and is marked Hi-Speed 60 2Gb. The cards that do NOT work are marked SanDisk Ultra II 1.0Gb and SanDisk 128 Mb. So my advice is, before you give up on the camera as broken, try a number of different CF cards first.
The second cause of CF failure is if someone has pushed a CF card in the wrong way. That can bend one or more of the tiny metal contact pins in the CF socket in the camera. Look carefully to see that all the pins are straight up. [I don't know how one can straighten these pins, or if the whole socket would need to be replaced...but at least you can determine the cause of the CF failure.
Best regards - Michael
Posted on Feb 16, 2009
robmcd27
  • 423 Answers
SOURCE: I have a sony dslr a100 and when I hook up the
Was your camera off when you connected it to the pc? It has to be off in order to work. Also, Does your camera require drivers? You might have to have the driver installed in your pc order to work.
Also, did you plug in your camera to your pc and go to my computer to see if it's listed there as a drive?
Rob
Posted on Mar 05, 2009
toheed99
  • 33 Answers
SOURCE: Sony Alpha DSLR-A100 Digital Camera
Its a minor problem. You can check form website the address of nearest service station.
Posted on Mar 16, 2010
Testimonial: "thanks, I was worried"
Sony DSLR-A100 eroor 0x58
Well, the good news is that there's probably no fault with the camera itself. It could be something as simple as the CF card being pushed in the wrong way. A look through the user manual will likely help you get to the bottom of your issue:
Sony Alpha DSLR A100 manual
Aug 13, 2014 | Sony Alpha DSLR-A100 Digital Camera
Does the error happen each and every time you take a snapshot, or only with some? As you are letting us know, have a look around the user manual to see if it can be of any help:
Sony a100 wont turn on
If the battery is charged, try replacing the battery first. Also try turning on the camera with the charger plugged in. If neither helps, you will probably need to have the camera sent for repairs, but you can still try checking out the user manual for helpful information:
Nov 11, 2013 | Sony Alpha DSLR-A100 Digital Camera
The display is black and won't show images or camera info
Sound like a display wrong, I suggest visit your photo techinican.
Jul 18, 2012 | Sony Alpha DSLR-A100 Digital Camera
Take apart sony alpha a100
Before attempting to take the camera apart, make sure to refer to the user manual. It will contain diagrams and schematics for the device:
Jan 05, 2012 | Sony Alpha DSLR-A100 Digital Camera
Image shifts off center and two corners appear rounded as if you are focusing on the rim of the lens.
Image shifts off center and two corners appear Problem with the Sony Alpha DSLR-A100 Digital Camera That
The Sony A200 kit (DSLR-A200K) comes with a DT 18-70mm (3.9x) f/3.5-5.6 zoom lens for an estimated US$600.
A separate Sony A200 kit (DSLR-A200W) includes two lenses: the DT 18-70mm mentioned above, and a 75-300mm f/4.6-5.6 telephoto zoom for an estimated US$800.
Click Here To Watch More Information about This Answer
Jul 18, 2011 | Sony Alpha DSLR-A100 Digital Camera
I cannot figure out how to use the timer setting on my Sony DSLR a100. HELP
Press the Drive button (marked with a one-handed clock). Use left/right to select the one-handed clock. Use up/down to select the delay, then press the OK in the middle of the cursor pad. Start the self-timer by pressing the shutter release button.
May 22, 2010 | Sony Alpha DSLR-A100 Digital Camera
I lost amual for my SONY a10... can't remember exactly how
Click Sony Support and download required instruction manual of Sony DSLR-A100
Mar 20, 2009 | Sony Alpha DSLR-A100 Digital Camera
Sony Alpha DSLR-A100 does not turn on anymore
Opening the device might help, check the connector of the battery if still connected. The drop may cause lose connections, may also happen to have a crack board... ^_^
Jan 12, 2008 | Sony Alpha DSLR-A100 Digital Camera
Sony Alpha DSLR-A100 Digital Camera Logo
85 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
