Question about Vintage Keeper 220 Plus Wine Cellar
Can not set temp
The unit is a Vintage Keeper 500. To adjust the temp there are two arrows one up and one down along with the temp display, The other day it was reading 63* but it had been set at 57* so I attempted to set it back down to 57*. Pressing the down arrow once the display went to 18*. Pressing the up arrow it went to 20*. I can't get it back to 57* it stays at 20*on the display.A separate portable thermometer now reads 59* and the unit is running constantly. John Mazza
3 Suggested Answers
  • 4793 Answers
SOURCE: We are looking at purchasing a used vintage
if the unit was left unused for 4 years chances are its way passed its sell by date,but if you switch it on and it works/was cheap to buy,then what the hell......
Posted on Jul 31, 2010
imufo2
  • 3773 Answers
SOURCE: My Vintage keeper 220 will
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
First I would check cold control. Thats where you turn it off, if your temp is not warm. it can
be defective and not shutting off. If your temp is warm proceed with the following.
I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if FREEZER CONTROL is turned WARMER WHICH MAKES THE REF COLDER AND VICE-VERSA. SEE?
The ref. temp should be about 33-35
The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
The higher the number you turn it up to is the coldest
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
Make sure back cover is on the fridge. Some take them off and throw them away.
make one out of cardboard if its gone, using the holes of the old one.
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
NOTE: This
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
This can cause slow ice making if its too high even tho its freezing everything else at 25 degrees
The icemaker is 110v
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects thenyou need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
If its leaking or no water at icemaker or door either one, then the valve at the rear bottom of ref needs replacing
First I would check the fan in the freezer. Listen to see if it is running
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also if it is getting drinking water to the door but not to the icemaker (or vice versa) Then you need to replace
the water valve at the bottom rear of the fridge. It is a double valve and one side is not working
If you still have trouble GO HERE:
http://www.applianceaid.com/procedures.html
Thanks
for using fixya
Leo Ponder
imufo2
PLEASE GIVE A TESTIMONIAL AND VOTE FOUR THUMBS UP IF THIS WAS HELPFUL
MORE TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
NOTE: This
For
extra help go here:
Thanks
for using fixya
Leo Ponder
imufo2
Posted on Aug 18, 2011
After changing batteries clock won't reset help
Set the Time & Date
The clock and calendar are utilized to time stamp history records and other data, so it is important to set the time and date soon after you power on the display unit.
Set the Time
1. Press the "up arrow" or "down arrow" buttons until "SET CLOCK?" is displayed on the Selectable Category part of the display unit.
2. Press the "SET" button to set the clock.
3. Press the "up arrow" or "down arrow" to adjust the hour.
Note the "AM" and "PM" indicators.
4. Press the "SET" button to confirm hour
selection.
5. Press the "up arrow" or "down arrow" to adjust minutes.
6. Press the "SET" button to confirm minute
selection.
The clock is now set.
https://www.acurite.com/media/manuals/01010W-instructions.pdf
BACK OF DISPLAY UNIT
1. A-B-C Switch
ID code that must match 5-in-1 sensor’s A-B-C switch to ensure units synchronize.
May 09, 2015 | AcuRite Acu-Rite 01010W Professional...
The actual temperature of my oven does not agree with what it says on the digital readout in the clock area. I have been told that you can adjust the reading of the clock, but I cannot find the service...
Press bake and set temp. to highest setting on some it's 500 on others it's 550 aftef setting to highest bake setting. Press and hold bake button until 00 is displayed,use up/down arrows to adjust in 5 degree incriments to plus/minus 35 dergees . ONce you've adjusted it push cancel/off button and you adjustment will be stored even if power loss and clock went out.
If your temp is more than 35 degrees off the clock needs to be replaced
Aug 16, 2011 | Ovens
How do you recalibrate the oven temperature of a Whirlpool Accubake oven system
To do that;
  1. Press BAKE
  2. Select a temperature of 550 or highest temp on some models its 500
  3. Quickly (within 5-seconds of setting 550) press and hold the BAKE button approximately 5-15 seconds until "00" or the previously entered temperature adjustment is displayed.
    Pressing longer could cause an F0, F1 or F7 error to be displayed.
  4. Press the UP/DOWN arrow button or turn the set knob to change the oven temperature in 5° increments to a maximum of +/- 35°
  5. Press the CLEAR or OFF button to return to normal operation.
Gene
Aug 12, 2011 | Whirlpool Ovens
We are looking at purchasing a used vintage keeper. The owner turned it on and it was cooling down to 55 and then it shut off. There are no instruction booklets so we had to guess as to how to restart it....
Jul 31, 2010 | Vintage Keeper 250 Plus Wine Cellar
What is the procedure for recalibrating the digital oven temp control for a built-in, dual element electric unit?
Oven will be off, of course.
Depress the Bake button; hold it down for 5-7 seconds.
The default offset of 0 will appear in the numerical display. Or, if the oven has previously been adjusted, you'll see that setting. Use the 'up' or 'down' arrow to adjust the temperature by the desired amount. The adjustments are in increments of 5 degrees F. Maximum adjustment is 35.
Press 'Start' to save the new setting.
I recommend rechecking the oven temp at this time. I expected to see a 25 degree increase, but all I got was 10.
Jan 24, 2010 | Whirlpool Ovens
My kool space wine cellar is not holding temperature
has the cellar ever worked right in your home? These small refrigeration units basically move heat from a conditioned space to another space that is not objectionable such as your home where your central air system then moves the btu's. This being said, the cellar has a ventilation system that must pull in room air and push out the box air. these vents must be clean and clear of obstrucions to ensure proper performance by the equipment
Nov 26, 2009 | Vintage Keeper Koolspace Wine Cellar
Koolspace wine cooler
I have the Vintage Keeper Odyssey. I had the same thing the other day. Unit is 7 years old. Vintage Keeper web-site suggested to unscrew the control box and remove. (The box with the "Set" and Up and Down arrows. Unplug the wiring and sensor on the back and then plug back in. Plug in the unit and text. It took my "AL" away.
Unit doesn't cool very well. A coolant leak may be my problem. I was looking for solutions other than buying a new refrigeration unit.
Jun 07, 2008 | Vintage Keeper Koolspace chillR Cooling...
VP500 Cooling unit issues
http://www.rosehillwinecellars.com/3rsV2/54_RHWC_plans/tuscany_plus_250_500.pdf
above is a link to the Vintage Keeper manual PDF format manual and problems and trouble shooting guide
Oct 23, 2007 | Vintage Keeper VP500 Wine Cooler
Vintage Keeper 220 Plus Wine Cellar Logo
Top Vintage Keeper Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Vintage Keeper Refrigerator Expert? Answer questions, earn points and help others
