Question about AOpen Computers & Internet
Reset switch location
My screen stay black.. nothing show up.. how can i reset the monitor?
SOURCE: Black screen
Try pressing the 3rd button, as it toggles the Analog or Digital inputs...
Posted on May 02, 2007
  • 63 Answers
SOURCE: monitor only stays on for 3 seconds
There is probably a bad capacitor within the monitor that will not allow the picture to "hold" in the on configuration. This will need to be replaced. You can send it back to Phillips, or 17" monitors are pretty cheap these days. I would suggest a Samsung or BenQ. They both carry 3yr warranties.
Posted on Aug 17, 2007
Scott Ellin
  • 558 Answers
SOURCE: monitor shows screen then goes black
It is the Monitor Cable connected to the CPU cabinet is faulty. Please check out the cable and its pin firmly.
Try to find the fault, may be the cable broken or tear up.
Let me know if further diagnose required.
Have a nice day.
Ellin
Posted on Oct 14, 2008
jesselohse
  • 128 Answers
SOURCE: monitor comes on but wont show picture
You should make sure the cable is plugged into the video port on the back of the tower. Also, if you have more than one video card, ie an "onboard card" and another card that was added later, try alternating one to the other and see if the other one works. You can identify video ports by finding the blue pentagonal plug. It also will be the only plug that your monitor cable fits into (that is describing a VGA cable, a white cable is a DVI cable and is even easier to identify.) You might also want to make sure the video card wasnt jostled out of place. The final solution could be you have developed some bad memory modules, or the memory was jostled out of its slot during the move.
Posted on Jan 03, 2009
budmrtn
  • 11361 Answers
SOURCE: The monitor switches on and shows benq logo, then
After changing the caps, do you get steady 12~18vdc feeding the inverter circuits? Inverter fuse OK? It can be bad transformers, or lamps also. Pictures will be great help. See where I post my pictures: http://s807.photobucket.com/home/budm/allalbums
Posted on Mar 05, 2010
Why does Sony laptop screen stays black when booting?
Shine a flashlight on the dark screen to see if you barelysee the icons on the desktop. If so, then the LCD Inverter is bad.
Plug in an external monitor and see if the display shows up on it. It can beany kind of monitor even the old big fat crt monitors as long as it has a vgacable to connect to your computer's vga port. If so that proves yourvideo card is ok. The video will show on most systems when you rebootwithout you having to do anything. Some systems will require you to hit the FN(Function key) + F1 thru F12. Hold down the FN key then hit the correctkey for displaying on the monitor (F1 thru F12). The correct key willnormally have CRT/LCD on it or it will have the icon of a display.
If you see no icons by shinning a flash light and the external monitor works,then your screen is bad. If you see no icons by shinning the flash lightand nothing shows on the external monitor, then most likely your video card isbad.
Mar 31, 2012 | Computers & Internet
Problem with monitor
Since the monitor is working normally other than turn off, I suggest plugging it into a power bar with switch. The pad switch is probably defective in the monitor.
Mar 11, 2012 | Dell Computers & Internet
My aser aspire shows nothing on screen when turn on. black screen
Are you using a HDMI monitor? The monitor I have has to be switched to HDMI by pressing the input button otherwise it will be black.
Jan 17, 2011 | Acer Aspire X3400 PC Desktop
When I turn my monitor on, the screen shows the desktop momentarily and then goes black. If I turn it off and on a couple more times, the desktop will stay on and function normally. Where is the likely...
Try the monitor on another computer, to check-out the monitor.
Does the POWER lamp on the monitor stay on when the monitor goes black? If so, then the monitor probably is OK.
Try a different monitor, to trouble-shoot the video-card.
May 28, 2010 | HP Vs17 17" LCD Flat Panel Monitor
Monitor isn't working...shows desktop screen for a second then goes black.
reinstall windows ur screen resolution is not accepted by monitor
Apr 26, 2009 | Computers & Internet
17" Sony Monitor Goes Black and No Light Shows On The Switch
Sounds like your backlight bulbs are wearing out.It is a common problem with Sony LCDs. Difficult to replace then.
Monitor Mike
Jan 03, 2009 | Sony SDM-HS73P 17" LCD Monitor
Black screen
how can u fix this black screen? the green power light is on, shows vista for a bit then turns black and stays black. any solutions or do i have to send it back?
Apr 03, 2008 | Microsoft HannsG HU171D 17" LCD Monitor
Screen stays black
Your inverter board is bad. It is time to change it.
This manual page 152 will show you what is involved.
http://h10032.www1.hp.com/ctg/Manual/c01035886.pdf
Mar 19, 2008 | HP Compaq Presario V6000T Notebook
Monitor only stays on for 3 seconds
Aug 17, 2007 | Philips 170S4FB 17" LCD Monitor
Black screen
Oct 05, 2006 | Dell 1703FPs 17" TFT LCD Flat Panel...
Computers & Internet Logo
27 people viewed this question
Top AOpen Computers & Internet Experts
Michael Galve
Michael Galve
David
David
Alun Cox
Are you an AOpen Computer and Internet Expert? Answer questions, earn points and help others
