Question about Apple iPad First Generation Front Glass Panel Digitizer Touch Screen
Sim is not provisioned
Cannot connect to WiFi network without a password I do not know
If I use my wifi password and decide I don't want this product how do I remove the password.
Tenda, So, it's time to remove a Wifi access point or password from your list. Here's how to do it. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Android 101 How to forget Wifi network
How to Change Wifi Password from Phone or Any Device
How do change my wifi password
Apr 21, 2016 | Tablets & eReaders
How to connect to wifi
Does it ask you for the password ...? If you don't know the password for that particular network, it won't connect
Feb 24, 2016 | Tablets & eReaders
How do I connect to Wi-Fi they keep asking for a password
If they are asking for a password, then the wifi you are attempting to connect to is a secured wifi network. Only unsecured networks can be connected to without passwords. If you are given the password by the network administrator, and enter it when asked, it will connect you to the network. Otherwise, you are attempting to hack a network that you are not authorized to use.
Nov 30, 2015 | Tablets & eReaders
NBN was connected yesterday but cant figure out how to input the new security code on my iPad. The new mini iPad connected without hassle and so did the PC. The iPad doesn't ask for the security code it...
This may fix your problem... Clear the cache that is stored in the settings.go to general settings ...look for safari ....empty browser history and cache.
then scan for any networks on the wifi settings....when you get to your router....don't enter password or try to connect to it....click right chevron to get to page that says forget network ....then rescan .....this time enter your password....it should connect.....Apple products are not happy if you change or update passwords on routers already configured.
Mar 02, 2015 | Apple iPad 2 Wifi 16GB
Wifi will not connect it sees the network?
Assuming you already know that a password isn't the issue and you know how to handle connecting to a password protected network...
Does your router have mac address filtering turned on? Maybe it's rejecting your tablet because the tablet's mac address list doesn't include the tablet's mac address.
Jan 03, 2015 | ZEEPAD MID Android Tablet 7 Inch WiFi
How do I connect to wi-fi?
To start you need to check you are entering the right password! The password is the one for the WiFi! Is it written on a card or on the router, it will be case sensitive!
Dec 27, 2014 | Amazon Kindle Wireless Reading Device
I have a RCA tablet rct6272w23 and I can't connect to internet what should I do?
Hi
To connect to the Internet with a tablet, you need to have either a SIM card with mobile access (3g or 4g) or a Wifi card in the tablet and access to a Wifi Hotspot. I downloaded the manual for your tablet here:
http://www.rcatablets.com/sites/default/files/CT9272W23%20IB%20English.pdf
and looking through it the first option does not exist for you as there is no facility for a SIM card.
Therefore you need to access a Wifi hotspot - somewhere. It could be your home router, a cafe, a railway station or a multitude of places. In order to access the Internet this way you must follow this procedure:
1. Go to Settings > WIRELESS & NETWORKS > Wi-Fi, and slide the Wi-Fi switch to the ON position.
2. The device will scan Wi-Fi networks automatically and display the available names.
• If the device finds a network that you connected to previously, it will connect to it automatically.
3. Tap a network name to connect to it, and enter a password if necessary.
4. Alternatively, if your Wi-Fi router supports Wi-Fi Protected Setup, tap the WPS icon at the top of the screen, and then press the WPS button on your router.
5. If your network does not broadcast its SSID, tap the Plus icon + at the top of the screen, and enter the Network SSID (name) of the network. If necessary, enter security or other network confi guration details.
In public places you may need to pay to get the necessary access password.
Hope this clears things up for you
Nov 14, 2014 | Tablets & eReaders
How do i get my wifi internet back
It sounds as if you simply need to reconnect to your wifi network. If you have already connected to it, but still have no access, then disconnect from your network, remove the network from your settings (Forget The Network) and then try reconnecting to it.
Aug 27, 2014 | Irulu 7" 4gb Mid Google Android 2.3...
Will not connect to wifi
  • Touch the Apps Menu button on the Home screen.
  • Open the Settings app.
  • Choose Wireless & Networks.
  • Choose Wi-Fi Settings.
  • Ensure that Wi-Fi is on.
    When you see a green check mark next to the Wi-Fi option, Wi-Fi is on.
  • Choose a wireless network from the list.
    Available Wi-Fi networks appear at the bottom of the screen. When no wireless networks are listed, you're sort of out of luck regarding wireless access from your current location.
    Optionally, type the network password.
    Touch the Password text box to see the onscreen keyboard.
    Touch the Show Password check box so that you can see what you're typing; some of those network passwords can be long.
    Touch the Connect button.
    You should be immediately connected to the network. If not, try the password again.
  • May 12, 2013 | Samsung Galaxy Tab Tablet PC
    I cannot connect my Literati to WIFI
    Ok! This is what I fund out personally. The WiFi connection needs to be a non-hot Wifi network. Meaning certain Wifi connections have a security lock preventing any file transfers. I tried several locations to make a connection (Coffee shops, Mc D's, Library, Work, etc.). The Best wy to connect your Literati is to find a friend who has a WiFi ruouter and ask him/her of there password temporarly.
    Now you need to enable the Wifi under the settings area by hitting the menu button ans scroll down to the settings tab. select the Wifi or wireless option. Enable the Wifi and your unit should start scanning the area networks. This is where you'll find your friends link or an open unsecure network. Do not select any links that have a pad lock unless your know there password. Once you join, wait about 1 minute and the unit will prompt you to update the software. From here it all down hill..
    The Hopeless Literati Guru
    Dec 26, 2010 | Sharper Image Literati Reader 16375680042...
    Apple iPad First Generation Front Glass Panel Digitizer Touch Screen Logo
    13 people viewed this question
    Top Apple Tablets & eReaders Experts
    Yoav Shilon
    Yoav Shilon
    John mullen
    john smith
    Are you an Apple Tablet and eReader Expert? Answer questions, earn points and help others
