Question about Microwave Ovens
Time showing on panel. No functions work.when I touch any button,
Time is showing on panel. when I touch any button, unit beeps, does nothing. Can not get unit to do anything.Unit beeps for no reason. I shut off power to try to reset unit. same problem
  • 82 Answers
You can try to reseat the serial ribbon but it sounds like a board problem. to reseat the ribbon, unplug unit. remove the case for counter top models, otr models need to remove the grille, and the control panel screw, lift up and pull out at the top. the serial ribbon is a flat set of wires at the top of the board lift on the connector latch to loosen the ribbon pull it out, push it back in and relatch. close up the control panel before plugging back in. if it works great, if not it is time for a new microwave boards are very expensive.
Posted on Jun 19, 2009
Microwave was beeping a single beep once in awhile now nothing happens but the clock still works
A lot of the time when that happens the touch pad is bad and may have a colappsed air pocket on a pad. ( it makes the unit think you are pushing a pad ) The only way to fix it is to replace it (the touch panel) . Did you see any numbers coming up in the display. Like if the 3 pad was bad and making it beep it may have been showing a 3 in the display,. Always possible it could be a bad main board. But most commonly I have found it to be the touch panel. Try to unplug it and then plug it back in and try to set the clock. when you do, try each number pad and see if they all work. See if any feel different.
Oct 17, 2017 | In Microwave Ovens
How do I get the microwave to stop beeping.It"s beeping and locking the controls by itself.
The touch pad sounds like it is trying to tell you it has a stuck pad. The touch pad will need replacing.
Oct 01, 2014 | GE Microwave Ovens
My GE Advantium microwave is beeping about 5 times every 2 minutes or so. The display says, "Keypanel Shorted. May need service. Press CLEAR to continue." Ironically, I need a working keypanel to press...
check the touch pad or control unit any short circuit in the control unit, other wise any moisture at control unit chec the circuit other wise replace the touch pad.
Jan 28, 2014 | GE Advantium SCA2000B Microwave Oven
On my GE Profile Microwave the led is lighted and shows the time correctly and displays the led buttons. When I press on the led buttons nothing seems to happen. Also, after some idle time, the led panel...
The touch panel has malfunctioned, Suggest replacing microwave unless you want to attempt repair. If so you will need a replacement touch panel for it.
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_a67ead41eb5fc62a
Jun 14, 2017 | GE Microwave Ovens
Galanz microwave Code 310
This how i fixed with mi open hand i hit the number pad , 3 times hard like i dont care anymore and yeaaaaa it work like new again
Jul 03, 2013 | Microwave Ovens
I have chefmate microwave and suddenly stopped working. it is showing 2:50 code on the screen only...it was working fine and dont know what happened to it and touch pad is not working..how do i make it...
HELLO.
The code on the screen indicate electric panel fault resulting from the touchpad malfunction.
The touch pad on your microwave oven acts as the brain of the appliance. It not only contains the buttons that you use to enter cooking settings and times, but also controls the function of the entire microwave. If the touch pad malfunctions or breaks completely, the microwave will cease to function. In this instance, the broken touch pad must be removed and a new touch pad must be installed, to restore functionality to the microwave.
1 Unplug the microwave from the wall outlet.
2 Remove the two screws, located on the front or top of the grill at the top of the microwave.
3 Pull the grill off of the microwave.
4 Remove the mounting screw from the top of the control panel.
5 Lift the control panel up and out to loosen. Look behind the control panel to ensure there are no metal tabs securing the control panel in place. If there are metal tabs, gently rotate the control panel to free the tabs.
6 Transfer the wires from the old control panel to the new control panel one at a time to ensure that the wires are properly installed.
7 Install the new control panel into the microwave and secure using the mounting screw that was removed.
8 Replace the grill from the top of the microwave and secure it using the screws that were removed.
9 Plug the microwave back into the wall outlet.
Thanks.
Sep 12, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Hi there, I've just moved into a new apartment and the Samsung Timesaver microwave seemed to be working fine yesterday, but it has been beeping at odd times for no reason. I turned the power off to stop...
Hi, this is usually a bad touchpad. The way to tell for sure is to kill power to the unit, take the control panel down and unplug the ribbon connector that connects touchpanel to the clock. Put it back together and reapply power. The clock will just sit there blinking and, obviously, the buttons won't work, either. if the beeping stops, then the touch panel is bad. And If it still beeps, then you have a bad clock.
Apr 03, 2011 | Samsung MC5694 Microwave Oven
Whirlpool gold series model gh7155xhs-1 buttons not functioning
Remove power to unit, wait 3 min. Plug unit back again try using touch control, If it still not working replace controller assembly, touch pad and board.
Sep 17, 2009 | Whirlpool GH7155XHS Microwave Oven
Ewave panel is on lock
As per the owner's manual:
The oven operation can be locked to prevent the microwave from accidentally being turned on. All oven functions can be locked.
To Set: Touch and hold the CANCEL/OFF Pad for three seconds. The Display shows “LOCKED” and the oven beeps.
To Cancel: Touch and hold the CANCEL/OFF Pad for three seconds. “LOCKED” disappears from the Display and the oven beeps.
If this does not work, then try a hard reset: Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If it still fails, you probably have a problem with the controller.
We regularly repair such control units for customers nationwide by mail for $39.95 postpaid in about a week or so with a one-year guarantee. It may cost a little more if you need parts, such as a new keypad.
Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more information & help.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Microwave Oven Control Panel Repair Nationwide
Aug 26, 2009 | Frigidaire Microwave Microwave Oven
Microwave Ovens Logo
57 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Are you a Microwave Oven Expert? Answer questions, earn points and help others
