Question about Corning Ware Wildflower 1 Qt Casserole Pyroceram A-1-B USA
Burnt on food on Corning Ware
Burned rhubarb when cooking it
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 17 Answers
Soak in hot water and baking soda overnight. Then scrub vigorously with a stainless steel scrubber or steel wool until clean.
Posted on Mar 03, 2015
Looking for a knob for a 6 quart oval slow cooker model no sco-150. its corning ware cooking pot and pyrex lid
If the knob is for the lid, you can use any cabinet door pull as long as it's made of metal.
Aug 08, 2017 | Crock Pots & Slow Cookers
I need instructions for 10in. microwave browner
Only place I've found is here: CorningWare Browner Instructions
As these dishes were designed by Corning for a 650 watt over, you can recalculate preheat and cooking times for your oven with the following formula:
650/(your oven's wattage) x (listed preheat time or cook time)
For example, for a Corning MW-9 dish, they list 4 minutes maximum preheat time. I have a 1,580 watt oven. So 650/1580 = .41 x 4 minutes = 1.64 minutes and about a minute and a half preheat. (MAX).
Mar 09, 2014 | CorningWare Microwave Ovens
MUST USE OLIVE OIL OR OTHER TYPE OF SPRAYS TO PREVENT FOOD FROM STICKING ON OUR NON STICK COOK WARE.... HELP.... NEED SOLUTION PLEASE....THANK YOU PRODUCT COOKS ESSENTIALS COOKWARE
you may be using too much heat. if you can cook with less heat and slower- this usually helps. If it was cheaper non-stick cookware you still may need to use a small amoutn of oil.
if you have burned the pan or used excessive heat i would recommend replacing it.
Dec 27, 2010 | Cook's Essentials Cooks Essentials Arome...
Need power cord for corningware broil,bake tray Model P-54 and for the P-35-B tray Thanks
The Corning Ware P-35B bake broil tray is for use inside your oven or broiler. It can also be used inside your microwave. It is made out of the same material as regular Corning Ware bake ware and may also be used on top of the range. This is not an electrical part and should not have a connection for a cord. Corning Ware did make hot plates. Is this what you are seeking a cord for?
Oct 12, 2010 | Kitchen Ranges
Turn on oven cleaning, but clean indicator stops after few seconds
hello
what this need is to set the reprograms
here are solution below
You can set the timer on a Corning ware slow cooker to automatically switch to a warming setting when you estimate Foods will finish Cooking The programmable features allow you to leave food stewing at home while you are out of the house, freeing up your day. Set the timer on a Corningware slow cooker to let the kitchen appliance do all the Work, and come home to a fully cooked meal.
  • Fill the insert of the Corning ware slow cooker with food and cover it with the lid. At least a quarter of the insert should be filled with liquid to keep the environment moist during long cooking times.
  • 2 Press the "On/Off" button on the left side of the electronic control panel in the front of the appliance. This will turn on the slow cooker to the low heat "Warm" setting.
  • 3 Press the "Cook Time" button on the right side of the electronic control panel to add hours to the timer which will show a total time in hours with a red digital display. Continue to press the button until the display indicates the desired cook time in one-hour increments up to 10 hours. The cooker will automatically adjust the temperature setting based on the amount of time you programmed on the timer. Cooking times of six hours or less automatically start on "High" heat and times of seven hours or more will start on "Low" heat. A small indicator light will come on below the word to tell you the cooking temperature.
  • hope this hope ?
    thanks
    Oct 03, 2010 | Ovens
    How can I remove burn stains from Corning Ware? It is on a teapot that burned dry.
    Can you let me know if you found a solution? I was warming tea and forgot. Thanks. joe.packer@att.net
    Aug 16, 2010 | CorningWare SC60 Slow Cooker
    Power cord for corning ware perolater model E1210
    The electric Corning Ware pots are no longer made, so to find parts, such as the power cord, go to eBay. The model #E1210 uses a unique Corning Ware cord, so don't buy the standard looking percolator cords, as they only fit the early 60's models. It should look like the cord in the photo below.
    Mar 15, 2010 | Hamilton Beach Proctor-Silex Simply Coffee...
    Have a corning ware countertop electric skillet. I need the skillet part. This particular item originally came with three parts. The bottom which is a seperate piece of corningware that heats up, the pan...
    I think the poster is talking about an item called Corning Electromatic Skillet. These Corning Ware skillets can be found all over the internet like Ebay. The part that sits on the warming area part is not called a skillet but a casserole. Look for one that is 12" by 12". Comes in many patterns also. If interested here is a site that has one available. http://SEWWHATSNEW47.blujay.com just search for Corning Electromatic skillet on that store. I think this is what the poster is talking about.
    Feb 18, 2009 | Kitchen Appliances - Others
    Corning Ware Wildflower 1 Qt Casserole Pyroceram A-1-B USA Logo
    Top Corning Home Experts
    Donni Steen
    Tom Chichester
    Are you a Corning Home Expert? Answer questions, earn points and help others
