Question about Brother HL 1250 Laser Printer
Brother 1250. Message on screen shows - fuser malfunction. Alarm light flashes, no lights,followed by all lights
  • 37 Answers
The Fuser is the part inside which gets hot. It will usually be a job for an engineer to replace, however it should try to reset by itself after 10 minutes with the power left on.
If not, switch off, hold down the button and switch on whilst holding the button. This will also reset, but if problem remains the Fuser unit will have to be replaced.
Posted on Jun 19, 2009
Brother dcp 7010 errors unable to print Use user guide but problem not solved
Hi Raj, please describe the error details( paper jam, color lights, blinking, solid, toner is original /refilled ? Recently changed-opened the fuser or the drum ?
To reset the drum error for a Brother DCP 7010 printer:
Turn the printer on and leave it like that.
Open the front panel.
You should see on the screen a message : drum change. Press "yes".
After that, the LED that was flashing near the drum will stop alerting.
Nov 26, 2014 | Office Equipment & Supplies
I can not get my printer to work it has all lights blinking
It indicates Fuser Malfunction.When any of the following error is indicated, turn the printer Off, wait 5 seconds and then turn the printer On again.
If the alarm continues, perform a Factory Reset:
  1. Turn the printer off.
  2. Hold in the circular button on the front panel of the printer.
  3. Turn the printer back on.
  4. When the DRUM light is lit by itself let go of the button.
  5. Hold in the circular button on the front panel again.
  6. Once the Alarm light comes on, let go of the button.
  7. This has performed a factory reset on the printer.
(Provided by Brother.com)
Hope this helps.
Bruce
Jun 14, 2011 | Brother HL 1440 Laser Printer
Brother HL 1250 Laser Printer Alarm light blinks at same time as ready light and printer does not print - why?
I have saeen this happen and there is usually a paper jam somewhere in the machine. Remember, it doesn't take much of a piece of paper to jam. Use a flashlight and look inside your printer closely. Also check your toner supply level.
Oct 02, 2010 | Brother HL 1250 Laser Printer
I have a couple Brother Printers HL-1435 that are in alarm status and will not print. The Drum light will flash, and then the Drum, Ready, Alarm and Data lights all flash at the same time. How can...
This could mean one two things.
* The toner cartridge is nearly empty.
* You have a paper jam.
To replace toner cartridge:
Click this link to go to the Brother site where it will show proceddure with illustrations how to change the toner cartridge.
http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/000000/000065/faq000065_011.html?reg=us&c=us&lang=en&prod=hl1435_us&Cat=7
To clear a paper jam:
Go to this link for procedure. It also has illustrations to assist you.
http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/000000/000026/faq000026_005.html?reg=us&c=us&lang=en&prod=hl1435_us&Cat=113
I hope this helps.
Aug 04, 2010 | Brother HL 1435 Laser Printer
My drum light and the ready alarm and data lights are all flashing and I just put a new drum in and the lights are still flashing and it is not printing.
Follow the link below to see what the light flashing mean.
http://welcome.solutions.brother.com/BSC/public/us/ca/en/faq/faq/000000/000100/000070/faq000170_012.html?reg=us&c=ca&lang=en&prod=hl1440_all
Apr 05, 2010 | Brother HL 1440 Laser Printer
I have replaced the fuser on Brother HL-4070cdw but the screen displays fuser unit end How do i clear the message Thank you
Look on page 115 under maintenence. Follow the instructions down to where it says Belt Unit, instead, find Fuser Unit then continue with reset instructions. Hope this helps.
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_HL_4040CDN_4040CN_4070CDW_EN_1037.PDF
Oct 27, 2009 | Brother HL-2040 Laser Printer
Brother HL 1250 Laser. Drum & page counter
Reset the drum counter as follows:
  1. Open the front cover.
  2. Locate the control panel button under the LED lights on the left side.
  3. Press the control panel button until all lights are lit, then release it.
    The Drum counter is now reset.
  4. close front cover
Mar 23, 2009 | Brother HL 1250 Laser Printer
My canon LBP5200 does all the usual whirring and stuff as if its about to print, when the paper feed normally starts instead the alarm light flashes and the following shows on screen :- Printer error....
The fuser unit is faulty.It sits at the back of the printer and disconnects by unlocking 2 blue levers.reseat it and try again,if not you need a new fuser
Aug 06, 2008 | Office Equipment & Supplies
Brother HL-1440/ flashing alarm light and flashing yellow data light
(blinking every 5 seconds) Toner Low Indicates that the toner cartridge is nearly empty. Purchase a new toner and have it ready for when Toner Empty is indicated. (solid) Toner Empty Replace the toner cartridge with a new one. User's Manual is available at the following location: http://www.brother-usa.com/Data/Documentation/Printer/User/UM_HL1440_1450_1470N.pdf Hope this helps.
Aug 22, 2007 | Brother HL 1440 Laser Printer
Brother HL 1250 Laser Printer Logo
282 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
