Question about Dell OptiPlex 7010 SFF Desktop Computer
Vga not function - Dell OptiPlex 7010 SFF Desktop Computer
Hi there I have a Toshiba CT - 9969 and want to connect my laptop using VGA? What must I do and where do I switch to VGA on the remote? Thank you
connect to TV using VGA port and select device or mode to PC in tv menu. or using remote
press laptop fn +F4
or see display change button in FN buttons .press with or without FN button . if you use HDMI pls cinnect with HDMI cable and in TV pls select HDMI mode in video mode
There is a row of Function keys at the top of the keyboard on every Toshiba notebook. These give you quick access to some useful functions. To activate them, just press the FN button on the keyboard together with the function key to activate the following commands.
press FN+F4
Nov 16, 2016 | Toshiba Computers & Internet
Acer keyboard functions
u must download ur fun key driver first but in this case u always can add vga monitor it printed in f5
May 07, 2013 | Computers & Internet
Can't get VGA adapter to work from labtop to Mitsubishi WS-55907 TV
If the TV has a VGA input it should work by simply striking the function key and the crt or monitor function **** on your f keys listed in blue.
Sep 04, 2011 | Mitsubishi Computers & Internet
Screen wont turn on at all. machine sounds like its running but no power to the screen. i tried the vga conection and hooked it up to a monitor but still no picture.
There may be a key combination that turns the external VGA adapter on. This may be something like FUNCTION + F4. Have a look at your Function keys and see if there is an image like a screen or laptop on it. Pressing and holding the FUNCTION key then pressing the screen key will let you enable the LCD screen, the VGA, or both.
Jul 27, 2011 | Toshiba Computers & Internet
I cannot connect to my hp dv5220us to the tv through vga. i think the vga driver is not installed . please suggest me which driver am i supposed o download.thank you.
Most laptops have three modes for video:
* output only to internal LCD screen
* output only to external VGA port
* output to both internal and external
Hold down the 'fn' ("function") key on the keyboard, and press one of the twelve 'F' ("function") keys, to "toggle" the video through the above 3 modes of operation, until you get output through the VGA port to the TV.
Also, on the TV, use the "input" or "source" button on the TV's remote control to select the 'VGA' input-port as the signal to be displayed on the TV screen.
Jul 16, 2011 | HP Pavilion Dv5220us Notebook
A compaq sr1000 need to know what no VGA input means. Will no allow my computer to come on
Welcome to FixYa
No VGA input means that the computer is not detecting video input from the video card. Usually you get this message if the video card of your system is not functional, the VGA cable is unplugged or the VGA cable is defective. To try and remedy this problem try these.
Check if you can hear sound coming from the system. If the video card is functioning then you should here the startup audio from windows.
Check the VGA connection on the back of the system. The VGA cable looks like thismalups_6.jpg
Please note that the VGA cable has two screws, make sure that both are fastened correctly
If the VGA cable is plugged in and you cant hear audio coming from the system. Then this would likely be caused by a defective video card on your computer
Hope this helps
May 28, 2011 | Compaq Computers & Internet
My video card type ax-8300gs/512d2 cannot function. lcd screen blank
There is problem in VGA Card. 1st you change your VGA Slot. If the problem exist Replace the VGA Card or have a local tech take a look at the VGA Card. VGA Card Drivers
Mar 16, 2010 | Rio Computers & Internet
How do i get my laptop screen to show on my tv? I have my laptop hooked to my tv with a VGA cable and my tv input is on vga, nothing comes on just blank screen
Most laptops have some key or combination of keys you need to push to tell the laptop to send the image to the alternate screen (VGA out). On Dell laptops it's often the F8 key. Pushing this key multiple times will typically toggle the output between your laptop screen, the VGA output and both at once. I hope this helps you out.
Dec 30, 2009 | Televison & Video
Brand new Toshiba Satellite L305D-S5868 laptop display screen has gone black, even though the computer is on.
Since your laptop is brand new , you may not be familure with it's function keys , FN
Sometimes the users accidentaly presses the FN and the F5 monitor function key at the same time.
which effectively turns the notebooks display off.
D in the image below is the FN function key
and the monitor function key could be F5 , it will have a little monitor symbol on it.
When they are pressed together it will turn the notebooks display off and enable any VGA monitor connected to it's VGA ports. when pressed again , they will turn of the VGA port and turn on the notebooks display.
Thank you for using FixYa!
Az.
Sep 18, 2008 | Computers & Internet
Dell OptiPlex 7010 SFF Desktop Computer Logo
12 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
