Question about Garden
Qualcast b43-no spark at plug
Qualcast b43
I got my qualcast 40 petrol chainsaw to start but the saw dies not turn. What's wrong?
Qualcast Product Support ' ManualsOnline.com
www.manualsonline.com/support/qualcast/
Manuals and free owners instruction pdf guides. Find the user manual and the help you need for the products you own at ManualsOnline.
Aug 08, 2015 | Garden
Qualcast rm34 assembly
I'm not familiar with the Qualcast rm34 assembly, BUT... from the "smoke" from beneath, I suspect that something has jammed/locked the blades, or blade pulleys, and the resulting slippage of the belt is causing the smoke.
With engine off, AND the spark plug wire FAR REMOVED from the spark plug, CLEAN OUT ALL DEBRIS FROM beneath the deck, above deck, AND from all areas in contact with the belt!
May 04, 2014 | Garden
I have a qualcast drop spreader but no instructions for setting spread rate
Usual to find this info on the fertilizer itself. It will show which number to set the spreader at.
Apr 06, 2012 | Garden
Linksys Wireless WPC54G drivers for ubuntu (Linux)
Just re-installed Ubuntu and let the installation load the broadcom b43 driver. If it doesnt the firmware need to be updated.
Here is a step by step install and firmware update for the b43 as well .
http://www.itadmintools.com/2011/11/getting-your-linksys-wireless-adapter.html
Feb 11, 2012 | Canonical Ltd. Ubuntu
I have a Qualcast Classic 35s there is no spark at the plug (new plug fitted) still no spark when held against cylinder head. What is the cause. It was working fine when I put it away last year. What is...
hi there
suspect engine is briggs and stratton 3.5 hp vertical
pull the wire at the kill switch and retest for spark -if still none
remove starter cover , pull wire off at magnetron unit retest
if still none replace magnetron coil and reset air gap to 0.010 "
assemble up and connect kill wires of course and let er rip
cheers pauly46
dont forget the thumbs rating
Jun 02, 2011 | Garden
Qualcast Suffolk Punch 35s lawnmower running problems
There is a small idling mixture screw on the side of the carburettor.
As the engine is not well suited to the carb. it mainly runs on the idle setting!
As long as you are not leaving the choke on. This is a little tab on the top of the carb. You start with it set on C then soon set it on the middle position, and after about 3 mins turn it off.
Jul 12, 2010 | York Yankees Bedding MLB Comforter
Please advise on where to puchase replacement parts for old Qualcast punch classic 30s lawn mowers
Hi howardandjan, You call it "old Qualcast punch" if it's called Qualcast punch it's not that old, it was originally called Suffolk punch (after the horse) and came in 14" and 17" cuts, the 30s (30cm approx 12") was originally called suffolk colt. when Qualcast took over just about all the british cylinder mowers Atco,suffolk,webb etc they started swapping names about but you should be able to get parts from any good mower shop try winchester garden machinery in hampshire always found them helpful
Aug 30, 2009 | Garden
Garden Logo
12 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
