Question about Craftsman 17 In. Dual Rear Tine Tiller
Tiller is locked into gear ,wont shift - Craftsman 17 In. Dual Rear Tine Tiller
2 Suggested Answers
  • 221 Answers
SOURCE: My tiller wont go into forward gear. Reverse is
Sounds like a problem in the gearbox if there is no external interference problems with the shift mechanism. It may require opening and inspecting the gearbox.
Posted on Jul 01, 2010
Testimonial: "Very Helpful to say the least. Saved me a lot of time and money"
Ryobi ry64400 tiller tines won't move engine runs fine
then you need to open the gear box and find out why if it has a forward and reverse the the shifting linkage it could be stuck in one gear and adding the other will lock it up as well
Apr 17, 2012 | Ryobi Cultivator
Tansmission won't lock into drive. 1979 Pony
sounds like your fork lever/ shift rod is bent and flexing
Jul 04, 2010 | Troy-Bilt Pony Garden Tiller
My tiller wont go into forward gear. Reverse is fine but wont shift at all. I lubed it well and the tiller does not have a lot of use. Any suggestions.
Jun 02, 2010 | Craftsman Rear Mount Tiller
Craftsman rototiller mod. # 917-294260 won't go into gear
try rolling it a bit. Sometimes the gear doesn't fully mesh correctly. As you try to shift push or pull the tiller juuuust a bit back and forth and try to shift as you do that see what happens. Or go into neutral and rock it then try again.
May 05, 2010 | Craftsman 8.50 Torque Rating Dual...
Rototiller wonts change gears
Try rocking the wheel as you try to shift.
Apr 30, 2010 | Craftsman 8.50 Torque Rating Rear Tine...
I have a craftsman 19 in dual rotating tines, rear tine tiller. # 917-293493. In mid till, the tines quit turning. Won't shift into any gear. Wheels are locked. Any ideas?????
It is going to be a transmission issue. You can try with the engine off, turning the trans pully by hand in the opposite direction that the motor was turning it.
Some gears in the trans got crossed up and locked.
Aug 12, 2009 | Craftsman Rear Mount Tiller
1995 crown vic gear problems/gear shift wont lock
most likely the shift tube bushings are bad- you may have also lost a few screws in the shift tube or they could just be loose. you have to pull the steernig column down to inspect/repair it.
May 30, 2009 | 1995 Ford Crown Victoria
Rototiller won't engage into gear
You will need to split the gear case if iam not mistaken it has chain drine the chain links break and you have to replace them
May 09, 2009 | Garden
Will not shift
neutral safety switch in console jammed, not releasing handle to change gears.
Apr 29, 2009 | 2005 Infiniti G35
Tiller tines won't turn where put in gear.
The spring goes in first followed by the ball. The ball should not get in the key way because that is filled by the slider pins that go up into the spur gear that drives the tines. Actually the slider pins drive all of the gears by engaging different gears as the gear collar is moved up and down. The detent spring and ball is the mechanism that is supposed to hold the the clutch collar in place. Mine jumps out of gear when tilling any depth except very shallow. I have reinforced the shifting forks and replaced the pins on the end of it. I believe that the pins wear and the arms spread because i have to keep pressure on the shifting rod or it will jump out of gear when tilling. Even with the reinforcing, pressure on the shifting rod will wear out the pins on the shifting arm. This will be my 3rd reassembly and I am leaning toward the detent spring being weak and allowing the shifting collar to move too easily. I may order an new spring and ball and see if that helps. I am getting pretty good at taking it apart.
Mar 18, 2009 | Mtd Bronco Rear Tine Tiller
Craftsman 17 In. Dual Rear Tine Tiller Logo
59 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
