Question about Apple iTunes
Photos not showing up in itunes, - Apple iTunes
How do i delete duplicated photos on ipod Nano 7th gen.?
You'd better cleanup your iTunes library firstly. Just click "View > Show Duplicate Items" and then you would just check off the duplicates that you wanted to remove. After removed all the duplicates in your iTunes, sync it to your iPod, then all duplicates in your iPod will be removed automatically.
Source: http://how-to-delete-duplicates-in-itunes.newgenresoft.com/ How to Delete Duplicates in iTunes 12 11 10 9 automatically
Jun 06, 2014 | Apple iPod nano 7th Generation
How can upload my photos in my iPad
When it comes to uploading photos to iPad, iTunes is always regarded as a good choice for many iPad users. As an official and free data transfer tool, iTunes can help users to sync photos from computer to iPad. The following guidance is about how to copy photos to iPad with iTunes.
  1. Plug iPad into computer with the USB cable. iTunes will automatically launch, if not, you need to manually start it on your computer.
  2. Click the name of the iPad in the left sidebar, and then click "Photos" in the right part of the window.
  3. Click "Sync Photo from" and check "Choose Folder", and then choose the photos from your computer.
  4. Click "Apply" at the right bottom of iTunes window. iTunes will then start syncing the photos from computer to your iPad. If you haven't enabled auto sync of iTunes on your computer, just go to Edit > Preferences > Devices, and uncheck "Prevent iPods, iPhones and iPads from syncing automatically".
upload-photos-in-ipad-oxaxc0rwhkhzilrwacqreyis-2-0.jpg For other methods to transfer photos to iPad, please read the following tutorial. http://www.leawo.org/tutorial/how-to-copy-photos-to-ipad-without-itunes.html
Mar 18, 2011 | Adobe Photoshop CS2 for PC
The PC on which I had itunes that synced with my ipad is no longer available. I want to transfer the music on my ipad to a new PC (with itunes). How do I do this transfer?
You can use iPad to PC Transfer, which can help you transfer from iPad to PC. iPad to PC Transfer is a professional sofeware, which can help you transfer Music, Movie, Photo, ePub, PDF, Audiobook, Podcast and TV Show from iPad to PC or iTunes library.
Dec 20, 2010 | Apple iPad 32 GB WiFi Tablet PC
How do you remove synced photos from the iphone?
You can do this in iTunes - with the iPhone connected select the 'photos' tab and deselect the folder containing the photos, then hit Sync to remove them.
Alternatively, just move the photos to a different location on your hard drive (out of any folder that is set to sync to iPhone), then connect to iTunes and hit sync.
Hope that helps!
Oct 30, 2009 | Apple iPhone 3G
I downloaded some pictures twice and I cannot find how/where to delete them. iPod 8GB, model #1236
You can not do it directly in the iPod. You have to use iTunes for deleting them.
Imported photos can be deleted from the iPod disk while it is attached to a Computer.
Connect the iPod to a Computer.
When the iPod icon appears in the iTunes Source list, select it.
If the Summary pane isn't showing, click the Summary tab.
Click "Enable disk use".
All imported photos are located in the "DCIM" folder on the iPod disk.
Delete the images which you want.
Source
Good Luck!!!!!!!!!!
Oct 20, 2009 | Apple Audio Players & Recorders
My ipod ShowS only Summary option in ituneS
turn the hold off and hold the middle button and play for about 30 seconds and the apple logo will show up then plug it into itunes and hit the restore button on the ipod tab in itunes.
Mar 16, 2009 | Apple iPod nano
How to transfer photos from a PC to an iphone
if u r using apple iphone
then folow the steps
install itunes in ur PC and connect the iphone
then select the mode in the iphone
open the itunes application ur iphone will show in that application it means u have successfully connected
drag and drop the songs from my computer to i tunes application it will transfer
Maybe what mentioned above is not useful for you, i personally share you with a article about transferring photos from Computer to iPhone
Aug 09, 2008 | Apple iPhone 3G
I haven't been successful at importing my photos from kodak easy share to my I-pod, nor do I know if it is possible to do so. thanks
Summary iTunes 4.7 and later has the ability to sync photos from your computer to any iPod with a color display (including Fifth Generation iPod, iPod nano and iPod photo). Find out the answers to common questions about photo syncing.
Products Affected iTunes, iPod, iPod nano, iPhoto 4.x, iPhoto 5.x, iPhoto 6.x, iPhoto 7.x, Windows, Adobe Phototshop
What sources can iTunes sync from?
iTunes 4.7 and later for Mac OS X can sync from:
  • iPhoto 4.0.3 or later
  • A selected folder of photos
iTunes 4.7 and later for Windows can sync from:
  • Adobe Photoshop Album 1.0
  • Adobe Photoshop Elements 3.0
Note: You cannot select a folder to which you do not have write access, like a CD. Later versions of Adobe Photoshop Album are not compatible. iTunes will only present the option to select a folder if a later versions is installed.
How much hard drive space do I need to sync my photos?
You need to have about as much free space on your hard drive as the size of your collection of photos. iTunes constructs a photo database on your hard drive in order to make photo syncing fast when you add new photos in the future.
What file formats can I sync to my iPod?
See iPod: Compatible photo formats for a list of file formats that can be used.
Can I sync my photos to my iPod manually?
You can't drag individual photos or groups of photos to the iPod like you can with music files in iTunes, but you can choose how you want them to be synchronized (see below) by selecting the correct options:
iTunes 7 or later:
  1. Connect your iPod to your computer.
  2. Select the iPod icon when it appears in the iTunes window (below devices).
  3. If the Photos pane does not show, click the Photos tab.
  4. Select your photo syncing options.
In iTunes 6.0.5 or earlier:
  2. Select Preferences from the iTunes menu (Macintosh) or Edit menu (Windows).
  3. Select iPod.
  4. Select Photos.
  5. Select your photo syncing options.
The syncing options include:
  • If you use iPhoto 4.0.3 or later in Mac OS X, you can have iTunes automatically sync all of your photos and albums or just certain albums every time you connect your iPod.
  • If you are using Adobe Photoshop Elements versions 3.0 or later, you can sync all of your photos or just certain collections of photos.
  • If you are using Adobe Photoshop SE in Windows, you can sync either all of your photos or certain collections of photos. If you are using Adobe Photoshop Album SE in Windows, you can only sync all of your photos. Note: While Photoshop Album allows you to sync only certain collections, Photoshop Album SE does not allow you to assign collection tags that are required for this to work.
  • If you are not using any of the above applications, you can sync all of the photos in a selected folder, or only photos in specific folders inside the selected folder. Folders inside the selected folder will be displayed as photo albums on the iPod, but not subfolders beneath them.
Can I add photos from multiple computers or user accounts to one iPod?
No, adding photos can only happen from one computer or user account.
Can I sync photos from my iPod to another computer?
No, all photo syncing is one way only, from computer to iPod. You can put full-quality copies of all your photos on the iPod in the options available in the Photos pane. Then drag the full-quality photos out of the Photos folder on an iPod that has disk mode enabled to any other computer.
What does it mean when "Optimizing for iPod" appears in iTunes and what happens if I cancel?
iTunes creates TV-quality versions of your photos and stores them in a database on your computer. This makes it much faster when you add new photos to your iPod later. If you cancel this optimization, the photos are not added to the iPod.
Jul 20, 2008 | Audio Players & Recorders
Apple ipod8gb
find the location for the photo and delete it.
here is the way to put photo on ipod. from this you can find the location for photos. from there you can delete it.
  1. Connect the iPod to your computer.
  2. Wait until the iPod icon appears in the iTunes.
  3. Select the iPod icon in iTunes window.
  4. If the Photos pane does not show, click the Photos tab.
  5. Select your syncing option.
The following are the sync options that you can use:
  • If you are using iPhoto 4.0.3 or later on Mac OS X:
    • You can have iTunes automatically synchronize all or selected photos and albums.
  • If you are using Adobe Photoshop Elements versions 3.0 or later:
    • You can sync all or just some collections of your photos.
  • If you are using Adobe Photoshop SE in Windows:
    • You can sync all or certain collections of your photos.
  • If you are using Adobe Photoshop Album SE in Windows:
    • You can sync all of your photos but you can't select and sync up.
  • If you are not using any of the above software then:
    • You can sync up all the photos in a selected folder, or only photos in specific folders inside the selected folder.
Note: Folders inside the selectedfolder will be displayed as photo albums on the iPod, but not their subfolders. Here is one more guide for transferring music from ipod to itunes and computer.
Jul 19, 2008 | Audio Players & Recorders
PICTURES
Using iTunes, connect the iPod to the PC u are using and right click on the track. This should bring up an options menu and u need to click the tab that says artwork. If its not thier already, copy/paste the artwork in and if its a full album u want to do, hold shift while selecting multiple tracks and do the same. Then in iPod options, show aretwork..... Et Voila
May 24, 2006 | Apple iPod MA446LL/A MP3 Player
Apple iTunes Logo
27 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
