Question about HP LaserJet 4 plus Printer
Manual ip for laserjet4 - HP LaserJet 4 plus Printer
  • John Bevan
    John Bevan Aug 21, 2014
    What is it that you need to know about "Manual IP for Laserjet 4?" Do you need to know if you can set one, how to set it, how to remove it, what the default is, or something else?
Replacing Laserjet4 with P3015 no printout
Make sure that the IP address is the same as the LJ4
When you display the printer from the control panel can you actually see it?
Look at the properties and check the IP address
Oct 26, 2011 | HP P3015 Laser Printer
Hp laserjet4 error 51
That's a "beam detect error"
Could be bad laser/scanner or DC controller.
It's an old printer. It might cost you more to repair it than to replace it.
Let it go out with dignity.
Dec 09, 2010 | HP LaserJet 4 plus Printer
Hewlett packard laserjet4. will not come on
If the printer will not power up, you may need to replace the power supply. It should be less than $100 and should take a repair person less than 45 minutes to accomplish.
Jul 08, 2010 | HP LaserJet 4 plus Printer
Will not come on
Check the power cable and the where the printer is connected, if connected through a surge connect directly to the wall. If the printer is still not responding it could be the low voltage power supply, and would require to be serviced.
Al
Eliteprintersolutions@gmail.com
Will HP laserjet4 plus print on card? If so how?
Depends on the weight (thickness) of the card. Assuming it's not too thick, feed it in through the manual tray (the flip-down tray on the front).
Feb 02, 2010 | HP LaserJet 4 plus Printer
Setup a laserjet4 printer
The printer might not be certified for windows vista if it is an older printer might just have to buy one that is certified for windows vista
May 17, 2009 | HP LaserJet 4 plus Printer
Hp laserjet4 printer will not print labels or envelopes
MP LOAD,
PC LOAD, or
LC LOAD
paper size,or
envelope size
The printer received a request for a paper or
envelope size not available in the printer.
MP LOAD: Load MP Tray with the requested
media. If the size is not selected in the printer
control panel, use the [MP[Paper[Size] key to enter
the requested size, or press [Shift] + [Continue] to
draw the requested size from another source, if
available.
Note: If MP LOAD remains in the display, you may
have to clear the buffer by resetting the printer.
Press [Shift] + [Reset].
Feb 12, 2009 | HP LaserJet 4 plus Printer
Printer is printing black line
Dirty Primary Charge roller. Change the Toner Cartridge.
Bad Toner Cartridge. Replace the Toner Cartridge.
Mar 07, 2008 | HP LaserJet 4 plus Printer
HP LaserJet4
In the printer driver, make sure you have the paper sizes set correctly  etc. Go over all the basics first.
Make sure that the options set under the "Device Settings" and "Advanced" tabs are relevant to your media and page sizes.
The chances are a setting in the driver has been changed by mistake.
Oct 18, 2007 | Office Equipment & Supplies
HP LaserJet 4 plus Printer Logo
Seeker5211
Seeker5211
