Question about Toro "Toro" Super Blower/Vac
How to put the bag on - Toro "Toro" Super Blower/Vac
Is it dangerous to put food directly into a reusable shopping bag?
It depends what the bag is made of, some are made of plastic and I wouldn\'t recommend that you put your fresh produce directly into the bag. Also we tend to not think about washing bags so these reusable grocery bags can be breeding grounds for bacteria. I recommend watching this short video about bacteria in shopping bags.
Sep 23, 2013 | Luggage & Travel
My duffel bag is dusty inside is it safe to put it in the washing machine?
I have never put a duffel bag in the washing machine. Usually my bags just get dusty inside so I just wipe it out with a damp cloth and let it sit in the sun to air dry. If it really needs to get cleaned you should check with the maker of the bag before putting it in the washing machine.
Sep 17, 2013 | Luggage & Travel
Took bag completely off and now I can't put it back together
Put the outer bag back on the unit. Make sure that you have pushed the outer bag down past a black lip. The piece that holds the inner and outer bag on the vacuum needs to be put on next. The small horseshoe shaped plastic piece goes on with hte open part down. Make sure that the docking station goes behind the lip I told you about. Next put the piece that the inner bag slides into on. This should have the bag back on the vacuum and ensure that it is on properly. If not, then it will pull of pretty easy and blow dirt into the outer bag...not the one that is meant to catch the dirt....I am a manager of an Oreck store.
Dec 04, 2011 | Oreck XL Ultra Bagged Upright Vacuum
My vacum e2000 electrolux dont start after i changed the bag ?
Try putting the bag in again. There is a kill switch on your door usually in the bottom left as your putting the bag in. Make sure that your bag covers that kill switch and your vac should start again.
Good luck.
Nov 07, 2010 | Electrolux UltraLux 2000 Bagged Canister...
My dirt finder light is not working My dirt finder red light never goes off. Have changed the bag, cleaned all filters.
take the bag out and the filter,put the coveer back on and start it up.see what the light says.if there is a clog somewhere and air is not getting into the bag it will read full.if that workd then put the filter back in and start it up.when the bag is in and hooked up does it expand when you turn it on.try putting the bag in and no cover and see what the bag does.please leave feedback
May 05, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
I cannot figure out how to put the bag in
theres a slot on the front stick your 2 fingers in there and pull ,its right above the front cover,then just pull the old bag out and push in the new bag.please leave feedback
Apr 04, 2009 | Bissell 3522 PowerForce Bagged Upright...
Vacuum bag busted
Greetings from GoVacuum.com,
Yes, you certainly can take off the outer bag of your Oreck and wash it in the washing machine. You DO NOT however want to put the bag through the dryer!!!!! Just hang the bag outside, and let it air dry. It is important to make sure that the bag is 100% completely dry before you use the machine again. If the bag is wet, it will cause dirt to turn to mud in the bag, and probably cause a foul odor when you use the bag.
There are 2 different types of bag systems with Oreck vacuums. The one pictured below is the older style that uses a metal clamp to hold the bag in place. The newer docking system, will be a white plastic clamp that holds the outer bag in place. They both will be removed the same way however. Simply take a screwdriver and pry off the clamp;
Once you have removed this clamp, simply pull the outer bag off. Once it has been washed, and the bag is 100% completely dry, put the outer bag back over the bag housing as far as it will go. When you put the clamp back on, it is imperative that the clamp go behind the plastic ridges, to ensure that it is tightly fastened. If the clamp is not put on correctly, this will cause the inner paper bag to fall off during vacuuming. Make sure that the clamp is in the right position when putting the bag back;
If you have any further questions, please feel free to email them to me. I really enjoy sharing my knowledge an passion about vacuum cleaner, and vacuum repairs. We do stock all Oreck parts, so if you need any parts, please let me know.
Chris Jones
GoVacuum.com
chris.jones@govacuum.com
Oct 15, 2008 | Oreck XL2200 Bagged Upright Vacuum
Problem putting in bags
The cardboard ends of the bags are notched and slide into the black holder, when the notch is seated, the red lever is held in place and the top will close.
Feb 21, 2008 | Euro-Pro EP022 Bagged Canister Vacuum
Vaccum Bag
Slide the plastic piece off the cloth bag and open the top. Looking down into the cloth bag, you will see the old bag. It is secured to the machine near the top. You will find the cardboard collar about a third of the way down. Remove it carefull. Now, stand BEHIND the machine and put your knee against the back of the handle and taking the new bag, open the hole in the cardboard collar and insert the bag into the cloth bag and put the cardboard collar onto the handle fitting. It helps to put the lower part of the hole on first and then press the top of the collar onto the handle fitting. The idea of standing behind with your knee against the handle is so that as you attach the bag, you will be pushing against your knee which will steady the machine and allow you to use the required force to complete the action. Once completed, fold the top of the paper bag down, so that when you replace the top slider, the paper bag is NOT clamped between the cloth bag and the slider.
Jan 25, 2008 | Hoover Soft Light U4266-940 Bagged Upright...
Toro "Toro" Super Blower/Vac Logo
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
lnbn1975
Mike Squire
Are you a Toro Garden Expert? Answer questions, earn points and help others
